Cooling Fans Reviews
The new colourful 120 mm class: be quiet! Light Wings PWM and High Speed PWM in test | launch review
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
Should Santa Claus now donate a restrained quiet pedal with ARGB halo or rather a powerful brother including colorful fireworks? And do you want the parts individually or in a three-pack with a hub as a free accessory?  Yes, also be quiet! sends glowing fans into the race for the first time, which may sound like blasphemy to some. Well, ARGB also works in black, so you can turn it off. But that would really be doing an injustice to the completely redesigned fans. Because that’s exactly what today’s test will show.
They are still fans, where the focus is on performance and noise development and which also shine nicely as a bonus without overdoing it. Fans that shine exaltedly and by the way also cool a bit and lay out nice noise carpets, the market knows enough by now. Doesn’t really need anyone, so better put the cart before the horse so it makes sense. The RGB lighting can be left as it is, even if the impression is rather solid and a bit more restrained (pleasant):
The manufacturer uses the so-called rifle-bearing, which is very similar to the normal plain bearing, but is quieter and has a service life almost as long as ball bearings. This bearing has a spiral groove through which fluid is pumped from a reservoir (similar to the fluid bearing). This makes them rather insensitive to the direction of installation (unlike plain bearings), as the pumped fluid lubricates the top of the shaft. Pumping also provides sufficient lubricant on the shaft, reducing noise and increasing service life. So much for the theory and we will see later in the sound spectrum if and which advantages can be seen (and above all heard).
The frame is, except for the translucent light ring with its individually controllable 20 ARGB LEDs, rather plain and very torsion-resistant. The use of translucent plastics results in a very uniform luminous image without extreme hotspots for the LEDs. The shape of the impeller follows the well-known wave design of be quiet! and relies on rounded tear-off edges. While the classic standard case fan uses 7 fan blades, the High Speed has a total of 9 fan blades, which later explains the slightly different measurement results of the fans at identical speed.
The decoupling is achieved with inserted rubber applications, which do not twist even when the screw is tightened. The gap dimensions and surface finish are good to very good. The power consumption of 4.56 (120 mm PWM) and 5.4 (120 High Speed PWM) Watts at full speed is medium-high, but that’s the toll you have to pay for a good performance. First of all, the key data for better comparability to the later measurement results for both fans in comparison:
120 mm PWM Standard 120 mm PWM High Speed
Form factor 120 mm
Starch 25 mm
PWM Yes, 4-pin connector
RGB 20 ARGB LEDs
Decoupled Yes
Color Frame Black
Accent color None
Color rotor Translucent
Weight in g 205 210
min. speed 100 300
max. speed 1700 2500
Volume flow m3/h 70.53 88.86
Flow rate CFM 41.51 52.3
static pressure mmH2O 1.66 2.6
Sound pressure dBA 20.6 31
Life Time hrs 60,000
On the next page you will first see how and what we test and why. Understanding the details is extremely important in order to be able to objectively classify the results later. The differences between many models are more in the details and THE best fan for all situations can hardly exist. There is a certain optimum in every situation and of course there are also good all-rounders. But they usually have their price. But if you plan to use 60mm radiators for example, you might save money by choosing the best model for your application, which might not perform so well as a case fan. And vise versa, of course.
For all curious people here again an excerpt of the data sheet:
Light_Wings_datasheet_en
Thy
1,843 Kommentare 744 Likes
Ich gehe davon aus, dass du uns die Ergebnisse der 140 mm - Version nicht lange vorenthalten wirst?
Pascal TM-Custom
1,122 Kommentare 1,361 Likes
ric84
63 Kommentare 30 Likes
BeQuiet goes RGB, 2021 ist ein verrücktes Jahr o_O
ssj3rd
225 Kommentare 156 Likes
140er Werte interessieren mich auch brennend
H
Headyman
117 Kommentare 54 Likes
Man schafft entweder die gleiche Performance mit weniger Betriebsgeräusch oder mehr Performance bei gleicher Geräuschentwicklung:
Das trifft offenbar weitestgehend zu, aber bei voller Drehzahl schlägt die Referenz zumindest den 1700er durchgehend beim Airflow (die gleiche Performance ist da nicht gegeben, da der 1700er die max. Performance des Noctua nicht erreicht).
