Noctua
Lian Li
NF-A14 FLX
UNI FAN SL120 ARGB
210 g
232 g
900 U/min
800 U/min
1200 U/min
1900 U/min
68.0 CFM
58.5 CFM
115.5 m³/h
99.5 m³/h
1.51 mmH2O
1.67 mmH2O
19.2 dBA
31.0 dBA
Beige
Braun
Silber
Braun
4.6 V
4.2 V
2.4 V
381 U/min
412 U/min
469 U/min
98 U/min
1199 U/min
1828 U/min
53.5 CFM
+130.2 %
23.2 CFM
33.0 CFM
+86.1 %
17.7 CFM
31.7 CFM
+100.0 %
15.8 CFM
30.1 CFM
+97.0 %
15.3 CFM
90.9 m³/h
+130.1 %
39.5 m³/h
56.0 m³/h
+86.0 %
30.1 m³/h
53.8 m³/h
+100.0 %
26.9 m³/h
51.2 m³/h
+96.9 %
26.0 m³/h
0.91 mmH2O
+127.5 %
0.40 mmH2O
0.91 mmH2O
+127.5 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
0.30 mmH2O
+33.3 %
0.40 mmH2O
0.09 hPa
+125.0 %
0.09 hPa
+125.0 %
+25.0 %
0.03 hPa
+33.3 %
34.2
-11.9 %
38.8
42.6
-13.8 %
36.7
40.8
-11.5 %
36.1
39.9
-13.3 %
34.6
