Noctua
Corsair
NF-A14 FLX
QL120 RGB
210 g
163 g
900 U/min
500 U/min
1200 U/min
1500 U/min
68.0 CFM
41.8 CFM
115.5 m³/h
1.51 mmH2O
1.55 mmH2O
19.2 dBA
26.0 dBA
Beige
Braun
Silber
Braun
Halbtransparent
4.6 V
3.0 V
4.2 V
381 U/min
245 U/min
469 U/min
472 U/min
1199 U/min
1600 U/min
53.5 CFM
+92.6 %
27.8 CFM
33.0 CFM
+60.0 %
20.6 CFM
31.7 CFM
+65.1 %
19.2 CFM
30.1 CFM
+74.8 %
17.2 CFM
90.9 m³/h
+92.6 %
47.2 m³/h
56.0 m³/h
+60.0 %
35.0 m³/h
53.8 m³/h
+65.0 %
32.6 m³/h
51.2 m³/h
+74.7 %
29.3 m³/h
0.91 mmH2O
+11.0 %
1.01 mmH2O
0.91 mmH2O
+82.0 %
0.5
0.5
0.30 mmH2O
+33.3 %
0.40 mmH2O
0.09 hPa
+11.1 %
0.09 hPa
+80.0 %
0.05
0.05
0.03 hPa
+33.3 %
34.2
-10.9 %
38.4
42.6
-10.1 %
38.3
40.8
-12.0 %
35.9
39.9
-10.3 %
35.8
