Audio/Peripherals Headsets Reviews
Turtle Beach Stealth 700 Gen 2 Review – Is the wireless headset for the Xbox also suitable for the PC? Yes, but…
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
To give our readers some distraction in these turbulent days, we have combined a review with a small self-test. What can a console headset do on a PC? Do console gamers have to settle for inferior equipment? We’re getting to the bottom of it!
Admittedly, the introduction is somewhat luridly worded, but in times of this overshadowing event, even the tech press has a pretty hard time. Catching readers’ attention and delivering a good article when you always have other things on your mind has presented me with an unexpected challenge. In order to still deliver an article of the usual quality and scope, I put the emotions aside and concentrate on the technical details and the impressions gained.
As the successor to the best-selling wireless headset for the Xbox One and Series X, the Stealth 700 Gen 2 takes on a tough legacy. Since the predecessor was so successful, they actually only made improvements in the details, for example, by doubling the battery life and now integrating the foldable microphone directly into the earphone’s casing.
In general, the black and silver Gen 2 version looks much more grown-up and not as playful as the predecessor with the typical Xbox green tint. Before we get to the technical details, there is of course the obligatory unboxing.
Unboxing
The outer box is in the typical Xbox design. Matt light gray with green applications meet the ravages of time, only a few technical details are listed. Apparently you don’t think the consoleros are as nerds as the PCers.
When you open the box, the device immediately smiles at you. ZERO plastic in the packaging, I find very commendable.
Besides the headset, only a charging cable and a small box with quick start guide and a sticker are in the box.
The metal-reinforced headband is covered with a kind of soft lacquer and has the Turtle Beach logo embossed on it.
From the bottom it is sufficiently soft padded. The cover is made of the same material as the ear pads and makes a robust impression.
All controls and the charging port are found on the left earpiece. Convenient: If you are connected to the Xbox or the Xbox Wireless Adapter and still connected to the smartphone via Bluetooth at the same time, you can adjust the volume of the game/movie/music and the chat/phone call separately.
The foldable microphone that can be retracted into the casing is also located on the left side.
The opening for the ears seems quite small at first glance, but is normal sized with a little over 4cm width and about 6cm height. Inside, the padding is covered only with a thin and very soft fabric that it should not press uncomfortably or even hurt even on larger ears.
I include more details on the adjustment mechanisms, etc., on page three, where the headset is also disassembled and the innards evaluated.
10,458 Kommentare 19,560 Likes
Was ist denn mit Euch los? Alle schon mit Headsets zugeballert? :D
Ghoster52
1,455 Kommentare 1,120 Likes
Die haben schon "Sharkoon Skiller SGH50" gekauft.... :ROFLMAO:
LëMurrrmel
181 Kommentare 143 Likes
Hab seit 3½ Jahren das Stealth 600 für die Playstation im Einsatz.
Die Verarbeitung ist ganz okay und entspricht dem Preissegment. Tragekomfort ist ziemlich gut - wenn man keine Brille trägt. Mit Brille fangen die Ohren nach etwa 2 bis 3 Stunden an leicht zu schmerzen. Hier ist mein Sennheiser HD650 aber auch nicht viel besser, aber insgesamt bequemer. Die Stoffbezüge zeigen nach 3.5 Jahren regelmäßiger Verwendung keine sichtbaren Verschleisserscheinungen.
Das Mikrofon ist zweckmäßig, zu Verständigungsproblemen im Sprachchat ist es bisher noch nicht gekommen. Mit dem unteren Lautstärkeregler kann man den Pegel des Mikrofon-Monitors einstellen (man hört sich einfach selber...) - diese Funktion ist tatsächlich sehr nützlich, da ich hiermit Umgebungsgeräusche identifizieren kann, welche die werten Mithörer stören könnten. Das macht sich vor allem in Online-Meetings positiv bemerkbar!
Der USB-Dongle funktioniert ohne Probleme an PC und PS4, die Reichweite geht mit 10m (inkl. 1 Trockenbauwand) auch in Ordnung.
Eine Sache nervt aber, der Auto-Shutdown. Mitten im Gespräch oder Spiel labert mich das Headset mit der Aussage "Auto Shutdown Enabled, Press Power to cancel" voll. Und schaltet sich keine 30 Sekunden später aus, wenn man nicht den Power-Knopf betätigt - was im Eifer des Gefechts nicht immer gelingt. Die Funktion lässt sich leider auch nicht deaktivieren oder justieren.
Achso, fast vergessen: Der Höreindruck. Geht so, ist ganz brauchbar. Sehr gut geeignet für Spiele und Kommunikation. Für Musik aber setz ich meine Sennheiser HD650 auf. Oder ich dreh mein Edifier S730D 2.1 System auf 🔊 :cool:
Wenn das Stealth 700 Gen2 ebenso gut verarbeitet und so lange haltbar ist wie das Stealth 600, kann man aber beruhigt zugreifen.
Guest
Bin zwar kein kein so großer Consolero, mit Headset schon gleich gar nicht bisher (und wohl auch in Zukunft nicht). Habe den Test aber trotzdem gelesen und für mich als unbrauchbar deklariert. Sieht ja nett aus, keine Frage, an der Verarbeitung gibt es auch nichts zu meckern.
Aber ich ärgere mich schon immer, wenn ich Konsolenport-Spiele in die Hand nehme. Da muss ich nicht auch noch ein Headset für die Konsole ans Laufen bringen.
Xbox-Controller ist zwar auch vorhanden, der tut aber einfach mit Blue Tooth, also kein Dongle nötig. Und die Features sind auch ganz nett, wenn man dafür Verwendung hat. Aber wenn ich dann am PC so rein gar nichts einstellen kann, weil nicht vorgesehen, ist das dann eben nichts für mich.
Und ja @Ghoster52 genau das hab ich gekauft, daher auch kein Bedarf mehr an HS ;). Suche eher nach einem würdigen Ersatz für den alten Sennheiser-KH. Das wird aber eine größere Geschichte, da der dann schon ein bisschen mit den Nuberts im WoZi mithalten muss. Und das wird nicht einfach, glaub ich. BTW: Kann der Sennheiser aber auch nicht.....
Ein 0815-Headset kann das erst recht nicht. Dieses hier getestete zählt sicher nicht dazu, die gute Verarbeitung kann sich sehen lassen. Soundtechnisch ist es aber auch nur begrenzt brauchbar. Und mit EQ rumfriemeln ist nicht so meins, das wird bei mir immer schlimmer, als es vorher war.
Ghoster52
Ich weiß jetzt nicht welches Modell Du hast und wie die Nuberts bei dir im WoZi "klingen"....
Hatte im Sommer im HF bei einer KH-Rundreise mitgemacht und war positiv überrascht / beeindruckt.
Testkandidat war ein "Hifiman HE-400SE" (Magnetostat) für ca. 169,-€, bis auf die zu harte Bügel-Konstruktion hatte ich nichts auszusetzen.
Wer die Klassiker (AKG K702, Beyer DT880 usw.) kennt und mag, könnte mit dem 400SE glücklich werden.
Man hat zwar null Isolation, dafür klingt der Sound viel freier und offener, ist aber bei KH eben immer Geschmackssache.
In ca. 10 Wochen darf ich den "Edition XS" testen, mal sehen ob die Größe eine Rolle spielt.... :LOL:
Alexander Brose
