Noctua
Alphacool
NF-A14 FLX
Rise Aurora
210 g
180 g
900 U/min
1200 U/min
2500 U/min
68.0 CFM
70.0 CFM
115.5 m³/h
118.9 m³/h
1.51 mmH2O
3.17 mmH2O
19.2 dBA
31.5 dBA
Beige
Braun
Braun
4.6 V
3.0 V
4.2 V
2.9 V
381 U/min
862 U/min
469 U/min
874 U/min
339 U/min
181 U/min
1199 U/min
2775 U/min
1045 U/min
53.5 CFM
+84.4 %
29.0 CFM
33.0 CFM
+35.0 %
24.4 CFM
31.7 CFM
+34.9 %
23.5 CFM
30.1 CFM
+36.5 %
22.1 CFM
90.9 m³/h
+84.4 %
49.3 m³/h
56.0 m³/h
+34.9 %
41.5 m³/h
53.8 m³/h
+34.8 %
39.9 m³/h
51.2 m³/h
+36.5 %
37.5 m³/h
0.91 mmH2O
+48.7 %
0.91 mmH2O
+78.5 %
0.51 mmH2O
+22.6 %
0.41 mmH2O
0.30 mmH2O
+36.0 %
0.41 mmH2O
0.09 hPa
+50.0 %
0.09 hPa
+80.0 %
+25.0 %
0.03 hPa
+33.3 %
34.2
-17.8 %
41.6
42.6
-3.8 %
41
40.8
-4.2 %
39.1
39.9
-1.5 %
40.5
