Case Reviews
THERMALTAKE CTE E600 MX Big-Tower Review – New feature fixes old problem and it looks really good!
With the CTE design, Thermaltake has tested a new approach to dissipate the waste heat from the components more efficiently. In the first iteration, however, this design led to problems with some GPU coolers, because heatpipes are little divas and are subject to the iron laws of physics. Thermaltake has now solved this problem with the E600 MX and you can find out how the unusual show case performs in everyday use in the test.
I have to admit that I was a little disappointed when I was allowed to test the first cases in Thermaltake’s CTE and The Tower series. Although the cases themselves are well thought out and make a solid impression in terms of quality, I was always annoyed by the “hanging” mounting of the graphics card. It is a mystery to me that only a few testers noticed the problem with the associated hotspot issues and complained accordingly.
Whether this is due to our vehement insistence or whether the “upgrade” was really only made for reasons of appearance is ultimately a matter of conjecture. The fact is: Thermaltake has circumvented the problem quite elegantly by equipping the new E600 MX with a bracket for “floating” mounting of the graphics card. This not only looks good, it also brings the heatpipes back into a “normal” position in which they can do their job properly. But before we get lost in features and technical refinements, let’s first unpack the colossus together.
Unboxing
The outer box is simple, with just a picture of the case printed on it. The model tested is the “Hydrangea Blue Edition” of the E600 MX, a color that was chosen as the “color of the year” on the occasion of the 25th anniversary.
And here it is. The color is certainly an opinion divider and really limits the color of the setup, but I personally think it’s really good!
There is another box in the box. This contains the alternative front panel made of glass, which we will install straight away.
Out of the box, the housing is equipped with the airy, open metal front panel, which naturally offers a much better airflow.
The panel is easy to remove and is also equipped with a magnetic dust filter at the rear.
Behind this is a holder for fans/radiators, which allows them to be conveniently installed outside the case. As we are not installing fans in the front, but an AIO in the side opening, the frame will simply be omitted later for reasons of appearance.
And then the glass plate is clicked into the front. With a material thickness of 4 mm, you have to reckon with quite a considerable weight, so the E600 is out of the question as a “LAN” case.
Next, let’s take a look at the right-hand side panel. This is made of metal and has large openings at the front and rear for proper ventilation.
Both openings are also equipped with magnetic dust filters.
The rear chamber of the housing is concealed behind the side panel.
There is plenty of space here for 2.5″ and 3.5″ drives.
The power supply unit and cables can also be one size larger.
As you would expect, there are also thick rubber buffers to support the power supply unit.
We’ll come back to the rear later when we look at the cable routing – in my opinion, the 600’s only “hitch”.
The rear dust filter, which is also magnetic, is made of flexible plastic.
At this point, I will again take the liberty of pagination in order to avoid endless scrolling.
Rizoma
184 Kommentare 156 Likes
Was ich gut finde das es ein Dualchamber Gehäuse ist wo man das Glas Frontpanel gegen ein Airflow tauschen kann und dies im Lieferumfang dabei ist. Was auch gut finde ist das die Teile für den Vertikal Mount der GPU nicht extra gekauft werden müssen wie so bei einigen anderen Premium Herstellern. Was ich nicht gut finde und evtl. liegt es ja an den Bildern aber es sieht billig aus egal wo man hinschaut Plastik.
Nachtrag: Das mit den Anschlüssen oben empfinde ich nicht als Nachteil so kommt man easy ran, einfach den Deckel abnehmen. Das ist auf jedenfalls einfacher als das Case aus der Ecke zu ziehen in der es in der regel versteckt wird. Übrigen was mir auch auffällt sollten die Schläuche einer AIO nicht nach unten verbaut sein damit die pumpe keine Luft zieht?
echolot
1,118 Kommentare 875 Likes
Guten Morgen zusammen. Schöner Test und schönes Gehäuse. Den Temperaturtest hätte ich gerne im Vergleich mit gelochter Frontplatte gesehen. Ich habe momentan das Thermaltake Core P6 im Einsatz., das gleich teuer und mit weniger Zubehör, vor allem dem PCIe Kabel, daherkommt. Von daher zwar ein stolzer Preis, dafür aber mit Alternativkomponenten. Das Blau gefällt.
grimm
3,194 Kommentare 2,126 Likes
Super Test und sehr interessantes Gehäuse. Ich würde es begrüßen, wenn ihr - passend zu Preis und Formfaktor - jeweils die Wettbewerber-Produkte nennen könntet, die dem Gezeigten sehr nahe kommen.
