Noctua
Blacknoise
NF-A14 FLX
NB-eLoop X PWM B12xP ARGB
210 g
120 g
900 U/min
400 U/min
1200 U/min
68.0 CFM
77.9 CFM
115.5 m³/h
132.4 m³/h
1.51 mmH2O
3.02 mmH2O
19.2 dBA
28.4 dBA
Beige
Braun
Grau
Braun
4.6 V
3.4 V
4.2 V
381 U/min
294 U/min
469 U/min
138 U/min
1199 U/min
2002 U/min
53.5 CFM
+31.9 %
40.5 CFM
33.0 CFM
+32.4 %
24.9 CFM
31.7 CFM
+37.6 %
23.0 CFM
30.1 CFM
+43.4 %
21.0 CFM
90.9 m³/h
+31.9 %
68.9 m³/h
56.0 m³/h
+32.4 %
42.3 m³/h
53.8 m³/h
+37.6 %
39.1 m³/h
51.2 m³/h
+43.4 %
35.7 m³/h
0.91 mmH2O
+57.1 %
1.43 mmH2O
0.91 mmH2O
+12.3 %
+22.0 %
0.30 mmH2O
+66.7 %
0.09 hPa
+55.6 %
0.14 hPa
0.09 hPa
+12.5 %
+20.0 %
0.03 hPa
+66.7 %
34.2
-0.6 %
34.4
42.6
-14.3 %
36.5
40.8
-12.0 %
35.9
39.9
-9.5 %
36.1
