CPU Latest news
AMD Zen 5 leaks contradict each other about the possible performance increase of the Ryzen 8000 CPUs
With the Zen architecture, AMD has made a remarkable comeback in recent years, as CPUs on the Zen architecture are able to compete with, and in some cases even surpass, Intel's processors. AMD's Zen 5 processors are the next generation of CPUs and are sure to bring further improvements and innovations in the architecture and performance of AMD's processors. Despite AMD's progress, there are still many questions about the exact performance of the Zen 5 processors. However, the new leaks from two well-known YouTube leakers have not brought much clarity. This is because there is a disagreement about how fast the Zen 5 processors will actually be. So they know that they don't actually know anything.
YouTubers Moore's Law is Dead (MLID) and RedGamingTech (RGT), have published detailed information about Zen 5. The two YouTubers have already made successful forecasts and assessments of new technologies and products in the past, but have also been miles off the mark from time to time. The desktop chips, which are intended for use in PCs and laptops, are to be manufactured in 4nm. This means that the transistors that make up the chips will be even smaller than in the current Zen 3 processors, which are manufactured in a 7nm process.
The APUs, which are designed as a combination of processor and graphics chip, could be manufactured in 3nm, while some others could be manufactured in 4nm. This suggests that AMD may be targeting different performance levels for different markets. Finally, it is also mentioned that next-generation server chips could also be manufactured in 3nm. This could indicate that AMD plans to further expand its presence in the server market, as these chips are typically used in data centers and other enterprise environments.
The big news relates to the upcoming Zen 5 processor lineup, which is expected to feature an overall performance increase compared to the current Ryzen 7000 lineup. The IPC increase, i.e. the number of instructions that a processor can execute per clock, should be between 20 to 25% higher, according to RGT. This means that the processors will be able to execute more instructions in a given period of time and thus achieve higher computing performance. Such an increase can be especially beneficial for compute-intensive applications and tasks such as video and image processing, 3D modeling, AI development, and gaming.
Single-threaded tasks refer to processes that are handled by a single CPU core, while multi-threaded tasks can be executed by multiple cores. An increase of more than 25% in single-thread performance would be a significant improvement. It is unclear what type of tasks the forecast is, as this is not explained in detail. For example, it could be games, applications, or other complex processes. RGT's statement is promising, as it promises a potential improvement in performance for certain processes. However, it remains to be seen whether this prediction will actually come true and how this will affect the overall performance of the system.
According to the two leakers, the new processor will have a larger cache and will be part of a speed increase. The architecture will also be revised and polished, which will lead to a considerable performance increase. The front-end will be wider and able to handle more commands simultaneously, while the back-end will have more resources. The clock rates will probably be increased slightly, but not as much as on the Zen 4. It is estimated that clock rates will increase by about 2% to 9%.
As for the number of cores, AMD will probably stick with 16 cores (32 threads) for the flagship, at least at the first launch. However, it is theoretically possible that AMD could get even tougher as development progresses and introduce a 32-core model. This model could be manufactured in 3nm instead of 4nm like the initial Zen 5 desktop lineup. Overall, the Zen 5 processors are expected to bring a considerable performance increase compared to the Zen 4 generation, although the clock rates are only slightly increased. The architecture has been thoroughly overhauled and polished, resulting in a broader front-end and more resources on the back-end.
MLID estimates that the Ryzen 8000 processors will have a performance increase of about 20%. Although a higher value is not excluded, it seems unlikely. Nevertheless, a 20% performance increase would mean a big leap for these processors. It is also mentioned that there are rumors that Zen 5 could be released at the end of this year, but these have proven to be false. Instead, Zen 5 processors are expected to hit the market in the first half of 2024. Some sources even believe that the first batch of desktop CPUs could be released in the first quarter of 2024, but this should be viewed with a fair amount of skepticism.
Source: YouTube, TweakTown
s
scotch
154 Kommentare 105 Likes
Mutet wie eine sehr große Glaskugel an.
Derfnam
7,517 Kommentare 2,032 Likes
Na, komm: die sollen schneller sein. So ne Vorhersage erfordert Mut und zeigt das Vertrauen der Piss-, ups: Leaker in ihre Quellen.
Y
Yumiko
591 Kommentare 283 Likes
Von mir habt ihr es zuerst gehört: Der Zen6 wird um 1%-100% schneller als der Zen5 sein und mehrere Kerne haben - vielleicht sogar mehr als der Zen5, oder auch nicht! Und der Release wird in der Zukunft sein - möglicherweise dieses Jahrzehnt noch, oder auch nicht!
