Aircooling Cooling Reviews Watercooling
Datasheet vs. Reality: Gelid GP-Extreme and EC360 Silver Review – Heat Conduction Pads with alleged 12 W/(m*K)
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
I’ve collected various pads in the meantime and evaluated lots of feedback. So today I am testing the desired thermal pads in the form of the GP-Extreme from Gelid and in addition the EC360 Silver from Jaden Technologies GmbH in the predefined upper class with 11 W/(m*K) , if one can really trust the manufacturer’s specifications. But can and may one do that? After today’s test I am not only smarter and you in the end of course too, because neither product really belongs there and one even belongs discontinued. But first things first…
Read more: Thermal Pad tested on the NVIDIA GeForce RTX 3080 – Four Reference Pads and brachial Temperature Drops of the hot GDDR6X down to 50%!
Gelid GP-Extreme Thermal Pad with 12 W/(m*K)
With 120 x 120 mm and 1 mm thickness, the pad with 0.28 Euro/ cm² is significantly cheaper than our 11 W/(m*K) reference pad with 0.32 Euro / cm² but also significantly more expensive than the reference pad with 7 W/(m*K), which costs 0.22 Euro / cm². The pad came from a well-stocked retailer, but was hard to come by in this family pack. So the usual 80 x 40 cm packs are not enough for a GeForce RTX 3080, so you need two of them. Then you are at about 18 euros street price. Let’s keep that in mind.
Unfortunately, the pads stick extremely and can also be difficult to separate from the film. Even just pulling off the film can cause it to tear, so you have to be very careful. A very thin spatula or the good old razor blade will help. The rest is not witchcraft and the pads also stick very well to the radiator bottom. The strength is about right, after all.
You should assume that a pad with a suitable thickness will also have enough contact, but consistency and surface texture are also decisive here, because the pad is quite compact and dense. After testing and disassembly, however, you can see only rough imprints, which have almost completely evened out again after 2-3 minutes. The pad was firm to the touch, but it’s just a little too hard to really nestle into all the crevices. This is already a big minus point, because it can be much better.
I have had countless pads in my hands, but this is one that you want to get off your fingers as quickly as possible. The handling is not quite simple, but solvable. It’s just the consistency that really raises questions. We’ll see how that cools in a moment.
The EC360, also bought anonymously, is much smaller and you also need two or an even larger pack. This costs 0,24 Euro/ cm² and is even cheaper than the Gelid pad. Price-wise, you’re slightly above the 7 reference pad. That reads sicherst once interesting, especially since I encountered the pad especially on YouTube constantly and was requested for a test because it was supposedly so good. Here too, of course, I want to know exactly, because one can claim a lot. So did the importer make a stroke of luck here and accidentally or deliberately get the right product from all the offers of the cheaper China suppliers?
Since the dates are on the back, I took a picture of the back as well. The pad with 50 x 50 mm is in principle sufficient for the memory modules and the PWM controller. However, the voltage transformers need significantly more, which is why I wrote about the larger pack. Purely haptically, the pad makes a much better impression than the one from Gelid. It also sticks easily, but is much softer and still more tear resistant. So the consistency comes more along the lines of what has proven to be useful over the years.
You can also see it after use, that a completely different picture emerges. You can even see the RAM labeling and the whole outline of the modules. The pad is slightly thicker than 1 mm and nestles very well even in the cracks and gaps. It also has a slightly lower density according to the data sheet. Still, the pad didn’t tear when I took it off. First of all, a big plus for that.
Before we get to the tests and the results, I would like to introduce you to the reference pads and the test system including the methodology. This is really important in order to be able to correctly classify the results and the assessment later on. We have already made a certain effort, which results in a good compromise between reproducibility and practicality.
RedF
4,888 Kommentare 2,718 Likes
Wie schnell ein Anbieter doch in meiner gunst sinken kann.
Habe noch etwas von dem Gelid Pad in der Bastelkiste, kann ich jetzt eigentlich nur in die Tonne kloppen.
