Noctua
Corsair
NF-A14 FLX
ML 120 RGB Elite
210 g
186 g
900 U/min
450 U/min
1200 U/min
1.6 W
68.0 CFM
58.1 CFM
115.5 m³/h
98.7 m³/h
1.51 mmH2O
2.90 mmH2O
19.2 dBA
30.4 dBA
Beige
Braun
Braun
4.6 V
3.0 V
4.2 V
381 U/min
510 U/min
469 U/min
450 U/min
169 U/min
84 U/min
1199 U/min
1993 U/min
53.5 CFM
+51.8 %
35.2 CFM
33.0 CFM
+36.3 %
24.2 CFM
31.7 CFM
+33.6 %
23.7 CFM
30.1 CFM
+41.5 %
21.3 CFM
90.9 m³/h
+51.8 %
59.9 m³/h
56.0 m³/h
+36.3 %
41.1 m³/h
53.8 m³/h
+33.5 %
40.3 m³/h
51.2 m³/h
+41.4 %
36.2 m³/h
0.91 mmH2O
+28.2 %
0.91 mmH2O
+49.2 %
+22.0 %
0.30 mmH2O
+136.7 %
0.09 hPa
+28.6 %
0.09 hPa
+50.0 %
+20.0 %
0.03 hPa
+133.3 %
34.2
-16.7 %
28.5
42.6
-30.8 %
29.5
40.8
-30.1 %
28.5
39.9
-30.3 %
27.8
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
