Noctua
Blacknoise
NF-A14 FLX
B14x-P-BL PWM ARGB
210 g
202 g
900 U/min
1200 U/min
1500 U/min
0.5 W
2.9 W
68.0 CFM
110.0 CFM
115.5 m³/h
186.0 m³/h
1.51 mmH2O
2.30 mmH2O
19.2 dBA
29.6 dBA
Beige
Braun
Braun
4.6 V
4.3 V
4.2 V
381 U/min
335 U/min
469 U/min
154 U/min
1199 U/min
1487 U/min
53.5 CFM
+12.7 %
60.3 CFM
33.0 CFM
+0.9 %
33.2 CFM
31.7 CFM
+2.0 %
32.3 CFM
30.1 CFM
+10.3 %
33.2 CFM
90.9 m³/h
+12.7 %
102.4 m³/h
56.0 m³/h
+0.9 %
56.5 m³/h
53.8 m³/h
+2.0 %
54.9 m³/h
51.2 m³/h
+10.4 %
56.5 m³/h
0.91 mmH2O
+45.1 %
1.32 mmH2O
0.91 mmH2O
+45.1 %
1.32 mmH2O
+102.0 %
1.01 mmH2O
0.30 mmH2O
+306.7 %
1.22 mmH2O
0.09 hPa
+44.4 %
0.13 hPa
0.09 hPa
+44.4 %
0.13 hPa
+100.0 %
0.03 hPa
+300.0 %
0.12 hPa
34.2
-1.5 %
33.7
42.6
-12.2 %
37.4
40.8
-10.3 %
36.6
39.9
-9.8 %
36
