Allgemein Case Reviews
THERMALTAKE The Tower 500 Review – flexible mid-size showcase with proper airflow and the necessary visibility
Disclaimer: The following article is mostly machine translated from the original German, and the translation has not been edited or checked for errors in-depth. Thank you for understanding!
After the Tower 900 for extensive custom loops and the Tower 100 for small ITX systems, Thermaltake is finally releasing the Tower 500 to serve everything in between. In the Tower 500, fat tower coolers or a small custom loop have room and are excellently put on show thanks to the three glass walls. Read our review to find out whether the case is more than just smoke and mirrors.
Unboxing
Without much talk, we go straight into the nitty-gritty. The case comes in a fancy outer box.
The unusual dimensions make the tower seem smaller than it really is.
The side panels can be “reversed”, which allows the viewing window and fan grille to swap positions (important for installing a radiator).
The entire rear is a huge opening!
The lid also consists practically only of a grid. Heat accumulation? No, thanks!
The grille insert can be opened by pressing it like a tank cap and can thus be removed very easily without tools. A great feature, but also definitely necessary due to the vertical motherboard layout.
The entire lid can then be removed from the casing with a firm pull.
Once the lid is gone, the side panels can easily be pulled out upwards as well. The fact that every single opening is equipped with a dust filter should already have been noticed from the pictures.
The back panel is hooked in at the bottom and fixed at the top with two Thumbscrews.
The inlay can also be removed, which makes mounting the components and hard drives much easier.
A view from above reveals the position of the motherboard I/O.
But this is far from the end of the dismantling process. The double bottom can also be removed in two parts.
Unfortunately, there is only room for two 120mm and one 240mm radiator, respectively. With 2-3cm more case width, a 360mm radiator would have been easy to fit.
Everything disassembled and ready for installation of the components.
Guest
Schöner Test @wuchzael
Ist zwar als "Air"-Flow-Gehäuse gedacht, könnte mir aber vorstellen, dass Leute, die gerne Wasser-Spiele veranstalten, nicht sehr begeistert sein.
Wenn ich so lese, was manche an Monster-Radiatoren einbauen, sehe ich da schwarz für diese Fraktion.
Aber einige nette Ideen vorhanden, kann man sicher nicht meckern. Vor allem das komplett zerlegen zu können hat schon was, wenn man große Hände hat.
Persönlich mag ich aber lieber die Standart-Gehäuse, da muss ich nicht zwingend um die Ecke denken ;)
Könnte in meinem (900er BeQuiet) auch das MB in dieser Richtung einbauen, was ich mir auch kurz überlegt hatte. Aber eben nur kurz.
RX480
1,887 Kommentare 879 Likes
Mit ner größeren Graka wäre das sogar Pflicht, weil sich sonst die Graka und Lüfter der AiO um die Frischluft aus dem Boden streiten.
und es wäre vor Allem auch günstig für die GPU-Temp.
btw.
Ich verstehe immer net, warum sich alle Leute Sorgen um den kleinen Wattverbraucher CPU machen aber den großen Wattverbraucher GPU
nur "irgendwie" rein basteln.
Gut, das Platz für 2x AiO´s vorhanden ist.
z.Bsp.
280er Eisbär (oben)+ 360er Eiswolf 2 + 2xLü. im Boden = 5x Intake + 2x Outtake
(EB+EW als gemeinsamer Loop; ob man im Boden noch nen 240er Radi reinsteckt, hängt vom angestrebten Powerlimit ab,
würde vermutlich keine extra Pumpe brauchen
Wer jetzt net gerade highFps-Gaming favorisiert wird ganz selten bei der CPU über 65...80W kommen.
Aber die Graka wird am Anschlag mit 200...250...300W+ betrieben. (in so ein teures Gehäuse sollte schon ne 6900 passen)
Bsp. Watts CPU+GPU beim Spielen:
Antwort 4 Likes
Xaero82
25 Kommentare 11 Likes
Vielen Dank für den lesenswerten Testbericht. Ich selbst besitze ein Tower 100 und vermisse die Möglichkeit eine 240/280 AIO einzubauen. Darüberhinaus bekommt mir die GPU etwas zu wenig Frischluft. Ansonsten bin ich mit der kleineren Variante sehr zufrieden.
Der Tower 500 wäre mir etwas zu groß. Für meine Zwecke wäre ein Mittelding aus Tower 100 und Tower 500 ideal.
FfFCMAD
689 Kommentare 187 Likes
Ich benutze die beiden Vorgaenger. Geile Teile. In dem Großen habe ich zwei Radiatoren drin, das rennt wie Sau
n
neroqx
3 Kommentare 2 Likes
Schöner Bericht und schönes Case!
Was ich noch vermisse sind Bilder von der Rückseite. Sowohl in der Galerie, als auch im Bericht ist nicht zu sehen wie das Case im fertigen Zustand von hinten aussieht und wie die Kabelführung verläuft.
garfield36
1,292 Kommentare 337 Likes
Ich habe mal meine Grafikkarte (MSI GeForce RTX 3090 Gaming X Trio) senkrecht in ein Gehäuse eingebaut. Empfehlenswert ist sowas nicht. Die Hotspot-Temperatur lag um 15°C höher als beim üblichen waagrechten Einbau.
