Noctua
Seasonic
NF-A14 FLX
MagFlow
26.6 mm
210 g
212 g
900 U/min
600 U/min
1200 U/min
2.2 W
68.0 CFM
63.3 CFM
115.5 m³/h
107.6 m³/h
1.51 mmH2O
2.61 mmH2O
19.2 dBA
33.8 dBA
Beige
Braun
Blau
Braun
4.6 V
4.1 V
4.2 V
3.8 V
381 U/min
617 U/min
469 U/min
520 U/min
577 U/min
569 U/min
1199 U/min
1980 U/min
589 U/min
53.5 CFM
+56.2 %
34.3 CFM
33.0 CFM
+78.4 %
18.5 CFM
31.7 CFM
+74.1 %
18.2 CFM
30.1 CFM
+74.7 %
17.2 CFM
90.9 m³/h
+56.2 %
58.2 m³/h
56.0 m³/h
+78.3 %
31.4 m³/h
53.8 m³/h
+74.1 %
30.9 m³/h
51.2 m³/h
+74.7 %
29.3 m³/h
0.91 mmH2O
+0.9 %
0.92 mmH2O
0.91 mmH2O
+28.2 %
+22.0 %
0.30 mmH2O
+173.3 %
0.82 mmH2O
0.09
0.09
0.09 hPa
+28.6 %
+20.0 %
0.03 hPa
+166.7 %
34.2
-13.5 %
29.6
42.6
-27.0 %
31.1
40.8
-25.5 %
30.4
39.9
-24.3 %
30.2
  • 577
  • 777
  • 977
  • 1177
  • 1377
  • 1577
  • 1777
  • 1977
  • 577
  • 777
  • 977
  • 1177
  • 1377
  • 1577
  • 1777
  • 1977
  • 577
  • 777
  • 977
  • 1177
  • 1377
  • 1577
  • 1777
  • 1977
  • 577
  • 777
  • 977
  • 1177
  • 1377
  • 1577
  • 1777
  • 1977