TT-Fabian
4 Kommentare 5 Likes
Sehr faire Review! Deine Kritikpunkte kann ich gut verstehen :)
Danke dir, Alex!
echolot
Für den, den es interessiert: Testreport mit offener Front. Hier vermisse ich aber auch den Vergleich mit Glasfront.
Inzingor
198 Kommentare 120 Likes
"Dafür aber ohne einen einzigen vorinstallierten Lüfter zum Kunde kommt."
Das ist für mich mittlerweile ein Pluspunkt! Dann kann man sich vernünftige Lüfter selbst einbauen.
F
Fischla
26 Kommentare 12 Likes
Das würde ich aber beim VP und P/L mit berücksichtigen und da ist man schnell bei 50 - 150+ X Euro je nachdem ob mit oder ohne LED.
Es gibt ja auch Gehäusehersteller die selbst Top Lüfter haben und diese auch darin einsetzten
grimm
Für mich ist die Kabelverlegung im Gehäuse zur Grafikkarte ein Thema. Wäre nur dann vermeidbar, wenn man das hängend einbaut. Ich kann aber nicht sagen, wie der Brummer darauf mittelfristig reagiert. Oder übersehe ich eine Stütze?
Edit: Und du, @Alexander Brose, hast natürlich recht vorteilhaft die Fotos von den angeschlossenen Kabeln ausgespart. Reicht der Platz im Deckel bei hängendem Aufbau für ein DP / HDMI-Kabel aus? Die kann man nicht eben einfach biegen...
Ich schau hier deshalb sehr genau hin, weil das ein Kandidat gewesen wäre, um mein Define R6 mal in Rente zu schicken ;)
W
Wellenbrecher
49 Kommentare 43 Likes
Vielen Dank für den Test. Das Gehäuse wäre nichts für mich, er ist noch größer und doppelt so schwer wie mein Phanteks P500A. Andererseits finde ich gerade die Optik und vor allem die Qualität sehr ansprechend (und gute Kühlmöglichkeiten sind ohnehin vorhanden).
@Alexander Brose Ein Vorschlag für einen möglichen Test in der Zukunft. Du hast bereits das Thermaltake Ceres 300 ausführlich getestet und das Gehäuse hat mir sehr gut gefallen. Im Januar hat Thermaltake bei CES das "Ceres 330" vorgestellt. Dieses Gehäuse ist sowohl mit üblichen Mainboards kompatibel als auch mit solchen, deren Anschlüsse auf der Rückseite sind. Asus und Msi haben solche Mainboards vorgestellt.
Mich würde ein Test des Ceres 330 sehr interessieren, wenn Du Mal die Zeit und natürlich selbst Interesse für das Gehäuse hast (und wenn Asus oder Msi ein entsprechendes Mainboard zur Verfügung stellen). Zudem kommt das Ceres 330 auch in einer hellblauen(?) Variante und nicht nur in Schwarz oder Weiß.
Edit: das Ceres 330 scheint eine Variante des 300 zu sein. Außer den Öffnungen für die Anschlüsse auf der Rückseite der relevanten Mainboards sind beide Gehäuse wohl identisch.
K
Klausikowski
23 Kommentare 7 Likes
Vielen Dank für den sehr aussagekräftigen Test!
Das Teil ist wirklich sehr chic, insbesondere die blaue Ausführung.
Das Manko mit den Anschlussgefummel sehe ich allerdings ebenso negativ, auch sind mir ein bissl wenig Plätze
für HDDs im Gehäuse. Allerdings wird das allgemein sowieso immer weniger. Ich habe da halt noch Bedarf.
Kommt trotzdem auf jeden Fall auf die "Könntemansichüberlegen"-Liste!
Starfox555
1,484 Kommentare 750 Likes
Sicher auch für Schaufenster eine interessante Option zur Präsentierung einer Grafikkarte mit RGB Anstrahlung.
Fehlt nur noch der atmosphärische Nebel.
S
SpotNic
1,090 Kommentare 464 Likes
Starfox555
S
SpotNic
Selten die Dinger, vor allem mit PCs dahinter ;)
holansensei
63 Kommentare 17 Likes
Boah, sieht das einfach krass aus. Bin geflasht.
Starfox555
Sind vom Aussterben bedroht, aber es gibt sie noch z.B. bei Arlt etc.
