Reviews Server & Services Storage Storage drives
Ugreen NASync DXP6800 Pro NAS review – Even bigger, but what about the software?
It has now been almost 3 months since we took a look at the NAS products of an unexpected new competitor on the market. So it’s a good time to take another look at UGOS and hopefully present the improvements that have appeared in the meantime. And since the 6-bay version is now also available, we’ll start with this one.
If you are more interested in the smaller versions, you can take a look here:
You can read the updated section on the software here.
The box has dimensions that I had trouble fitting into my photo box. But it does look nice, you have to give Ugreen that much. It could certainly look good on the shelves of various technology stores in the future, if I mentally put the rather plain brown boxes from Synology, for example, next to it.
One layer deeper, we are greeted by extensive transport protection made of foam padding.
And in the box with matching labeling we find the accessories, which include a power cable, two network cables, screws and tools.
There are also two “keys” for the drive bays and the two extremely thick thermal pads we are already familiar with.
Specifications
There is still no real product page for each individual member of the NASync series, so here is the general overview for now. However, Ugreen now provides a comparison page with the different variants.
echolot
1,150 Kommentare 901 Likes
Prima, dass Du Dich dem 6bay auch mal angenommen hast. Mittlerweile läuft das 4800plus auch bei mir. Hardware zum Kickstarterpreis unschlagbar. Habe mir nach einmonatigem Test aber Unraid installiert, da es für den Laien einfach besser und auch ausgereifter ist. Geräusche sind mir egal. Das Teil steht im Technikraum und da stört es niemanden. Mittlerweile laufen Fileserver, easybackup und Nextcloud ohne Probleme.
1,770 Kommentare 1,107 Likes
Allerdings sind die 4800 und jetzt auch die 6800 dann immer noch ein Fall von Hardware Hui - Software Pfui oder zumindest Software na ja. Wäre dann besser, wenn Ugreen sich hier entweder noch mehr um ihre Software gekümmert hätte, oder ihre NAS gleich mit Unraid oder ähnlichem gebündelt anzubieten. Der von @Tim Kutzner auch erwähnte lärmende Lüfter im Netzteil ist unschön, da eben nicht jeder einen Technikraum/Keller oder ähnliches hat, wo man den kleinen Radaubruder unterbringen kann. Und bei lärmenden Lüftern klingeln bei mir gleich die Alarmglocken, denn sowas deutet auf Lagerverschleiß und frühen Ausfall hin.
d
drakrochma
16 Kommentare 8 Likes
Hab das 6800 pro noch uneingerichtet daheim stehen.
68tb HDD und 8 TB SSD hab ich verbaut, RAM getauscht gegen 32 GB, aber ans einrichten hab ich mich noch nicht getraut/keine Zeit gehabt.
Hat jemand Erfahrung mit dem Wechsel der Lüfter?
echolot
Lüfter hab ich gegen eine Arctic getauscht. Beim 6bay sind es 90er Lüfter. So richtig Auswahl gibt es da nicht. Wenn Du nicht glücklich wirst mit der Software, dann probiers mit Truenas Scale oder Unraid. Man braucht da nichts ausbauen. Bildschirm anschließen. Beim Booten strg+F12 drücken um ins BIOS zu gelangen. Watchdog ausschalten und Bootdisk ändern bzw. Boot Nvme disablen. Den Rest findet man auf Youtube.
c
cunhell
569 Kommentare 543 Likes
"Ich sehe keinen Grund, wieso eine SSD nicht Read und Write übernehmen können sollte."
Wenn zwei SSDs im Raid1 laufen kann eine sterben und trotzdem gehen die im Write-Cache liegenden Daten nicht verloren.
Hat man nur eine und die SSDs stirbt, hat man im Write-Cache-Modus zwangsläufig Datenverlust, da die Daten ja noch nicht auf den HDDs liegen
Als Read-Cache ist es egal, da die Daten ja weiterhin auf den HDDs vorliegen.
Macht also durchaus Sinn. ;-)
Cunhell
Antwort 5 Likes
d
drakrochma
Unraid hab ich noch eine Lizenz daheim liegen, wäre dann Plan b :)
Und zum installieren gibt es keinen Stress mehr, dass man nur was anderes installieren kann, wenn die bisherige System-SSD nicht gefunden wird?
Das waren ja mal gute Nachrichten. (y)
L
LGTT
27 Kommentare 13 Likes
Von der Hardware immer wieder gut. Die Software scheint sich ja auch langsam zu entwickeln. Wenn das so weitergeht muss mein NAS aber noch 3 oder 4 Jahre durchhalten.
Ich habe es leider versäumt, mir noch rechtzeitig eine unbefristete Unraid Lizenz zu besorgen, bevor die ihr Lizenzmodell umgestellt haben. Wenn man jetzt Unraid einsetzen will und (wie zB ich) Abomodelle vermeidet wo es nur geht, ist die Alternative entweder eine jetzt ziemlich teure unbefristete Lizenz zu kaufen oder was anderes zu finden. Und gerade für ein NAS ist ein OS, das man ohne großes Gefrickel einrichten kann und auch zuverlässig und einigermaßen sicher ist eben unabdingbar. Auch deshalb ist es richtig schade, das Ugreens OS bis heute nicht ausgereift ist.
@Tim Kutzner : hatte mein Danke für den Test und den ausführlichen Artikel in meinem ersten Beitrag vergessen - hiermit nachgeholt!
Und die bis jetzt ausgebliebene Antwort von Ugreen auf Deine Anfrage ("Ich habe Ugreen am 17.07.2024 um Stellungnahme gebeten, bisher aber keine Antwort erhalten") gibt auch zu denken! Wenn eine Firma selbst einem Reviewer seit über 2 Wochen keine Antwort auf eine Frage schickt, wie wird sie dann mit einem normalen Kunden umgehen? Ich glaube, daß sich auch hier zeigt, daß Ugreen im NAS Bereich eben doch ein bisschen zu "Green" ist. Bestärkt meinen Eindruck: im wesentlichen gute Hardware fürs Geld, aber eher was für Leute, die sowieso ihr bevorzugtes OS darauf installieren wollen und denen es auch nichts ausmacht, hier selbst bei der Hardware nachbessern zu müssen, wie zB @echolot es gemacht hat.
Tim Kutzner
874 Kommentare 714 Likes
Die 4800 Plus hatte das Problem auch nicht, die hat ja ein externes, lüfterloses Netzteil :D
Tim Kutzner
Bei Reddit gibts diverse Berichte und auch Anleitungen:
Tim Kutzner
Die Gehäuselüfter sind aber nicht auffällig, die kann man ruhig so lassen :)
Hyourinmaru
1 Kommentare 0 Likes
Gibt im Forum auf Computerbase jemanden, der die beiden Gehäuselüfter und den Netzteillüfter gegen Lüfter von Noctua getauscht hat. Soll wohl viel besser sein mit der Lautstärke.
Weiß jemand zufällig, wann Ugreen vorhat, die Geräte auf dem Markt einzuführen? Auf Nachfrage bei Linuxnews Mitte Juli, die ja auch nen Test gemacht haben, hieß es, dass der Marktstart auf Anfang August verschoben wurde, da Ende Juli nochmal ein großes Softwareupdate für UGOS ausgerollt würde. Inzwischen haben wir Mitte August und noch immer lässt sich von den NAS nichts am Horizont erkennen, weder in deren Webshop noch auf Amazon.
M
Manta
1 Kommentare 1 Likes
Der UGreen-Support hatte mir vor kurzem auf Anfrage mitgeteilt, dass die NAS ab dem 20. August auf deren Webseite verfügbar sein sollen.
A
Art
55 Kommentare 10 Likes
einen Idle Verbrauch von 24 Watt ohne HDDs finde ich unangemessen hoch - woran liegt dies?
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