Hach, Mist - jetzt habe ich ganz vergessen diesen extremen Leak zu monetarisieren! oO
Case39
2,564 Kommentare 973 Likes
Also nix genaues weiß man nicht...warum dann die News?
1,747 Kommentare 1,072 Likes
Saure Gurken Zeit? Ein bisschen früh dafür (noch lange nicht Sommer), aber Papier ist geduldig, und das Internet noch geduldiger.
Allerdings sind die entsprechenden YouTube, TikTok usw Kanäle, die solche Leaks, die keine sind verteilen, wohl auch recht einträglich.
Viel von diesen Vorhersagen/Vermutungen sind entweder sehr offensichtlich, oder von Faktoren abhängig, die gar nicht genannt werden. Zum Beispiel die Strukturen, die wahrscheinlich genutzt werden können, wenn es denn soweit ist. Z.B. hat TSMC zZt durchaus Kapazitäten in deren 7/6 nm Knoten frei oder zumindest deutlich billiger zu buchen, bei 4 nm wird's teurer, und bei 3 nm kommt es noch sehr darauf an, wieviel übrigbleibt, nachdem Apple gebucht hat. Apple hat nämlich Erstkaufrecht für Kapazität auf die jeweils neuesten Knoten, und bezahlt dafür auch entsprechend.
Und dann kommt noch die Variable dazu: schafft es Samsung VLSI, endlich zu TSMC aufzuholen? Wenn Samsung ihren 3 nm GAA Prozess noch dieses Jahr für Großserie aufstellen können, würde 3 nm erschwinglicher. Aber, viel "wenn" auch hier mit dabei.
Ich warte jetzt auf die 7040 APU für Notebooks, und man wird sehen, ob die bis Ende April tatsächlich bestellt und auch geliefert werden können.
Gregor Kacknoob
543 Kommentare 450 Likes
Der Inhalt ist in meinen Augen keine News wert. Die Strukurbreite sagt schon lange nichts mehr über die tatsächlichen Strukturbreiten oder gar etwas über die Transistoren aus. Der Mix mit den verschiedenen Strukturbreiten hat ja auch was mit auszulastenden Fertigungskontingenten und den verschiedenen Chips bzw. Chiplets zu tun, um die Preise entsprechend dynamisch gestallten zu können. Die IPC Angabe trägt mittlerweile einen langen Bart. Moore’s Law is Dead lag m.W. ein paar mal echt weit daneben. Also in den Kommentarsektionen blieb nicht viel übrig von deren Ruf eines verlässlichen Leakers.
Gibt doch bestimmt spannendere Themen, als noch ungelegte Eier 2024 (TM), zu denen man jetzt im Frühjahr noch absolut nichts verlässliches weiß :S
Case39
AMD soll bitte erstmal dafür sorgen, das die X3D CPUs, in der Breite verfügbar sind...zumindest der 7950X3D.
Casi030
11,923 Kommentare 2,339 Likes
Da muss man auf der Jagt sein....
Tronado
4,026 Kommentare 2,130 Likes
Stellt sich die Frage, was uns so eine wischiwaschi News bringen soll.
Eine IPC- und SC-Steigerung um mindestens 20% ist das Minimum, daran hapert es noch. Und Big/Little bekommt ihr dann auch, wie fein. :)
Case39
Was glaubst du was ich gerade tue😂
Gamer
148 Kommentare 37 Likes
AMD wird wieder etwas revolutionäres abliefern. So wie bei jeder Generation. Ich freu mich drauf!
Ob das wirklich so "bei jeder Generation" war, bezweifle ich allerdings. AMD hat, genau so wie Intel, doch auch mal daneben gegriffen; ich hatte vor über 10 Jahren Mal so eine AMD APU, die damals noch nicht so hieß, in einem Netbook, das war wirklich nicht schön. Allerdings ist mir auch mein Dual Core Athlon von 2005 sehr gut (positiv) in Erinnerung, der lief dem Vorgänger (Pentium IV ) aber sowas von davon, es war eine Freude.
Allerdings hoffe ich auch, daß der Zen 5 zumindest mit dem Cove der Stunde gut mithalten kann; wenn sich AMD und Intel kloppen, geht's vorwärts. Zur Zeit drücke ich Intel die Daumen, daß die ihren "Intel 4" EUV Prozeß zum Laufen bringen, so daß AMD dann mit TSMC 4 und 3 kontern muss.
A
Aeon.Flux
7 Kommentare 3 Likes
Ich weiß, dass ich nichts weiß.
Bitte um Bezahlung meiner Weisheit.
Samir Bashir