T
Toacon
343 Kommentare 143 Likes
Einfach schön zu lesen :ROFLMAO:
Antwort 4 Likes
Guest
Ein typisches Beispiel dafür, warum das Tun von Igor so wichtig ist.
Danke dafür.
Antwort 9 Likes
Du kannst es durchaus verwenden, aber eben nur als 4 bis 5 W/(m*K) Pad. Immer noch besser als nichts, aber die Zahl ist echt gaga. Ich bin selbst heute noch angefressen. Ich habs mittlerweile auch mal von einem Bekannten mit eignem Pad proofen lassen, alle Replacements waren bei ihm auch besser.
Guest
Das mit EC360 wundert mich. Bin mit meinen Silver 0,5er und dem Ergebnis eigentlich zufrieden.
Das „Made in China“ ärgert mich etwas… hatte sie extra bei https://www.coolsierra.de/ bestellt bzw. rausgesucht weil ich dachte „Made in Germany“. Die Seite suggeriert mir irgendwie Produktion in Deutschland.
Wollte irgendwann meine 3090 mit neuen Pads ausstatten aber das wird mir zu teuer, zumal ich schon gute Temps beim Speicher hab.
(Ich weiß natürlich das mein Pc zu 99% Made in China ist aber das war mir vorher klar.)
Die gemessenen Werte sind durchaus ok und der Abstand zwischen den Pads halbiert sich auch mit deren Stärke.
Die dünneren 0.5er genau auseinanderzuhalten ist schon deutlich schwieriger... :)
Die EC360 tun für den Preis genau was sie sollen, nur ärgert mich die falsche Angabe auf der Packung. Das ist übrigens auch der einzige Kritikpunkt im Review.
Antwort 4 Likes
Casi030
11,923 Kommentare 2,339 Likes
Danke für den Test , gut das ich noch keine Pads bestellt habe.......
Hmmm die WLP mit 13,4 und auch das Graphite Pad interessiert mich dann doch schon sehr.CPU Testen ist da doch leichter für mich.
Guest
Na klar, beim Vergleich von 0,5ern würde das Feld bestimmt nochmal etwas zusammenrücken.
Trotzdem hätte ich die Silver 1,0 näher an der Spitze erwartet. ✌️
Komisch ist ja, dass alle Pads(auf www.coolsierra.de) laut Hertseller-Angabe mit dem ASTM D5470 getestet wurden aber dann ein Pad nicht die Werte einhält wie aufgedruckt. 1x testen und dann auf Lebenszeit darauf verweisen? 🙁
Martin Gut
7,956 Kommentare 3,712 Likes
Danke für die Tests Igor. Die zeigen wieder mal wie geduldig das Papier ist auf dem die technischen Daten aufgeschrieben sind. o_O
Um die Wärmeleitfähigkeit genau zu bestimmen müsst man ein Prüflabor mit definiertem Aufbau verwenden. Die eine Seite müsste auf eine definierte Temperatur geheizt und die andere gekühlt werden so dass man den Wärmedurchgang durch eine definierte Fläche messen könnte. Um etwas mehr auszusagen müsste man den Test dann mit mehr oder weniger stark gepressten Pads durchführen.
Dein Aufbau zeigt natürlich besser, wie sich so ein Pad in der praktischen Anwendung auf einer Grafikkarte schlägt. Dazu siehst du, wie brauchbar die Handhabung des Materials ist.
g
gadgetfreak
35 Kommentare 12 Likes
@Igor Wallossek Die Alphacool Eisschicht mit 11W/mk sind, vermutlich wegen deines Tests, überall ausverkauft. Dafür haben die jetzt "Alphacool Apex Soft Wärmeleitpad 11W/mk" gelistet und sogar direkt lieferbar. Wäre super wenn du denen vielleicht entlocken könntest wo der Unterschied zu den Eisschicht liegt! Vor allem weil Alphacool auf der Seite der Apex Soft mit deinem Award wirbt und nicht bei den Eisschicht!
