Noctua
MSI
NF-A14 FLX
MEG Silent Gale P12
27.5 mm
210 g
209 g
900 U/min
1200 U/min
0.7 W
1.4 W
68.0 CFM
56.2 CFM
115.5 m³/h
95.5 m³/h
1.51 mmH2O
2.21 mmH2O
19.2 dBA
22.7 dBA
Beige
Braun
Braun
4.6 V
5.5 V
4.2 V
4.3 V
381 U/min
906 U/min
469 U/min
742 U/min
194 U/min
186 U/min
1199 U/min
1980 U/min
512 U/min
53.5 CFM
+71.9 %
31.1 CFM
33.0 CFM
+53.0 %
21.5 CFM
31.7 CFM
+43.5 %
22.1 CFM
30.1 CFM
+53.1 %
19.7 CFM
90.9 m³/h
+71.8 %
52.9 m³/h
56.0 m³/h
+53.0 %
36.6 m³/h
53.8 m³/h
+43.5 %
37.5 m³/h
51.2 m³/h
+53.3 %
33.4 m³/h
0.91
0.91
0.91 mmH2O
+12.3 %
+62.0 %
0.30 mmH2O
+170.0 %
0.09
0.09
0.09 hPa
+12.5 %
+60.0 %
0.03 hPa
+166.7 %
34.2
-8.8 %
31.2
42.6
-18.3 %
34.8
40.8
-15.2 %
34.6
39.9
-17.0 %
33.1
