Case Picture stories Reviews
Something fits in there: Lian Li Q58 in review – water march in the tightest of spaces!
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
The Q58 is the smallest case that Lian Li currently offers and it comes with a somewhat unusual design. It is not only the two different side panels that are unusual, but rather the fact that they can be adjusted modularly and as needed. The Lian Li Q58 is available in 4 versions: black and white with PCIe 3.0 riser cable and the same again with PCIe 4.0 each. The prices depend on color and cable and start at 119 Euros (black) and 129 Euros (white). PCIe 4.0 then costs an additional 30 Euros each.
So, the customer is spoiled for choice as to which case is the right one for him. The markup for color and riser cable is plausible, but not really nice. We will find out what is possible in this case in today’s test. But just to add something like that would be really boring…
..and therefore this will be a real water cooling installation in the smallest space here and now! Anyone can build a large case, but a tiny one like this is always a nice challenge. And exactly on this journey I will take you today simply times!
Scope of delivery
Lian Li ships the Q58 in a plain brown cardboard box with a picture of the case – nothing else is visible from the outside. Inside, the case is well protected as usual with 2 styrofoam blocks and a foil.
The box also contains an accessory box with various screws, cable ties and brackets for the SSD. Also included are two magnetic dust filters and a bracket, which will still be very interesting and which I will discuss later in the review. Because this is very unusual in such a case, but I don’t want to spoil anything here yet.
Technical data and instructions
Here is a brief summary of what the Q58 offers (and what it does not):
Oh, and before I forget: the operating introduction for all those curious little sniffers who always want to know everything in detail:
Anleitung
Tim Kutzner
855 Kommentare 700 Likes
S
Stirrling
31 Kommentare 13 Likes
Ein schöner Bericht - das Case ist an sich schon hübsch und hat nette Details. Weil die Wege kurz sind, ist der Loopeinbau nicht ohne. Bei der Kaltgerätebuchse fiel mir aber gleich das "Terminal flat straight" für den Wasserblock von alphacool ein. Kann natürlich sein, dass man damit vom Regen in die Traufe kommt (kann ich auf den Bildern nicht ganz abschätzen). Aber schön, dass die Option besteht.
Ist ein schicker Build geworden.
Pascal TM-Custom
1,122 Kommentare 1,361 Likes
Danke, schön das es euch gefällt.
Und ja die Wege sind wirklich sehr sehr kurz da muss man echt überlegen wie man das am besten macht. Was hier aber auffällt ist das Wakü nicht immer gut sein muss.
Hätte ich jetzt rein Luft Kühlung genommen hätte man da auch Locker einen 5950X und eine 3090 einbauen können.
Das macht son Mini Build sehr Interessant, ich wollte hier einfach mal an Grenzen gehen :) und es hat echt Spaß gemacht.
Dummbatz
295 Kommentare 91 Likes
wäre dann nur eine Frage der Temps. und Lautstärke.
Also wenn Du mal Langeweile hast....
Immer voran ;-)
Pascal TM-Custom
sollte ich in diesem Leben mal eine 3090 haben und 5950X dann gerne 😁
Das Traurige an dem Build ist das es in kürze wieder zerlegt wird und die Teile für ein nächstes Build herhalten müssen damit ihr nächsten Vlog bekommt.
Aber so ist das eben mit solchen Vlog Builds die Lebenserwartung ist nicht sehr hoch.
Onkel.Tom
55 Kommentare 8 Likes
Hi,
ein sehr schönes Gehäuse... Danke für den Test !
Vielleicht könnte man für die Zukunft die Fotos anders machen? Ein heller Hintergrund wäre doch zu bevorzugen. Denn viele Fotos lassen keine Details erkennen.
Für meinen Geschmack sind die Fotos zu dunkel...
Trotzdem, weiter so !
Blubbie
808 Kommentare 275 Likes
@Pascal Mouchel schöner test und sehr gute fotos!
Der Kaltgerätestecker an der Position ist echt selten dämlich. Soweit ich das sehe ist das Problem mit dem engen Platz vom GPU Waterblock aber auch nur weil du so eine relativ kurze GPU verwendest, bei der der Terminal so weit vorne sitzt.
Bei z.b. diesem (meinem) RTX3090 referenz design Waterblock wäre da noch viel viel Platz.
Damit wäre das Gehäuse soweit ich das in deinem Fotos sehen kann auch für besonders breite / große Grafikkarten mit Wassserblock geeignet - nach oben hin ist ja genug Platz.
zum vergleich dein Waterblock:
Pascal TM-Custom
So ist es ich hab mir eigentlich selber ein Bein gestellt 😊
S
Stirrling
"Wieso muss es denn gerade die 3090 sein?"
"Weil bei der das Terminal weiter rechts sitzt! Nur deswegen."
Pascal TM-Custom
6800/6900xt nehm ich sehr gerne auch.
Bei denn kleinen Karten ist durch die Bauweise der Terminal sehr weit Links. Und es gibt kaum Blöcke für kleinere Karten.
S
Stirrling
Ich stellte mir nur gerade ein Gespräch mit der "Finanzverwaltung" vor. :)
Blubbie
ich kann dir noch mehr "Gründe"/"Argumente" aufführen:
- Radeon 6900XT die ich sogar noch im Januar 2021 für 1300 Euro gekauft hatte - habe ich original verpackt gleich zurück geschickt da ich zu spät gesehen habe, dass in mein kleines Gehäuse (NCAse M1) nur Wassergekühlte NVidoa Referenz-Design oder Founders Editions rein passen. Die Radeons sind da knapp 1 cm zu breit :-(
- die RTX 3080 kostete zu der Zeit (Januar 2021) 1100-1300 EUR (im Vergleich zu heute ein Schnäppchen) - allerdings verglichen mit der 3090 für die ich nur 1669.- gezahlt habe - quasi UVP - wäre die 3080 reiner Wucherpreis gewesen. Gründe über Gründe ;-)
Ne Scherz bei Seite - ich finde das Lian Li Q58 echt interessant, da durch die vertikale GPU Halterung man echt mehr Spielraum in der Breite der GPU hat und damit mehr Modelle potentiell möglich sind.
Pascal TM-Custom
zum Glück ist meine Finanzministerin da ganz einfach xD
TGH1978
58 Kommentare 25 Likes
Bin zwar selber kein Fan von Wasserkühlung, aber dass heißt nicht, dass ich nicht wie in diesem Fall die Arbeit von Anderen bewundere.
Ist wirklich Spitze geworden. Meine ehrliche Hochachtung!
Du hast in dem Bericht mehrmals gefragt warum man auch ein ATX-Netzteil einbauen kann...
Bei SFX Netzteilen ist (derzeit) meines Wissens nach bei 850W die Grenze...
Wenn aber jetzt jemand diese Gehäuse zb. mit einem 5900X und einer 3080er GPU (von 5950X und 3090er ganz zu schweigen) nützen will, dann natürlich mit Luftkühlung wird er wohl zu mind. 1000W (aufwärts) und ATX greifen... ;)
B
Besterino
6,900 Kommentare 3,471 Likes
Silverstone hat ein 1000W SFX, das reicht für einen 5950 plus 3090.
arcDaniel
1,665 Kommentare 924 Likes
@Pascal Mouchel warum tust du dies ;-) ich plane ja auch einen neuen Aufbau und hier schwebt mir das Evolv Shist XT im Kopf herum, was vom Aufbau dem Q58 doch extrem ähnlich scheint.
Ich möchte Luftgekühlt bleiben, da es doch vieles Einfacher macht aber den Build macht mir wieder Lust auf eine Wasserkühlung... rrr...
Sehr schöne Arbeit aber!
TGH1978
Danke wusste ich nicht - bisher hatte ich nichts über 850W gesehen...
Und ja für den 5950 + 3090 können 1000W noch reichen, je nachdem was man sonst noch so betreibt, und wie sehr man OC will...
Aber der Grund für die Möglichkeit auch ein ATX-Netzteil nehmen zu können bleibt meiner Meinung nach der Selbe, falls es jemand braucht, zb. mit extrem OC i9-12900K+3090, hat man bei ATX einfach noch stärkere zur Auswahl...
Wahrscheinlich eh schon alt bekannt - hier kann man sich ein wenig "spielen":
Und wenn nicht kann man ja eh auch ein SFX nehmen...
B
Besterino
Klar, eine ATX-Option ist definitiv von Vorteil (im Zweifel schon beim Preis für's Netzteil).
Pascal TM-Custom
Ok betrachtet man das ganze so dann macht die Option Standard ATX PSU Sin.
igor'lLAB Community
