Thermaltake
Arctic
P12 PWM PST RGB 0dB
212 g
159 g
500 U/min
58.4 CFM
48.8 CFM
99.1 m³/h
82.9 m³/h
2.41 mmH2O
1.85 mmH2O
22.3 dBA
Grau
Grau
Halbtransparent
4.0 V
2.9 V
391 U/min
380 U/min
413 U/min
532 U/min
1950 U/min
1985 U/min
33.2 CFM
+3.3 %
32.1 CFM
25.2 CFM
+5.2 %
23.9 CFM
24.5 CFM
+6.4 %
23.0 CFM
20.8 CFM
+6.0 %
22.1 CFM
56.4 m³/h
+3.3 %
54.6 m³/h
42.8 m³/h
+5.2 %
40.7 m³/h
41.6 m³/h
+6.4 %
39.1 m³/h
35.4 m³/h
+6.0 %
37.5 m³/h
1.84 mmH2O
+127.2 %
+32.8 %
+22.0 %
0.40 mmH2O
+52.5 %
0.18 hPa
+125.5 %
+32.4 %
+22.4 %
+53.0 %
37.4
-9.6 %
33.8
36.5
-13.4 %
31.6
36
-9.2 %
32.7
36.2
-11.3 %
32.1
