Thermaltake
Arctic
P12 PWM
212 g
139 g
500 U/min
200 U/min
1800 U/min
58.4 CFM
56.3 CFM
99.1 m³/h
2.41 mmH2O
2.20 mmH2O
22.3 dBA
Grau
Silber
3.0 V
391 U/min
207 U/min
413 U/min
547 U/min
1950 U/min
1748 U/min
33.2 CFM
+1.1 %
33.5 CFM
25.2 CFM
+8.4 %
23.2 CFM
24.5 CFM
+6.4 %
23.0 CFM
20.8 CFM
+3.4 %
21.5 CFM
56.4 m³/h
+1.1 %
57.0 m³/h
42.8 m³/h
+8.3 %
39.5 m³/h
41.6 m³/h
+6.4 %
39.1 m³/h
35.4 m³/h
+3.4 %
36.6 m³/h
1.84 mmH2O
+268.0 %
+32.8 %
0.5
0.5
0.40 mmH2O
+52.5 %
0.18 hPa
+260.9 %
+32.4 %
+2.0 %
+53.0 %
37.4
-1.9 %
36.7
36.5
-4.9 %
34.7
36
-3.6 %
34.7
36.2
-5.0 %
34.4
