GPUs Latest news
We’re in for a treat: PowerColor presents the beautiful Hellhound Radeon RX 7800 XT Sakura
Spring has arrived and the first cherry blossoms are showing their leaves. Cherry blossom petals are particularly eye-catching due to their white-pink color and for this reason PowerColor has introduced a new Hellhound Radeon RX 7800 XT, which has been designed entirely in the sakura style.
Image Source: PowerColor
Sakura is a Japanese word and means cherry blossom. But enough of the good stuff, let’s move on to the technical details of the card and its appearance.
The card has a white and pink design, like a cherry blossom. It is equipped with AMD’s RDNA 3 architecture. On board is a 16 GB GDDR6 memory with a 256 bit bus interface. It has a speed of 19.5 Gbps and 3840 units are included as stream processors. The base clock of the new card is 2213MHz, while it offers 2520MHz in the overclocked state. That’s a whole 90 MHz more than the standard version, which only packs 2430 MHz.
The GPU has three DisplayPort 2.1 and one HDMI 2.1 display connection. The card is equipped with three 2.5 fans. There is also a nice LED mode that can be used. It is possible to use the fans in pink blossom, pure white or off mode. The off mode is for those who simply want to enjoy plain white color.
The interesting thing about the card is that it has a dual BIOS switch in which gamers can overclock the card or optimize it for silent operation. The card is available as a Limited Edition and a normal version. The Limited Edition version highlights the Sakura theme with unique packaging. Each card comes with a special GPU bracket to ensure that the setup not only looks exceptional, but is also safe. As such, PowerColor says this limited edition is set to become a collectible piece for enthusiasts who want to celebrate the fusion of high-end gaming performance with unparalleled beauty. Well.
By the way, the card is already available. The normal version costs around 579 euros, while the Limited Edition is listed at 599 euros.
Source: PowerColor
_
_roman_
96 Kommentare 22 Likes
Die Karte kommt etwas zu spät für mich. Die Karte ist mir zu schlicht. Etwas mutiger könnte der Hersteller sein, so wie Yeston:
-> Nein -> Folien usw. werde ich nicht kaufen und Hardware bekleben. Oder Spraycan benutzen.
Gewisse Hardware trifft schon meinen Nerv. Nur leider nicht erwerbbar
Kein AMD AM5, nicht erhhältlich: https://www.techpowerup.com/313012/...e-meow-series-graphics-cards-and-motherboards
ApolloX
1,687 Kommentare 955 Likes
Krass, MF hat sie schon. Aber so limited ist die dann doch eher nicht, oder?
Hoang Minh Le