Chismon
139 Kommentare 98 Likes
Sehr schickes, schlichtes und funktionell (genug) anmutendes Gehäuse :love:, das wäre genau mein Fall, auch wenn ich aktuell keinen Bedarf sehe mein uraltes ThermalTake Chaser MK-I Gehäuse zu ersetzen (das Geld liegt ja nicht auf der Straße und unnötig - da wenig nachhaltig - wäre es zudem).
Wenn ich mir einen Zweit-PC anschaffen würde, dann würde es in jedem Fall wieder ein ThermalTake Gehäuse werden (für mich bleiben die der Referenz-Gehäusehersteller) :), egal wie viel Hype um Corsair, Fractal Design, LianLi, etc. aktuell medial vielerorts gemacht wird (womit ich natürlich nicht aussage, dass diese schlecht sind).
Falls möglich würde ich aber eine leicht größere Version wählen (falls irgendwann in Planung bei ThermalTake; vielleicht nimmt sich der Hersteller ja dem seitens des Autor gemachten Vorschlag mit den wenigen cm mehr für die 360er Radiator Option an), besten Dank auch für den klasse Artikel/Test (y).
Ein wenig erinnert mich das Design des Gehäuses (in weiß) an den Ultimaker 2 (3-D Drucker).
Gurdi
1,370 Kommentare 900 Likes
Super Test, das Gehäuse wird in meiner engere Auswahl kommen. Ich werde gegen Herbst meinen HTPC zum Showcase umbauen und da wäre das Gehäuse perfekt.
Ja das ist leider immer ein Problem an diesem Aufbau was mich auch lange davon abgehalten hat.
R
RohrPostPonny
38 Kommentare 10 Likes
Ist es möglich, ein Vertical Mount in das Gehäuse zu bauen, so das die GPU komplett zu sehen ist?
garfield36
Bei mir steht demnächst eine Übersiedlung in ein neues Gehäuse an. Vorher muss ich aber noch etwas an der Bodenkonstruktion ändern. Der wabbelige Staubfilter unten geht ja gar nicht. Um ihn abzunehmen muss man erst das Gehäuse kippen bzw. umlegen. Werde da eine Art Schubladenkonstrukt anbringen und dann einen Filter mit starrem Rahmen darin einschieben.
F
Furda
663 Kommentare 373 Likes
Weshalb ist es schlecht, dass die AIO mit den Schläuchen unten montiert werden musste? Ich hätte sie auf jeden Fall nur so montiert.
garfield36
Nach den Tests und Kommentaren die ich gelesen habe, ist der Einbau in der Front/Seite, mit den Schlauchanschlüssen unten, die bessere Variante.
Gurdi
Bei einer AIO sollte der Radiator immer überhalb der zu kühlenden Komponente liegen, ansonsten nimmt die AIO mit der Zeit schaden und/oder kühlt schlecht.
garfield36
Auch wenn die Schläuche unten sind kann der Radiator über den Kühlkörper ragen. Das heißt also die Luft steigt im Radiator zum oberen Ende. Und wenn der Kühlkörper unterhalb des oberen Radiatorendes montiert ist, ist alles paletti. Gibt dazu genügend Beiträge im Netz.
FfFCMAD
Die Ein/ Auslaesse am Kuehlblock/ der Pumpe aber dann moeglichst auch nach Oben. Bei einigen Wasserkuehlungen ist das auch so angegeben (Fenster nach oben etc)
Das ist im Prinzip logisch/ Physik. Die Pumpe darf keine Luft ziehen.
F
Furda
Der Block ist hier in der Höhe ziemlich mittig zum Radi, Pumpe bleibt immer unterhalb Oberkante des Radi, es drehen ändert daran nichts.
Die Schläuche unten, damit sie immer unter Wasser sind und die Luftblase oben ist, weg von der Pumpe.
Finde es immer schlimm, wenn der Radi gedreht wird für die Optik, oder weil die Schläuche nicht so geführt werden können, wie man es will, oder zu fest gespannt sind, etc. Dann passt das Ganze einfach nicht, Punkt. Case oder Radi wechseln, alles andere ist Murks. Und Anfänger bauen das nach und haben das Nachsehen.
Xaero82
🤔 Echt? Bei mir hängt zwar nur eine Radeon 5700XT von Sapphire im Tower 100 drin, jedoch hat die auch sehr hohe Hotspot Temperaturen.
Hängt das ggf. damit zusammen, das weniger Gewicht (weniger Druck) auf dem Chip lastet? Oder wie ich bisher vermutet hab aufgrund schlechterer Frischluft-Zufuhr.
garfield36
Ich kann das nicht genau sagen, vermute aber, dass es an der Luftzufuhr liegt. Beim senkrechten Einbau bekam sie Frischluft von den 3 Frontlüftern. Diese konnten Luft aber nur durch beiden Gitter links und rechts des Frontcovers ansaugen. Wie es halt bei vielen Gehäusen ist. Bei der waagrechten Montage bekam die GraKa wohl etwas mehr Frischluft ab. Ich hatte auf der gelochten Netzteilabdeckung zwei 120mm-Lüfter platziert. Die pusteten direkt von unten auf die Karte. Das wird wohl eine Auswirkung gehabt haben. Aber gleich 15°C sind halt schon sehr viel. Viele beachten nur die GPU-Temperatur aber den Hotspot vergessen sie.
Xaero82
Werde ich wohl doch mal mit und ohne Seitenwand testen müssen, wenn es die Zeit zulässt.
Alexander Brose