Irgendwas ist seltsam am letzten Diagramm (Airflow/Drehzahl), warum endet die Kurve beim Noctua bei 50cfm, die müsste doch bis 58 gehen bzw. bis 55 wenn die 5er Rastung als Limit gilt. Die fast 2000Upm erscheinen auch recht hoch für 50cfm, schließlich liegt der max. bei 58cfm und das muss ja auch noch über die Drehzahl kommen.
Oder habe ich hier was völlig missverstanden (Gehäuseszenario beim letzten Diagramm)....?
Pascal TM-Custom
Na ist ja auch klar das der mit 1700 geschlagen wird der macht ja auch mal 300RPM weniger :)
Ich muss nochmal in der Grafik schauen vielleicht hat es denn Wert nicht übernommen werd ich direkt Prüfen.
Der Test geht über mehrere Phasen natürlich kann es auch sein das unser Referenz Lüfter jetzt schon etwas gelitten hat und nicht mehr wie am Anfang die 58 cfm Packt das waren die Werte von Anfang an.
Ich werde aber gegeben falls nochmal einen neuen organisieren und nachmessen.
LEIV
1,558 Kommentare 645 Likes
Sehr schöner test, und sehr schöne Lüfter.
Falls ich noch mal auf nen RGB Trip komme, sind die auf jeden Fall in der engeren Auswahl 👍
A
Andy
269 Kommentare 73 Likes
Irgendwas stimmt da wirklich nicht. Wenn ich nach den Daten auf Seite 4 gehe, erreicht der Noctua bei 1000 RPM 31,6 CFM (Case Fan) und im Volumetric Airflow vs. Fan Speed Diagramm auf Seite 7 kommt er nur noch auf ca. 23 CFM bei 1000 RPM.
10,472 Kommentare 19,602 Likes
Bitte Eines nicht vergessen:
Wir messen die CFM in möglichst genauen 5er Schritten. Wenn 55 CFM gehen, dann ist der Wert drin. Wenn er 60 nicht erreicht (auch knapp 59 sind keine 60), ist er nicht drin. Unsere Kurven sind NICHT interpoliert und jeder der Einzelwerte ist wirklich auch in der Excel-Tabelle ein echter Kurvenpunkt! Höher auflösen kann man das nicht mehr weiter, weil man auch so schon unzählige Einzelmessungen hat.
Und nun kommt der mögliche Knackpunkt. Die letzten beiden Tabellen sind immer aktuelle Messungen, die Vergleichswerte aus den Einzeltabellen stammen vom Originaltest mit dem damals nagelneuen Lüfter. Wenn der Referenzlüfter über die mittlerweile doch ordentlich aufgelaufenen Betriebsstunden so nachgelassen haben sollte, dass er auch die 55 nicht mehr erreicht, wird es einen neuen Referenzlüfter geben und wir müssen mit Blacknoise reden.
Nachtrag: Pascal misst jetzt alles mit einem anderen Lüfter des gleichen Modells noch einmal nach. Plausibilität und so. Also bitte dranbleiben...
Ihr bleibt natürlich auf dem Laufenden :)
Alexander Brose
836 Kommentare 598 Likes
Wow, krasser Test! (y)
Schön, dass die Blinki-Bunti-Lüfter auch endlich eine vernünftige Qualität erreicht haben und auch was können, statt nur eine Show abzuziehen und zu rattern.
Grüße!
RAZORLIGHT
360 Kommentare 266 Likes
Durch den Leuchtring, schrumpft dadurch nicht der Impeller im Durchmesser, was zu verminderter Performance führt? Irgendwo muss man ja den Platz für den Ring hernehmen um die 120mm Spezifikationen einzuhalten, hatten doch auch die Alphacool Auroras vor ein paar Jahren.
Wenn der 140er ähnlich gut performt wäre das ein toller Gehäuselüfter für mich.
Update vom 23.11.2021 um 12:10 Uhr
Wir haben aus Gründen der Plausibilität und Hinweisen unserer Leser den Referenzlüfter noch einmal vermessen und danach mit einem weiteren, baugleichen Modell verglichen. Der neue Lüfter überdreht zwar um reichlich 100 rpm, erreicht aber wieder die Werte aus dem damaligen Einzeltest des Referenzlüfter. Wir haben deshalb die beiden Grafiken auf dieser Seite (und nur die betraf es) aktualisiert und den Werten des neu getesteten Referenzlüfters angepasst. An der eigentlichen Aussage ändert sich jedoch nichts, denn die Light Wings sind auch jetzt noch leiser bei gleicher Performance und der High Speed leistet sogar deutlich mehr bei immer noch deutlich geringerer Geräuschemission.
Da sich das Bild jedoch verdichtet, dass die von uns verwendeten Referenzlüfter erneut Lagerschäden aufweisen (und deshalb beim Nachtesten immer wieder irreführende Werte aufgetaucht sind), werden wir diesen Lüfter als Referenz ablösen und bei den nächsten Tests durch ein anderes Fabrikat ersetzen. Mit Noctua werden wir uns natürlich in Verbindung setzen und über die entstandenen Probleme berichten. Eine derartige Qualitätsschwankung ist jedenfalls nichts für Referenzmessungen.
Links alter Referenz-Lüfter mit defektem Lager, rechts Lüfter vom heutigen Gegentest
Antwort 5 Likes
Thy
Ja, das sollte so sein und ist meiner Meinung nach auch so, wenn man sich die Papier-Daten der anderen beQuiet-Lüfter mal daneben legt:
Lüfter Light Wings Pure Wings 2 Silents Wings 3
Umdrehungen [rpm] 1700 1500 1450
Luftdurchsatz [m³/h] 70,53 87 85,8
Luftdruck [mm H2O] 1,66 1,25 1,79
Lautstärke [dB(A)] 20,6 20,2 16,4
Pascal TM-Custom
der Impeller ist Gleich geblieben beim Light Wing.
Thermaltake ist ein gutes Beispiel mit ihren Quad RGB Lüfter da hat der Impeller nur noch anstatt 120 nur noch 100
Pascal TM-Custom
du musst dir die Lüfter genau anschauen die Pure Wings haben 9 Blätter die Light Wings 7 und die High Speed Version hat 9 Blätter. BQ hat das schon schlau gelöst und drauf geachtet das der Impeller an sich gleich bleibt aber eher am Rahmen Modifiziert haben das eben nicht wie bei dem meisten der Lüfter/Impeller schrumpft.
N
Nevra
32 Kommentare 11 Likes
sehr schöner test und auch der mehr aufwand und nachtest super! wird es mal eine DB geben wo ich als aussenstehender die lüfter die mich interessieren und ihr getestet habt gegeneinander plotten kann?
ich hab ein kleinen fehler bei der letzten grafik gesehen. Da ist der Bequiet HS grün anstelle von rot in der legende unten, aber man kann es sich auch ableiten welcher welcher ist. wollts nur anmerken fall man das "schnell" fixen kann und sonst ist's halt bunt wie RGB.
Pascal TM-Custom
Danke für die Info hat wohl die Farbe nicht übernommen 🙈.
Und ja sowas wie eine DB wird es geben sind aber noch immer auf der Suche der uns sowas programmieren kann. 😣
ssj3rd
Noctua haben schon wieder Lagerschaden?
Hmm, so wirklich toll ist das nicht…
RAZORLIGHT
@Pascal Mouchel danke für die Aufklärung, klingt sehr gut!
igor'lLAB Community