S
Schmerzschrauber19
19 Kommentare 1 Likes
Finde gut dass sich was tut im Big Tower Bereich. Habe selber ein TT, das View 71 Tempered Glass RGB Plus Edition (der kam übrigens mit 4 Riing Trios nebst Controller). Hab den jetzt mit 7 Riing Quads (der letzte kam heute) und zwei Controllern im Einsatz. Wow. Gerade mal geschaut, die legen mittlerweile 380 € für das Ding. Ich habe vor knapp zwei Jahren 259 € bei Alternate bezahlt. Musste aber selber noch Bolzen für die Glastüren machen lassen, da die beim Transport abgerissen waren. Nervig. Die Kisten kommen bei den Agenten von Transportdienstleister schon mal mit Schaden an. Die erste Lieferung musste ich komplett retournieren, da sogar Glas zerbrochen war.
Ich bin mit dem Case und TT seither voll zufrieden. Hab auch ein Riserkabel von denen. Kann nicht meckern. Nur der Support lässt etwas zu wünschen übrig. Antwortet mal einfach gar nicht. Aber anderer Geschicht...
Ich hatte davor das beQuiet dark base pro 900. War auch gut und sehr, sehr modular. Aber eng! Ich mag es, wenn Luft aus so einer Kiste nach allen Seiten raus kann. Mittlerweile habe ich genug Platz und die Wärme wird nach außen abgeführt, wo sie hingehört. Einfachstes Gesetz! Hab nur 20 Jahre gebraucht, um den Schritt mit MO-RA zu machen, weil wegen, ist ja so unbequem.
@topic:
Das CTE E600 wird nicht mein Case (und dass nicht nur wegen der Farbe), vor allem wenn ich lese, du musst Kabel ziehen um überall hinzukommen. Musst du mal ran, baust du die ganze Kiste auseinander. Das wird nix mit uns. Auch das NT hochkant bzw. quer einbauen steht bei mir nicht zur Debatte. Möchte mein NT (Dark Power Pro 13 sehen, und ja, wegen mir leise hören, da nicht passiv gekühlt) sehen und auch mal schnell drankommen, wenn was ist.
Auch das die Karte da drin hängt wie ein Schuhkarton ist nicht meins. Diese 4080/90 Trümmer mit ihren riesigen Lüftern brauchen echt Platz, sind schwer. Mit so einer Entwicklung gehe ich auch (noch) nicht mit, solange es GPU Waterblocks gibt.
Aber nochmal, finde es super, dass sich in dem Segment was tut und den liebevollen Test sowieso. Der Preis ist ok. Ohne Lüfter allerdings dann doch mager. Wenn das Riserkabel drin liegt, auch wieder ok. Das kostet (wenn es so eins wie meins ist für PCIe 4.0) 90 €.
hansmuff
57 Kommentare 39 Likes
Das Gehäuse spricht mich schon an. Ich bin nun kein RGB-fan an sich, aber man kann ja auch alles abschalten oder schwarz einstellen. Der GPU-mount mit riser Kabel mit im Preis ist mir wesentlich lieber als irgendwelche Lüfter die ich eh austauschen würde. Mein tower sitzt unterm' Tisch und je dunkler desto besser. Aber das kann man ja mit diesem Kasten auch.
Ich hätte auch gerne gewußt, wie gut denn ein fettes (lang, daher viel Isolierung) HDMI Kabel da paßt ohne den Deckel zu bedrängen. Insgesamt finde ich die Lösung mit dem Kabelschacht nach oben-hinten raus eigentlich genial.
Sehe ich das richtig, daß die GPU sogar mittig noch einmal unterstützt wird und da auf Gummi, dann Stahl sitzt? Das finde ich also echt supergeil.. oder sehe ich das falsch?
Ist jedenfalls auf meiner Liste für eine zukünftige Neuanschaffung. Danke für den umfangreichen Test!!
Guest
Danke!
Liest sich gut.
Danke für Test.
Das Haus im Auge für next gen 24 core Renderkasten. next gen Grako.
Die beiden Gläser würden gegen dickere getauscht. Der Rechner dahinter entkapselt.
faradyay. etz. ( Emp- sicheres Rendern-steuern..lol) ( warum nicht..)-zweite Funktion ist
( zweites Gerät) Überwachung einer etwas größeren Vertical Farming Gemüse Unit.
Ebenfalls sehr fest. bis 50 Kilotonnen. lol
Entspricht etwa der Technik im Jahr 2080.. voll bio und gut.
Die dritte Funktion will man nicht wissen, ist aber die spaßigste. bang bang..
Verkabelung ist eh erst fertig und nach Testphase-dann- nicht mehr oft rann. Durch
Kapseltechnik in 2 sec immer. Wh inkl eigener Klimatisierung etz..
Lustig ist immer, das man net noch 4, 5 cm breiter und höher geht. Raum ist genug da.
danke peace :)
Alexander Brose
