Noctua
Asus
NF-A14 FLX
210 g
145 g
900 U/min
250 U/min
1200 U/min
1800 U/min
68.0 CFM
62.5 CFM
115.5 m³/h
106.2 m³/h
1.51 mmH2O
3.07 mmH2O
19.2 dBA
22.5 dBA
Beige
Braun
Braun
4.6 V
4.2 V
381 U/min
409 U/min
469 U/min
419 U/min
208 U/min
129 U/min
1199 U/min
1778 U/min
308 U/min
53.5 CFM
+123.4 %
23.9 CFM
33.0 CFM
+76.2 %
18.7 CFM
31.7 CFM
+71.4 %
18.5 CFM
30.1 CFM
+70.2 %
17.7 CFM
90.9 m³/h
+123.3 %
40.7 m³/h
56.0 m³/h
+76.1 %
31.8 m³/h
53.8 m³/h
+71.3 %
31.4 m³/h
51.2 m³/h
+70.1 %
30.1 m³/h
0.91 mmH2O
+0.9 %
0.92 mmH2O
0.91 mmH2O
+0.9 %
0.92 mmH2O
+63.2 %
0.82 mmH2O
0.30 mmH2O
+137.9 %
0.09
0.09
0.09
0.09
+60.0 %
0.03 hPa
+133.3 %
34.2
-1.2 %
34.6
42.6
-8.7 %
38.9
40.8
-5.9 %
38.4
39.9
-3.8 %
38.4
