Thermaltake
Silent Wings 3
212 g
137 g
500 U/min
150 U/min
1450 U/min
58.4 CFM
50.5 CFM
99.1 m³/h
85.8 m³/h
2.41 mmH2O
1.79 mmH2O
22.3 dBA
16.4 dBA
Grau
4.1 V
3.9 V
391 U/min
413 U/min
206 U/min
244 U/min
1950 U/min
1411 U/min
33.2 CFM
+47.2 %
22.5 CFM
25.2 CFM
+26.6 %
19.9 CFM
24.5 CFM
+42.0 %
17.2 CFM
20.8 CFM
+24.2 %
16.8 CFM
56.4 m³/h
+47.2 %
38.3 m³/h
42.8 m³/h
+26.6 %
33.8 m³/h
41.6 m³/h
+42.0 %
29.3 m³/h
35.4 m³/h
+24.2 %
28.5 m³/h
1.84 mmH2O
+82.2 %
1.01 mmH2O
+14.1 %
+42.0 %
0.40 mmH2O
+25.0 %
0.18 hPa
+82.2 %
+14.1 %
+42.0 %
+25.0 %
37.4
-1.6 %
36.8
36.5
-12.7 %
41.8
36
-11.1 %
40.5
36.2
-10.8 %
40.6