Antwort 4 Likes
Ich habe es hier im Artikel bei den Links und der Referenzseite bereits geupdatet. Ich hatte im Test die als Apex bezeichneten Pads mit dem neuen Namen. Reingefallen bin ich, weil es noch die alte Verpackung mit Eisschicht war. Kleines Geheimnis am Rande: es sind de facto die gleichen Pads. Made in Japan. 😜
Antwort 7 Likes
T
Thermaltake
1 Kommentare 2 Likes
I don't speak german sorry for that I will write on English. I used to use Gelid pads but after seeing them dried up after short time period on VRMs I ditched them, plus they cost a lot for what they really worth. After Gelid I start to using EC360 pads, and they seems really OK for now. I used Silver, Gold, Premium ones. Hope to see how Gold and Premium perform on your test Igor.
Regards
Thermal.
B
Breiminator
6 Kommentare 4 Likes
Danke für den tollen Test. Bei mir sind gerade Gelid Extreme Pads aus Hong Kong angekommen, die werde ich dann doch nicht benutzen ^^
Nur eine Frage: Ich würde die Pads für Luft-Kühlung benutzen, du schreibst in deinen Tests, die 1mm sind optimal für Wasserkühlung. Kann ich die 1mm auch problemlos für Luft-Kühlung verwenden?
RedF
Die 1mm passen nur bei seiner Konfig von Garfikkarte und Kühler besonderst gut. Ob Luft oder Wasser ist erstmal egal.
Smartengine
147 Kommentare 135 Likes
Habt ihr auch so was wie einen lagzeittest geplant?
Bzgl. Austrocknung, Und verlust der Wärmeleitfähigkeit?
B
Breiminator
Ah ok. Ich werde den Standardkühler der Founders Edition weiterverwenden und hab diesbezüglich auch schonmal gelesen, dass 1mm zu dünn sind, da an manchen Stellen nicht genug Auflagedruck vorhanden ist. Mhm dann muss ich vllt doch die Gelid nehmen (hab sie in 1,5, 2 und 3 mm hier).
S
SaschaT
23 Kommentare 7 Likes
Igor hatte im ersten Vergleich mit den Referenz-Pads geschrieben, dass man die Pads auch aufeinander kleben kann, wenn ich mich richtig erinnere.
/edit: Er hatte es in den Kommentaren unter dem Artikel geschrieben.
Andy197
196 Kommentare 96 Likes
Ich kann auch etwas dazu sagen. Ich selbst hatte schon EC360 Silver und Gelid Pads, letztere aber als Ultimate mit 15W/mK.
BTW ich spreche hier von einer Mining Karte. Lüftergeschwindigkeit immer gleich. Raumtemperatur ungefähr die gleiche +-3°C oder so.
Die EC360 waren von der Temperatur gleich wie die Gelid (15W) nur hatten die EC einen gigantischen unterschied: Nach 30 Tagen ist die VRAM Temperatur über 10°C gestiegen! Das spiel hab ich 2mal mitgemacht und jedesmal stieg die Temperatur an. Zum Schluss hab ich Gelid Ultimate verwendet und es gab keine Probleme. Auch nicht nach 2 Monaten.
PS: Die EC360 Silver Pads verlieren stark an Öl. Vielleicht liegt es daran, dass sich das Silikonöl unter das Pad verflüchtigt und absetzt. Silikon ist ja nicht der beste Wärmeleiter...
Ob es durch das Mining verursacht war, weis ich nicht. Jedoch lag alles innerhalb der Spezifikation. Nur eben nahezu 24/7. Gelegentliches Zocken war auch dabei^^
Mich stört bei den Wärmeleitpads von Alphacool nur der Preis so enorm. Ist verdammt viel Geld für "Brösel"
Wie jetzt?
61 Kommentare 48 Likes
Sehr schön wie hier wieder einmal mehr die Blender überführt werden. Aber bei mir hat sich jetzt eh´ Alphacool Eisschicht "eingebrannt". :p
So groß ist die ja nun auch nicht, oder?
Allen ein sonniges WE!
Follow Igor:
