CPU Motherboard Reviews
Power consumption and load peaks: Checking the Intel performance profiles Baseline, Performance, Extreme and Insane in Cinebench CB23
There’s been a lot of talk lately about Intel’s potential degradation issues with the high-end 13th and 14th generation CPUs, so I thought I’d use Powenetics and test an i9-13900K under three different power settings: Standard, Performance and Extreme. Then there’s the “Insane” profile, where you set the 4096 watts as an infinity factor and leave the CPU to its own self-protection.
Since I have a (self-designed and manufactured) high-end solution (Powenetics v2) that allows me to perform precise CPU power measurements, I decided to use it for exactly this purpose. These are my settings in detail:
Intel Core i9-13900K (14900K) Basic setting (“Standard”) Performance Extreme Insane
Basic performance of the processor 125 125 125 125
PL1 125 125 250 4096
PL2 188 253 250 4096
Iccmax 249 307 511 511
Intel explicitly does not recommend the baseline power profile as it severely affects the performance of the CPU. It is recommended to implement the highest power profile that is compatible with each individual motherboard design. As you will see from my test results, the baseline profile does indeed affect performance in Cinebench, even though this is only about rendering. There will be a second article where Igor will run these profiles with real workstation applications in a very time-consuming way, with some very interesting nuances and performance differences. But I don’t want to get ahead of myself. Intel only sees the usual suspects such as CB23 and, of course, games. So let’s start today with CB23 and rendering.
Test system and methodology
Environment/laboratory Ambient temperature: 26°C ±1°C
Humidity: 40% ±4%RH
Motherboard Asus Prime Z690-A
CPU Intel 13900K
GPU NVIDIA 1070 Ti
NVMe XPG GAMMIX S50 Lite 1TB
MEMORY XPG Lancer DDR5 (2 x 16GB) 6000MHz
Power supply Seasonic Vertex 1200W
(Cybenetics Platinum)
CPU cooler Arctic Liquid Freezer III 420 A-RGB AIO (fan fully open)
Case DimasTech bench
I used a strong cooling solution to test how high the Intel CPU can run when all restrictions are lifted.
The load application is none other than the infamous Prime95 (Small FFTs) program, which puts a huge strain on the processor. To test the CPU’s performance under the different power profile settings, I use Cinebench R23. I also have the Powenetics system to continuously measure the CPU’s power consumption, which is much more accurate and faster than using a software solution like HWinfo.
1,698 Kommentare 1,031 Likes
Wobei ich mir bei den auch hier von Aris gemessenen Leistungsaufnahmen immer auch die Ströme vorstelle, die hier fließen müssen; es geht ja um mehrere hundert Ampere. Jetzt bin ich gespannt auf Igors Artikel, der ja Leistungsaufnahme in Watt und Compute Leistung in Anwendungen in Relation stellen wird.
echolot
1,118 Kommentare 875 Likes
Das ist krank!!! Bei 77 °C.
Antwort 4 Likes
K
Knoxxi
5 Kommentare 0 Likes
77 Grad bei einer AIO und bald 500 Watt. Stolze Leistung und die AIO kann bei Bedarf den Kaffee warm halten.
Siri, definiere Kotzgrenze. :D
ApolloX
1,687 Kommentare 955 Likes
Fazit, erster Satz: "Die Architektur bleibt gleich die geliche, falls sich jetzt fragt, warum ich eine CPU der 13. und nicht der 14."
Ich glaub, dem Artikel würde einmal Rechtschreibprüfung plus Korrekturlesen noch helfen.
Und die vier genannten Erkenntnisse sind halt trivial.
Nichts gegen die schon interessante Arbeit von Aris, aber seine Artikel bräuchten sprachlich und formal jedesmal etwas Hilfe.
konkretor
312 Kommentare 321 Likes
Endlich übertakten ohne fummeln zu müssen
Y
Yumiko
546 Kommentare 247 Likes
Wer übersetzt die denn?
Ich arbeite hier gerade an vier Dingen parallel, da war Aris' Artikel eines davon, damit Ihr heute was zu lesen habt. Korrekturvorschläge und Hinweise gern per PN, die Nörgelei nervt wirklich und läuft voll am Topic vorbei, sorry...
Aris ist im Übrigen Ingenieur mit mittlerweile vier Graduierungen (und einer Pilotenlizenz) und kein promovierter Kinderbuchautor ab wirtschaftlichen Abwegen. Auch wenn manches etwas hölzern klingt, nicht jeder ist der geborene IT-Lyriker :D
Antwort 13 Likes
s
samhayne
108 Kommentare 77 Likes
Ich finde ja, dass Hand und Fuss hat, was *beide* sagen.
Kinderbuchautor klingt nach müffeligen Twitter-Ecken.
c
cunhell
562 Kommentare 529 Likes
Bei aller Wertschätzung der geleisteten Arbeit. Nur ein kleiner Vorschlag. Ich finde es nicht zielführend in einem technischen Forum unterschwellige oder auch direkte Politikkritik mit sachlichen Fragen zum besprochenen Artikel zu vermischen. Sowas sollte man lassen. Dafür gibt es genügend andere Foren.
Das ist zumindest meine persönliche Meinung
Nichts für ungut.
Cunhell
B
Besterino
6,906 Kommentare 3,473 Likes
Glaub Igor hat einen schlechten Tag - zu wenig Schlaf bei zu viel Arbeit machen sowas mit einem.
In der Sache bin ich aber auch bei @ApolloX und @cunhell. Das Fazit galt so quasi auch schon bei Release. Interessant wäre, welche Settings genau denn nun eine zunächst unauffällig laufende CPU über die Zeit killen bzw. instabil werden lassen. Dummerweise kann man das nur schlecht oder nur mit völlig absurdem Aufwand austesten.
big-maec
916 Kommentare 541 Likes
Ich nicht, er nörgelt und macht selbst Rechtschreibfehler. Mir ist das aber eh egal ich kann Rechtschreibfehler ignorieren.
Nur mal am Rande:
Wer hier Politik-Kritik rein- und überinterpretiert, ist selbst schon in diesem Strudel der monochrom-zugespitzten Gehässigkeiten gefangen. Je dünner das Fell, umso dicker die Probleme. Das schrieb mein Lehrer 1976 mal in mein Hausaufgabenheft. Das gilt noch heute. ;)
Aris ist kein Lyriker, der seine Inhalte schönschreiben kann und muss, für ihn ist der Text eher nur das Mittel zum Zweck, um vom Machen mal schnell aufs Publizieren zu kommen. Wenn ich die nötige Zeit habe, schreibe ich ihn auch etwas um, aber gestern gings nicht. 13 Stunden an einem Sonntag sind eh schon Selbstkasteiung.
Antwort 5 Likes
c
cunhell
Mir geht es nur mittlerweile komplett auf den Senkel, dass egal welches Thema besprochen wird, es sich immer einer oder eine findet der in den ersten paar Postings Aussagen zur Politik oder Politikern anbringt.
Wenn ich mich in einem Hardwareforum bewege will ich Meinungen und Diskussionen zu dem besprochenen Hardwarethema lesen und keine Seitenhiebe auf Politik oder Politiker.
Ich gewinne ja schon fast den Eindruck, dass der neue KI: "Grünen-Bashing-Überleitungsgenerator" keine Satire mehr ist sondern Realität:
Man kann gerne seine Meinung zur politischen Landschaft haben, keine Frage, aber die muss man nicht überall einbauen.
Cunhell
Antwort 6 Likes
M
Mr.Inkognito
10 Kommentare 8 Likes
Beitrag entfernt.
Hier gab es kein pauschales Grünen-Bashing, sondern eine Spitze, wo es um die lyrische Kompetenz einer Fachperson ging. Das muss man einfach aushalten, denn es ist kein Bashing, sondern einfach eine Tatsache. Und es gilt für alle Politiker aller Parteien gleichermaßen, dass man nur das tun sollte, was man gelernt und wovon man Ahnung hat. Ich gehe ja auch nicht zum Blumenbinder, um mir den Blinddarm entfernen zu lassen :D
mVidia
4 Kommentare 2 Likes
Hallo erstmal an Alle,
ich lese die Tests und News zwar schon eine ganze Weile mit, hab es aber nun doch endlich geschafft, mich hier im Forum anzumelden :)
Mal eine kleine Frage an die Redaktion, da ich denke dass sich eventuell der Fehlerteufel eingeschlichen hat.
Müsste es beim "Extreme"-Preset nicht eigentlich 253 Watt für PL1 und PL2 und 400 Ampere bei Iccmax sein laut den Intel-Spezifikationen für die K-Modelle?
Großes Lob an dieser Stelle an Igor und die Redaktion für Eure sehr detaillierten und umfangreichen Tests & die unterhaltsamen und lehrreichen YouTube-Videos. Ihr seid spitze ;)(y)
L
Legalev
53 Kommentare 51 Likes
Absolut Offtopic und hat hier nichts zu suchen.
Deine Statistik wird schon seine Gründe haben.
Bitte den Beitrag löschen.
Danke
@Igor Wallossek : Stimme Dir weitgehend zu. Ich fand (und finde) Aris' Artikel und Reviews interessant, und nie missverständlich formuliert - und auf letzteres kommt es doch vor allem an.
Warum nur weitgehende Zustimmung? Weil (IMHO) das Schreiben von guten (!) Kinderbüchern alles andere als trivial ist😃. Wobei ich weiß, daß es Dir hier um das Schreiben fachfremder Beiträge ging, und das kann man Aris hier nun wirklich nicht vorwerfen - er kennt sich da sehr gut aus, und das kommt beim Lesen durch. Powenetics ist ja sein eigenes (von ihm entwickeltes) Tool.
Mir geht es darum, dass es wichtig ist, dass jemand vor allem weiß, worüber er schreibt. Über den Stil kann man gern diskutieren, aber wenn ich Zeit habe, dann glätte ich auch ein paar Dinge. Aber lieber so, als andersherum, mehr wollte ich mit meiner kurzen Spitze gar nicht sagen. Gut formulierter Unfug wird durch angewandte Wortgewandtheit leider auch nicht besser. Aber es liest sich angenehmer. Dass dann alle wieder über so ein kleines Stöckchen springen müssen und dazu noch richtig Anlauf holen, ist leider ein Zeichen der aktuellen Umstände, wo die Toleranzgrenze gegen null geht. Wer mangelnde Toleranz beklagt, sollte bitte auch selbst welche mitbringen. :)
Ich schreibe auch immer fehlerbehafteter, aber das hat leider gesundheitliche Gründe. Mit einem beginnenden Glaukom bin ich aktuell über den Tag mit Augentropfen gestraft und ich kann mich entscheiden, ob ich was richtig klar sehe oder ob ich den Druck senken will, damit es nicht schlimmer wird. Die OP ist irgendwann im Herbst, aber es gibt ja im Gesundheitswesen auch noch andere Probleme. Ganz ohne Grund sitze ich nicht vor einem 55"er :D
Dr. Aristeidis Bitziopoulos
Chief Test Engineer at Cybenetics LTD
Ph.D. in Wireless Sensor Networks
Bachelor in Computer Science and Electronics
Telecommunications Engineer Degree
