Noctua
Sharkoon
NF-A14 FLX
Silent Storm PWM RGB Fan
210 g
135 g
900 U/min
400 U/min
1200 U/min
1400 U/min
2.2 W
68.0 CFM
115.5 m³/h
93.6 m³/h
1.51 mmH2O
19.2 dBA
20.4 dBA
Beige
Braun
Braun
4.6 V
3.6 V
4.2 V
381 U/min
585 U/min
469 U/min
561 U/min
1199 U/min
1374 U/min
513 U/min
53.5 CFM
+57.3 %
34.0 CFM
33.0 CFM
+69.2 %
19.5 CFM
31.7 CFM
+29.7 %
24.4 CFM
30.1 CFM
+39.9 %
21.5 CFM
90.9 m³/h
+57.3 %
57.8 m³/h
56.0 m³/h
+69.2 %
33.1 m³/h
53.8 m³/h
+29.6 %
41.5 m³/h
51.2 m³/h
+39.9 %
36.6 m³/h
0.91 mmH2O
+28.2 %
0.91 mmH2O
+49.2 %
+22.0 %
0.30 mmH2O
+103.3 %
0.09 hPa
+28.6 %
0.09 hPa
+50.0 %
+20.0 %
0.03 hPa
+100.0 %
34.2
-7.3 %
31.7
42.6
-31.5 %
29.2
40.8
-32.6 %
27.5
39.9
-32.1 %
27.1
  • 561
  • 761
  • 961
  • 1161
  • 1361
