Case Reviews
THERMALTAKE The Tower 200 ITX showcase Review – Is that actually still Mini-ITX?!
While the Tower 100 still lacked installation options for a powerful AIO and monster graphics cards like a 4090 or 7900XTX, the slightly grown Tower 200 now offers space for 280mm AIOs and 380mm GPUs. Read about the strengths and weaknesses of the stylish tower in the review.
When I tested the Tower 500 a little over a year ago, I was quite taken with the flexibility and looks. Decent Thermaltake quality, clever solutions, great show – practically everything you would expect from such a case. Unfortunately, I had only installed the small RX 6600 at the time and didn’t realize that the suspended mounting doesn’t suit many large heatpipe coolers of current graphics cards. I first noticed the problem when testing the CTE 750 and unfortunately both the KFA² RTX 3070 Ti SG and the MSI RX 6900XT Gaming X Trio showed the same symptoms again: Supposedly good (GPU) temperatures, but rapidly rising hotspots and revving fans, which is why a small graphics card with an S-shaped heatpipe cooler had to be used again for the review.
But before we condemn the case before the actual review, let’s unbox it first and see what it has to offer.
Unboxing
The small tower comes in an elaborately designed outer box.
The large glass front literally begs for attention.
Quite breathable! Practically all sides of the Tower 200 are perforated.
There’s even room for fans at the rear, with dust filters of course.
Of course, the bottom also has openings and a filter.
The front I/O offers all the usual ports, including USB-C.
The screen, like all other sides, is removed without tools. One click is enough..
… and the screen is unlocked.
Thanks to the anchoring on the bottom, the screen does not fall directly towards you after unlocking.
The lid can also be unlocked by pressing it.
Dust filter – check!
A pre-installed 140mm CT fan can be found under the removable lid.
Another one is located in the rear.
The view from below under the lid. The cables for the peripherals will be connected up there later.
Under the right side panel, two 120/140mm fans or a 240/280mm AIO can be accommodated. The radiator bracket can be removed for easy installation.
For fixing the graphics card, there is a decent clamp on board, which has a good grip on even the largest graphics cards.
Under the PSU cover is a spacious chamber for stowing cables and other things.
For example, 2.5″ SSDs:
Of which, by the way, there is room for two more (or alternatively even two 3.5″ HDDs) behind the mainboard.
Despite the ITX form factor, the tower accepts 200 regular ATX power supplies, which makes PSU selection much easier.
The small panel under the front panel can be removed and replaced by an (optional) panel with a 3.9″ LCD display.
In addition to the user manual, two plastic panels, replacement clips for locking the side panels, cable ties, screws and a speaker are also included.
Cateye180
13 Kommentare 8 Likes
Es fehlt eigentlich ein Hinweis, dass der Tower 200 ein echtes µAtx Gehäuse ist; alle Bohrlöcher und natürlich auch der Platz für ein mATX Motherboard sind vorhanden.
Es ist sehr verwunderlich, dass Thermaltake den Tower 200 ausschließlich als ITX case deklariert.
F
Furda
663 Kommentare 373 Likes
Danke für den Bericht. Wenn ich es richtig verstanden habe, die Anschlüsse sind oben, also die meisten Kabel kommen oben zum Deckel raus, richtig? Da dies sehr unüblich ist, hätte ich mir schon einige Bilder dazu gewünscht....
onyman
244 Kommentare 128 Likes
Hä? Wenn dieser Turm ~50 cm hoch ist, dann sind es doch bis zur Schreibtischunterkannte nur noch circa 20 cm. 😉
A
AahhhFreshMeat
31 Kommentare 18 Likes
Wenn es ausschließlich für ITX wäre würde ich tatsächlich ein anderes Gehäuse wählen. Die für µAtx sind dann nur unwesentlich größer, dafür bekomme ich aber wesentlich günstigere Mainboards und die Auswahl ist auch größer.
Da beides geht, ist's schon OK. Der Preis ist aber dann eher so... Naja
TT-Fabian
4 Kommentare 5 Likes
Ist an sich richtig, allerdings gab es bei der Verwendung von mATX Boards vor dem Release Probleme (verdeckte Kabelführungen, zu kleine Abstände und damit schlechterer Airflow, Kompatibilitätsprobleme mit einigen Boards), weshalb wir offiziell uns dazu entschieden haben das Tower 200 nur als ITX zu bezeichnen.
Wir können einfach nicht sicherstellen, dass mit mATX das Gehäuse so funktioniert, wie es soll
Leo von KitGuru hat ein mATX in seiner Review genutzt, da kann man die Probleme eigentlich recht gut sehen
Antwort 4 Likes
Alexander Brose
836 Kommentare 598 Likes
Danke für die Antwort, Fabian (y)
Freut mich, dass du hier bist.
Grüße!
1,695 Kommentare 1,030 Likes
@Alexander Brose , danke für den Test. Meine Frage geht noch über die von Dir gestellte (Ist das noch Mini-ITX?) hinaus: Warum sollte sich jemand für den Tower 200 entscheiden? Irgendwie kombiniert das Gehäuse doch die Nachteile von Mini-ITX und mATX ohne aber besondere Vorteile zu bieten. Oder sehe ich das falsch?
Pfannenwender
302 Kommentare 196 Likes
Wären die Füße wenigstens an der Seite, oder zumindest demontierbar ... dann könnte man das Case auf die Seite legen und jede von der Größe her passende Grafikkarte verwenden.
So aber ... ist datt Dingen doch allerletzter Murks, oder irre ich da?
Oder hab ich etwa die Liste aller Grafikkarten übersehen, die TT für den Verbau in diesem Case ausschließt?
Ich glaub nicht.
Sowas prangerte ich schon mehrfach an, dass die linke Hand nicht weiß, was die rechte tut.
Da designt TT irgendwas Hübsches daher, was dem Kühlkonzept der meisten Grafikkarten allerdings vollkommen zuwider läuft.
Aber man rechnet wohl damit, dass es den Wenigsten auffallen wird.
Und wenn es auffällt, dann hofft man drauf, dass es auf die Graka an sich und nicht auf die Einbaulage geschoben wird?
Für mich gehört das Dingen von Markt genommen, es ist doch nur mit Verwendung spezieller Grafikkarten tauglich!
Und genau diese Aussage ... hätte ich im Fazit erwartet. Zumindest eine deutliche Produktwarnung!
z
z0rdiac
2 Kommentare 0 Likes
Ich hatte den kleineren 100 auf meiner Liste fuer mein SFF build, jedoch ist selbst dieses etwas zu gross geraten. Das schlimmste ist aber die nach oben gerichtete IO und damit die Grafikkarte, die wie im Vorwort angemerkt wurde, gegrillt wird. Andere (viel kleinere) Gehaeuse wie das Hyte Revolt 3, das NZXT H1 und die SSUPD Gehause machen es vor, IO und GPU Panel unten, halbes Volumen etc.
Alexander Brose
Ja, die hatte ich tatsächlich vergessen, sorry!
Aber so ein Gehäuse stellt man doch nicht UNTER den Schreibtisch 😱!
Weil er optisch durchaus einige Leute ansprechen wird - ich finde ihn ja auch sehr schick. Gehäuse sind immer ein Kompromiss, ITX ganz besonders. Jeder Hersteller versucht da sein eigenes Alleinstellungsmerkmal zu etablieren, mit mehr oder weniger durchschlagendem Erfolg. Bei der Tower Serie ist der Fokus halt mehr auf Optik gesetzt.
ICH halte den hängenden Einbau von Grafikkarten mit geraden Heatpipe-Kühler grundsätzlich für ungeeignet, das habe ich im Review auch mehr als offensichtlich so geschrieben. Bei Kleinen (oder wassergekühlten) Grafikkarten ist er aber absolut kein Problem, weshalb eine generelle Produktwarnung eben etwas überzogen wäre. Ich bin aber gespannt, ob andere Tester nach unserem Hinweis hier und im CTE Review die Sache auch mal überprüfen und evtl. bestätigen können. Wenn man sich die Funktionsweise einer Heatpipe mal genauer ansieht, sollte klar werden, warum diese Einbauvariante eigentlich auch gar nicht funktionieren kann und warum z.B. Noctua vor gut 10 Jahren schon davon abgeraten hat.
Grüße!
M
Mike Sierra
8 Kommentare 0 Likes
Ich bin Fan eines liegenden Boards und darauf stehender Graka = Top Airflow.
Ich nutze daher seit Jahren "mein best Case" (Wortspiel) ;)
Thermaltake Core V21 microATX + Thermalright Grand Macho RT als CPU Kühler
1x 200mm Front + 4x 120mm Oben + 1x 140 Hinten + 2x 120 Unten
Bietet auch die Möglichkeit 2 der Würfel aufeinander zu stapeln.
Für Custom WaKüBuilds oder aber um 2 Systeme (z.B. Produktiv + Gaming) oder (Work + Privat) in einem Gehäuse zu vereinen.
3x 2,5" an der Seite + 3x 3,5" innen.
Echt viel Platz und Flexibilität (AIO 280mm passt Oben und an der Seite)
Bin seit Jahren davon begeistert und fand für mich nichts besseres mit liegender Montage.
by the way, das Gehäuse bietet als Würfel auch die Möglichkeit der herkömmlichen Montage von Board und Graka ala Tower
Oder auch Board oben hängend wenn man was Außergewöhnliches will.
Sinn mal dahin gestellt.
R
RazielNoir
439 Kommentare 202 Likes
Was für ein Monster! Also, ITX ist das für mich nicht mehr!
Mal als Vergleich ähnlicher Gehäuse:
Silverstone FT03 (MATX) 235mm(W) x487mm(H) x284mm(D)
Silverstone FT03mini (ITX) 188.9mm(W) x397mm(H) x235.1mm(D)
The Tower 200 (ITX?) 300mm(W) x537mm(H) x280mm(D)
Größer als das FT03, aber MATX geht nicht gescheit rein?!
Follow Igor:
