Noctua
Corsair
NF-A14 FLX
LL140 RGB
210 g
210 g
900 U/min
600 U/min
1200 U/min
1300 U/min
68.0 CFM
51.5 CFM
115.5 m³/h
87.5 m³/h
1.51 mmH2O
1.52 mmH2O
19.2 dBA
25.0 dBA
Beige
Braun
Braun
Halbtransparent
4.6 V
4.2 V
2.9 V
381 U/min
226 U/min
469 U/min
378 U/min
1199 U/min
1319 U/min
53.5 CFM
+18.8 %
45.0 CFM
33.0 CFM
+16.2 %
28.4 CFM
31.7 CFM
+29.3 %
24.5 CFM
30.1 CFM
+14.0 %
26.4 CFM
90.9 m³/h
+18.8 %
76.5 m³/h
56.0 m³/h
+16.2 %
48.2 m³/h
53.8 m³/h
+29.3 %
41.6 m³/h
51.2 m³/h
+14.0 %
44.9 m³/h
0.91 mmH2O
+51.7 %
0.60 mmH2O
0.91 mmH2O
+82.0 %
0.5
0.5
0.30 mmH2O
+103.3 %
0.09 hPa
+50.0 %
0.09 hPa
+80.0 %
0.05
0.05
0.03 hPa
+100.0 %
34.2
-3.1 %
35.3
42.6
-13.4 %
36.9
40.8
-16.7 %
34
39.9
-12.8 %
34.8
