Thermaltake
Alpenföhn
Wing Boost 3
212 g
122 g
500 U/min
400 U/min
1050 U/min
58.4 CFM
60.6 CFM
99.1 m³/h
103.0 m³/h
2.41 mmH2O
22.3 dBA
22.0 dBA
Grau
4.7 V
2.0 V
391 U/min
443 U/min
413 U/min
174 U/min
1950 U/min
1075 U/min
477 U/min
33.2 CFM
+48.4 %
49.3 CFM
25.2 CFM
+7.3 %
23.5 CFM
24.5 CFM
+4.2 %
23.5 CFM
20.8 CFM
+0.8 %
20.7 CFM
56.4 m³/h
+48.4 %
83.7 m³/h
42.8 m³/h
+7.3 %
39.9 m³/h
41.6 m³/h
+4.2 %
39.9 m³/h
35.4 m³/h
+0.8 %
35.1 m³/h
1.84 mmH2O
+12.9 %
1.63 mmH2O
+32.8 %
0.5
0.5
0.4
0.4
0.18 hPa
+12.8 %
0.16 hPa
+32.4 %
+2.0 %
+2.0 %
37.4
-16.1 %
44.6
36.5
-22.8 %
47.3
36
-21.2 %
45.7
36.2
-16.4 %
43.3
