Thermaltake
Fractal
Prisma AL-12PWM
212 g
167 g
500 U/min
500 U/min
1.9 W
58.4 CFM
85.7 CFM
99.1 m³/h
145.7 m³/h
2.41 mmH2O
2.80 mmH2O
22.3 dBA
32.0 dBA
Grau
4.5 V
3.8 V
391 U/min
443 U/min
413 U/min
269 U/min
1950 U/min
2001 U/min
550 U/min
33.2 CFM
+5.0 %
31.6 CFM
25.2 CFM
+21.6 %
20.7 CFM
24.5 CFM
+17.5 %
20.8 CFM
20.8 CFM
+5.4 %
19.8 CFM
56.4 m³/h
+5.0 %
53.7 m³/h
42.8 m³/h
+21.6 %
35.2 m³/h
41.6 m³/h
+17.5 %
35.4 m³/h
35.4 m³/h
+5.3 %
33.6 m³/h
1.84 mmH2O
+127.2 %
+14.1 %
+42.0 %
0.40 mmH2O
+52.5 %
0.18 hPa
+125.5 %
+13.5 %
+42.8 %
+53.0 %
37.4
-5.1 %
35.5
36.5
-7.9 %
33.6
36
-11.4 %
31.9
36.2
-21.0 %
28.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
