Cooling Latest news
Hardness data for heat conducting pads – conversion from Shore 00 and Shore A to Shore D | Practice
We already explained that the hardness of pads is enormously important in the practical article “Rescuing a Gainward RTX 2080 Ti Phoenix GS – Replacing thermal pads correctly“. There I refer to the value defined as Shore A, which is based on a standardized measurement procedure. However, the fact is that there are different Shore measurements here, which are also subject to different procedures depending on the hardness. Depending on the pad supplier or OEM, you will then find mostly confusing information in the data sheets.
The problem is that a high Shore value actually also indicates a high hardness. In principle, this is also completely correct, but it only really works plausibly within a measurement procedure. For example, a pad from Arctic has a Shore A value of 25, which is still a very high 76 at Shore 00. If this information is missing from the Shore data, the information content is zero. In order to give you a rough orientation, I have selected a comparison table (SpanSet secutex) with the different Shore methods for you, which at least allows a rough reference point:
I will also continue to prefer to work with Shore A because it most closely encompasses the range of pads we use most often. Here I have the comparison values once in a separate table, which we also saw yesterday in the practice article:
I’d be grateful for any further advice or suggestions, so that I can perhaps publish a more in-depth article. However, I didn’t want to go into too much depth today, as the problem already seems to be quite complex for outsiders. The important thing is that with the help of both tables you can already classify each pad well. If the provider communicates these values at all. I also wouldn’t buy a pad without a shore value. Why this is really important has already been well explained in the article.
LurkingInShadows
1,398 Kommentare 592 Likes
u.U. könnte man noch ergänzen:
ABS: Kunststoff aus/für zB. 3D-Drucker
PP: Plastik-Blumentöpfe
RedF
5,113 Kommentare 2,928 Likes
Was noch halbwegs interessant ist, ist das es bei Shore werten keine Teilwerte gibt, also z.b. 42,5. Auch wenn die Mesgeräte das gerne anzeigen.
Shore A wird nach 15s messzeit abgelesen. Das zu messende Objekt muss midestens 6mm dick sein und sollte lange genug vor messung bei Raumpemperatur ( 23°C ) gelagert werden. Von 5 Messungen wird der Median genommen, die Messpunkte müssen "wert vergessen" mm aus ein ander sein.
So jetzt könnt ihr Shore A Messen :geek:
LurkingInShadows
6mm dick, da wirds beim Pad-nachmessen eng.... :)
Guest
Doch natürlich gibt es die, nur zur Orientierung in der Härtegradeinstufung nicht. Es gibt Nachkommastellen mit +/- Abweichung bei bestimmten Temperaturzutsänden.
RedF
Na zumindest waren keine nachkommastellen in der DIN/ISO vorgesehen. Ist alles auch schon wieder 6-7 Jahre her.
Messen kann man das natürlich.
Guest
Eigentlich schon, da die Messung einen Wert der Eindringtiefe über Zeit bei Aufwendung einer Kraft (Newton) ermittelt und die ist nicht immer 3mm (beispielhaft), zudem muss man das Material klimatisieren (Abweichungen im +/- Bereich sind erlaubt). Es gibt aber unterschiedliche Verfahren (A [12,5N +/- 0,5] und D [50N +/- 0,5) Temp +/- 2°C bei 23°C) und die Werte können gerundet sein um sie einem Härtegrad zuzuordnen. Die Shore reicht dabei von - bis (50 bis 70 beispielhaft Polymer), daher ist es nicht ganz so wichtig wenn man im Mittel liegt. Wollte es nur schreiben.:)
jamesblond23
10 Kommentare 0 Likes
Grüße aus den YouTube Kommentaren!
ro///M3o
378 Kommentare 275 Likes
Mit den Shore Werten hatte ich sehr viel zu tun, als ich noch aktiv im RC Touring Sport und Drift Sport unterwegs war (Reifen) und auch Viskositäten (Dämpfer Öle und Differential Fette) 😅
Aber schön zu sehen, dass solch Wissen weiter im PC Hobby und auch sonst weiter verwendet werden kann 😁 Danke für die Klasse Erklärung und Überblick.
Gan77
13 Kommentare 3 Likes
Der Artikel besagt - Arctic eine Shore-A-Wert von 25.
Auf der Website des Herstellers wird Härte angegeben: 50 Shore OO.
Auch gesehen - Härte: 25 Shore OO
10,843 Kommentare 20,543 Likes
25 Shore 00 sind sinnlos, das ist ja Pudding, auch 50 sind eher nicht realistisch. Ich denke mal, es sind 25 Shore A :D
LurkingInShadows
Ausm Wiki:
Material Shorewert Skala
Geleinlage eine Fahrradsattels 15–30 OO
Kaugummi 20 OO
Und in der Grafik ist auch erkennbar, dass Shore00 @ 55 etwa Shore A @ 10 entspricht...
RedF
Auf meiner Packung Arctic Thermal Pad APT2560 steht tatsächlich auch 25 Shore 00. Aber ich kann versichern das das keine 25 Shore 00 sind.
RedF
War mit etwas Arctic pad bei meinen Kollegen aus dem Physik Labor und habe die Shore A gemessen. Musste Stapeln und auf RT habe ich es auch nicht aufwärmen lasen. Habe eine Shore von 27 gemessen. Also Shore A 25 passt.
Als Füllstoff ist ca. 25% Alu 13% Zink und 6% Silizium drinnen ( XRF )
Edit: Das polymer schein ein Silikon zu sein, somit sind die ergebnisse zum Füllstoff warscheinlich mist ( zumindest die prozente).
ianann
338 Kommentare 235 Likes
Alphacool gibt die Rise Ultra Soft auch mit 25 00 an. Von Der Konsistenz her sind die zwar etwas weicher als die Arctic würde ich sagen, aber keine Welten. Ist ja schön wenn es internationale Einheiten gibt, sie aber offenbar nicht sauber genutzt werden. :D
Follow Igor:
