Cooling Practice Reviews
Twins? Thermal Grizzly Kryonaut Extreme vs. Kingpin Cooling KPx analyzed with scanning electron microscope and X-ray spectroscopy
Today we want to find out what is really in the two extremely expensive pastes and what philosophy is behind the respective mixture. And to spoil it a bit in advance: The biggest difference here is really only the color. Chic baby blue in the tube against a nice baby pink from the can and two prices reminiscent of certain products with the gold edge. But it’s like with certain high-speed tires in real life: They have their justification if the intended use fits. For everything else, it’s more wishful thinking and, of course, a bit of a marketing lesson. Even from my side, there is almost honest admiration, because you didn’t think of it yourself.
This time, the two pastes were de facto paid for by the donation box and I hope that I will not be accused of pure waste or misappropriation. But in the end, curiosity was too great to dissect the two precious substances thoroughly. But before we get started with the analysis, I want to get rid of a few little basics that are important to know when evaluating the two pastes.
Thermally conductive particles as a basis
Each paste relies on specific particles of a chemical compound with the lowest possible thermal resistance. There are many options here, up to and including diamond powder. However, they are also particles whose grain size plays a very important role in subsequent performance. On the one hand, there is the shape, which can be platelet-shaped, crystal-shaped or rather round. On the other hand, of course, the grain size also plays a very important role. And that’s where theory and practice already clash. Coarser grits offer lower thermal resistance, at least on paper, but also leave larger gaps between the particles and even the surface. This, in turn, also negatively affects the actual thermal conductivity of the entire mixture.
However, higher grit sizes usually make the coatings a bit too thick. Too fine grits, on the other hand, produce thinner layers under great pressure, but with a bit of bad luck make pastes too solid. Liquid, rather slurpy or a bit more viscous? With the grain size, you can control the consistency quite well in advance. It is clever to mix different grit sizes, i.e. anything between 1 and 2 µm and something larger up to approx. 5 µm. Then you have something from both worlds.
Different grain sizes and a much finer filler
Fillers
And how do you get the spaces between a corundum, for example, filled appropriately? For everything below 1 µm, a filler is used that is still as thermally conductive as possible and is much cheaper, often in the form of platelets. Especially the very fine grits of corundum, diamond and boron nitride are really expensive. The stuff has to be ground in a complex process, and that costs money. Therefore, many set the cut at around 1 to 1.5 µm and fill up with additives. The cheapest are things like zinc oxide, which are also used on their own as a base for cheaper pastes.
Binder and mixture
To ensure that the paste does not reach the customer as dust, various binders are used, which on the one hand guarantee the final consistency of the paste and on the other hand represent one of the most important secrets when it comes to long-term durability (“reliability”) and performance in certain temperature windows. The pastes tested today can also be used for sub-zero applications, which of course poses different challenges for the binder than for a “normal” consumer paste.
The silicone oils (linear polysiloxanes) that are almost always used are, from a purely chemical point of view, a middle ground between inorganic and organic chemistry. They have an inorganic framework (as in rocks and minerals) and contain certain organic residues. This positions them between silicates and plastics. The resulting properties are versatile and, above all, easily controllable. Unfortunately, these silicone oils are difficult to analyze with an EDX. Even if you can use a cryogenic table, you only get the chemical elements, but no information about the molecules themselves and their degree of crosslinking. If one of the readers would be able to: gladly times a feedback by PN in the forum, by Mail or also telephone (stands everything in the imprint).
Very important for the quality and shelf life of a paste as well as the congruent consistency of all batches is “conching”, i.e. the permanent and complete mixing of all ingredients until the ideal distribution of all ingredients is approximately achieved and maintained. The mass distribution will certainly never be perfect, but almost. But you know this from cocoa: if you don’t stir and shake constantly, the suspended solids sink back to the bottom over time and the paste dissolves. The only thing that helps is constant stirring and agitation. If you don’t do this or do it inadequately, you will have a different result for each batch and the pastes will no longer be the same. Especially with cheaper fillers there is really danger ahead, because you can make even the best paste almost useless by such carelessness.
Derfnam
7,517 Kommentare 2,032 Likes
Rasterfahndung, Mahn. Und ein Joint Venture.
Gregor Kacknoob
536 Kommentare 449 Likes
Die perfekte Morgenlektüre zum wachwerden. Sehr spannendes Thema. Wie wohl eine Diamantpaste in einem Vergleichstest abschneiden würde :unsure:
Kaum besser. Je dünner man so eine Paste hinbekommt, umso geringer der Wärmewiderstand. Es hängt auch Vieles vom IHS und dess Oberfläche ab, also nicht nur von einer möglichen Wölbung.
P
Phoenixxl
160 Kommentare 124 Likes
Ich würde Thriller Grizzly kaufen, wenn es eine von beiden sein muss. Roman ist das ja dabei und der engagiert sich schon sehr für die Hardware Community.
Und auch wenn es bei HBBot gerade ein Skandälchen gab, hat er es von seiner Seite wieder vorbildlich "gemanaged".
Auch das Thema Spannungswandler-Temperaturen auf Mainboards war etwas, dass glaube ich von ihm auf die Agenda der Mainboard-Hersteller gesetzt wurde.
Dabei möchte ich gar nicht sagen, dass Igor nicht hinter den Kulissen nicht auch so wirkt.
Antwort 4 Likes
onyman
244 Kommentare 128 Likes
Ich würde es begrüßen, wenn bei REM Bildern IMMER ein µ-Balken im oder am Bild ist. Die Vergrößerungsangaben lassen keine Quervergleiche zu.
PS: Die REM Bilder auf den Seiten 5 und 6 sind übrigens gleich.
Ocastiâ
108 Kommentare 50 Likes
Sehr cool, obwohl mich jetzt natürlich auch alle anderen Pasten interessieren, das zeug von Noctua soll ja sehr gut sein.
Irgendwie fühle ich mich bei den Sportreifen angesprochen, immerhin habe ich Michelin Pilot Sport 4 auf meinem 132kw Diesel... und vor Kryonaut extreme für meinen nächsten Rechner zu verwenden.
Naja besser als Techart-Spoiler und RGB Kirmes.
Annatasta(tur)
374 Kommentare 133 Likes
Also ich glaube, rot leitet die Wärme besser! :p :ROFLMAO:
Ocastiâ
Rot leitet die Wärme schneller!
Blau bringt glück.
Zumindest wenn man den 40k Orks glaubt.
Annatasta(tur)
Jetzt ist nur noch die Frage, ob man eher Glück bei der Kühlermontage oder schnellere Wärmeabfuhr braucht. ;)
FfFCMAD
689 Kommentare 187 Likes
Die Unterschiede duerften Messbar sein, wenn auch nicht unbedingt bei zwei fast identischen Produkten. Die normale Kryonaut ist jedenfalls nicht ganz so gut unterwegs wie die Extreme bei der Waermeableitung. Wenn man das Geld hat, warum nicht? Speziell wnen man dann bei der 4090 oder dem Ryzen 7950x genau die ein oder 2 °C weniger auf der Uhr hat, die ein klein wenig mehr Boost bringen.
Steffdeff
777 Kommentare 729 Likes
Ich habe den Artikel mal zum Anlass genommen und meine Wärmeleitpaste erneuert. War sowieso längst fällig.
Arctic Silver runter und Phobya Nano Extreme drauf. Bringt 4 Kelvin (!) geringere Temperaturen beim CPU-Z Stresstest nach 20 Minuten. Neu gegen alt zu vergleichen ist aber auch ein wenig unfair. 🫣
Die zwei Pasten aus dem Artikel sind ohne Vergleichsmessung für mich jedoch schwer einzuschätzen. Preislich spielen sie aber ganz vorne mit. Wahrscheinlich so ein OC Ding.
Wo wir gerade beim Preis sind, der ist doch gar nicht so der große Posten im Rechner.
Außer man kauft, wie Igor, die Familienpackung.😉
Mir erschließt sich dieses Schminkdöschen als Verpackung jedoch nicht!
Die Klecks und Würstchen Fans (gehöre ich dazu) haben damit keine Freude.
Danke für den TIEFEN Einblick in die Materie!
FfFCMAD
Die Spritzen mit 2g sind die eigentlich teuren. Die kleine Dose mit 30g ist im Vergleich spottbillig.
Ghoster52
1,460 Kommentare 1,123 Likes
Wer braucht schon 30g ???
Die könnte ich dann noch den Urenkeln vererben, wenn es kein Haltbarkeitsdatum gibt. :ROFLMAO:
Das ist doch die Spachtelmasse für Overclocker. Die spateln das Zeug drauf, wie meine Kids die Leberwurst aufs Brot. :D
Antwort 5 Likes
Annatasta(tur)
Also mindestens 5 mm.🤣
FfFCMAD
Also eine 10g Spritze haelt bei mir zwei Jahre. Ich tausche die WLP oefter/ Modifiziere das System
Diese kleine Dose duerfte dann noch laenger halten, da luftdicht > Kaum zu erwarten das sie austrocknet :D
K
Karborund
48 Kommentare 50 Likes
Man könnte dann natürlich so eine Art Ying-Yang Wurst auftragen und auf beides hoffen.
ro///M3o
361 Kommentare 249 Likes
Danke für die Einblicke :cool: schön wäre noch die Alphacool ZubZero oder Apex zum Vergleich gewesen. Ich persönlich halte viel von den beiden :)
1,698 Kommentare 1,031 Likes
Die andere Frage die ich hier habe ist, welche Paste denn wie lange brauchbar die Hitze transferiert? Und dabei meine ich wie viele Monate man sich hier wenig oder keine Sorgen machen muss, daß die thermale Leitfähigkeit deutlich verloren geht. Oder sind hier Pads besser, und wenn ja, welche?
Und bei der ganzen "trocknet das Zeug schnell aus oder nicht" Frage kommen u.U. auch die Eigenschaften der silikonorganischen Bindemittel zum Tragen, denn Korund oder Zinkoxid bleiben von Zeit, Wärme und Sauerstoff eher unbeeindruckt.
Follow Igor:
