Thermaltake
Light Wings PWM
212 g
205 g
500 U/min
100 U/min
1700 U/min
0.8 W
4.6 W
58.4 CFM
41.5 CFM
99.1 m³/h
70.5 m³/h
2.41 mmH2O
1.66 mmH2O
22.3 dBA
20.6 dBA
Grau
391 U/min
369 U/min
413 U/min
350 U/min
1950 U/min
1680 U/min
134 U/min
33.2 CFM
+1.8 %
33.8 CFM
25.2 CFM
+26.6 %
19.9 CFM
24.5 CFM
+26.1 %
19.4 CFM
20.8 CFM
+12.7 %
18.5 CFM
56.4 m³/h
+1.8 %
57.4 m³/h
42.8 m³/h
+26.6 %
33.8 m³/h
41.6 m³/h
+26.0 %
33.0 m³/h
35.4 m³/h
+12.7 %
31.4 m³/h
1.84 mmH2O
+159.2 %
+62.0 %
0.5
0.5
0.40 mmH2O
+52.5 %
0.18 hPa
+157.8 %
+58.9 %
+2.0 %
+53.0 %
37.4
-21.1 %
29.5
36.5
-18.9 %
29.6
36
-12.5 %
31.5
36.2
-10.5 %
32.4
  • 350
  • 550
  • 750
  • 950
  • 1150
  • 1350
  • 1550
