Noctua
Fractal
NF-A14 FLX
Prisma AL-12PWM
210 g
167 g
900 U/min
500 U/min
1200 U/min
1.9 W
68.0 CFM
85.7 CFM
115.5 m³/h
145.7 m³/h
1.51 mmH2O
2.80 mmH2O
19.2 dBA
32.0 dBA
Beige
Braun
Braun
4.6 V
4.5 V
4.2 V
3.8 V
381 U/min
443 U/min
469 U/min
269 U/min
1199 U/min
2001 U/min
550 U/min
53.5 CFM
+69.3 %
31.6 CFM
33.0 CFM
+59.2 %
20.7 CFM
31.7 CFM
+52.0 %
20.8 CFM
30.1 CFM
+52.4 %
19.8 CFM
90.9 m³/h
+69.3 %
53.7 m³/h
56.0 m³/h
+59.1 %
35.2 m³/h
53.8 m³/h
+52.0 %
35.4 m³/h
51.2 m³/h
+52.4 %
33.6 m³/h
0.91 mmH2O
+12.3 %
0.91 mmH2O
+28.2 %
+42.0 %
0.30 mmH2O
+103.3 %
0.09 hPa
+12.5 %
0.09 hPa
+28.6 %
+40.0 %
0.03 hPa
+100.0 %
34.2
-3.7 %
35.5
42.6
-21.1 %
33.6
40.8
-21.8 %
31.9
39.9
-28.3 %
28.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
