Motherboard Practice Reviews System
The highest-end OC platform for Intel? – EVGA Z590 Dark motherboard review with teardown and overclocking
EVGA’s Z590 Dark is probably one of the most sought-after XOC motherboards for the current generation of Intel CPUs, not least because of its uncompromising design, legendary reputation and limited availability of its predecessors. Whether EVGA has created a worthy successor with the project name “E599” to also fire Intel’s Rocket Lake CPUs to the top of all benchmark rankings, we find out today.
Overview and Features
If you’ve ever seen a “Dark” motherboard from EVGA, you’ll immediately recognize the model based on the Z590 platform. The strongest feature is probably the CPU socket rotated by 90° and thus also the shift of the RAM slots from the right to the upper edge of the board. With this special layout, clock frequencies of 5333 “MHz” should then be achievable on the main memory. But also for the overclocking of the CPU all conceivable measures were taken to squeeze the last megahertz out of each chip. EVGA advertises a “21 phase” voltage reulation with a 100% copper heatsink, additionally cooled by two 40mm PWM fans behind the IO panel.
Control and overview is provided by the 4-digit multifunction display, on-board Start, Reset, Clear CMOS and Safe Boot buttons, the latter loading the last working BIOS profile without having to reset all settings. In addition, there are also two “ProbeIt” connectors for external monitoring of all conceivable voltages on the board during benchmarking.
But also the daily use and the installation in a case EVGA has not less features to offer. Two Intel 2.5 Gbps Ethernet ports, Intel WiFi 6 and Bluetooth 5.2, three M.2 slots with a massive heatsink, dual SLI support, right-angled connectors all around for the cleanest possible cable management, and more should fulfill just about every wish.
To start with, EVGA is asking 619 Euros for their LGA1200 top model in their German online shop, which also puts them a bit above the competition in the extreme overclocking segment. The availability of the Dark models in Europe has historically always been somewhat limited and so it’s not surprising that the Z590 Dark is also currently barely available or even listed in etail shops. So I’d like to take this opportunity to thank EVGA for kindly providing us with a retail sample of the board.
Case39
2,549 Kommentare 964 Likes
Hübsches und eindrucksvolles Board. Danke für den Test.
Tim Kutzner
855 Kommentare 700 Likes
Die Eleet Software ist ja mal cool :D
Bin gespannt, was EVGA mit dem X570 Mainboard machen wird
B
Besterino
6,900 Kommentare 3,470 Likes
Nur 2 RAM-Bänke macht es für eher „Normalos“ aber vielleicht nicht so attraktiv. Klar, nicht die Zielgruppe.
H
Himmelhund83
24 Kommentare 7 Likes
Naja der Schnitt wird wohl 2x8Gb haben oder sich 2x16Gb einbauen
Störender sind da schon die Unzulänglichkeiten im Bios wo das Standardmäßige teils gar nicht einstellbar ist
Was ich allerdings seltsam finde: Jetzt baut endlich mal einer einen soliden Kupfer Kühler und setzt doch etwas Material ein, dann kommt der Tester und kritisiert das, auf die Art und Weise wird man für 600€ aufwärts immer nur das durchschnittliche Zeug einbauen...
Spannungswandler Temperatur im Vergleich zu anderen Mainboards hätte ich im Text jetzt nicht entdeckt
Die Bilder in Videoform im Beitrag sind übrigens total störend
thebagger
104 Kommentare 77 Likes
Ich mag das Design, die könnten mehr Bretter mit den seitlichen Stromanschlüssen bringen.
B
Besterino
Jo, die "Video-Bilder" haben mich auch total genervt!
ipat66
1,420 Kommentare 1,434 Likes
Diesen angesprochenen faden Beigeschmack der 21 Phasen kann ich gut nachvollziehen.
Eigentlich eine echte Unverschämtheit dieser PR-Fuzzies.
Sagt einfach die Wahrheit,und gut ist...
Man kann ja die Vorteile verwendeter Komponenten und ihre Qualitätsmerkmale beschreiben
Das einzige was mich gewundert hat,ist der fehlende CO2-Neutral Aufkleber in gruen...:)
Ansonsten sieht das Board schon lecker aus.
Sobald die kleinen Kinderkrankheiten per Update behoben sind,werden diejenigen die sich diesen doch stolzen Preis leisten können austoben können.
Die Software scheint gut geordnet und intiutiv.
Sonst bleibt das Motto erhalten:
Die letzten 5% Leistung kosten eben 50 bis 100 % zusaetzlich
Danke Scullbringer für den Einblick.
Guest
Nervt. Alle 2-3 sec ändert sich das Bild.
Die seitlichen Anschlüsse sind ähnlich wie bei anderen Enthusiastboards, der gedrehte Sockel ermöglicht so aber nur noch 2 RAM Steckplätze, hat also auch Nachteile. Da EVGA auch viel Murks bei den Grakas zusammenbastelt, würde ich so eine Platine als Kleinserie nicht kaufen.
OC auf Intel? Das Design ist doch schon bis an die K*tzgrenze ausgepresst. Cinebench auf 267W allein für die CPU im Stockset (10900k), was soll sowas?
*Eher was für Extrem-LN2-OC, kaum alltagstauglich. Die Heatsinks lassen sich ja relativ einfach abnehmen. Dann müssen sie auch nicht aus Kupfer sein.
skullbringer
310 Kommentare 329 Likes
Danke für das Feedback!
Mit dem Autoslide wird man eben direkt vom nächsten Bild abgeholt, wurde mir auch schon als positiver Aspekt berichtet, aber ist scheinbar sehr polarisierend. :D Man könnte ja auch unten rechts Pause drücken, wenn man sich was genauer angucken möchte.
Alternativ mit deaktiviertem Autoslide müsste man sich eben selber zum nächsten Bild klicken.
Was meint ihr, den Autoslide Timer erhöhen (aktuell 3 Sekunden) oder ganz deaktivieren? 🤔
RX480
1,887 Kommentare 879 Likes
Lt. Corsair:
"Zunächst einmal allerdings würden nur DDR5-Module mit bis zu 32 GByte angeboten."(128GB sind technisch möglich je Modul)
(würde also mit 2x32=64GB für die meisten Gamer reichen, vor Allem mit ds+SF, was ja massiv Ram sparen sollte)
ipat66
Mir persönlich ist es lieber,wenn mein klick zum nächsten führt...
So entscheide ich (und jeder selbst) wann ich (er) durch ist.
Antwort 5 Likes
RedF
4,866 Kommentare 2,702 Likes
Gut das ich nicht der einzige bin den das genervt hat.
B
Besterino
Vor allem aufm Smartphone geht das gar nicht. Und der Pausenbutton ist da eh viel zu klein. Führt nur zu mehr (un)nötigen clicks und für mich einfach NUR NERVIG das Ganze.
Nicht alles was geht / neu ist, ist eine Verbesserung.
skullbringer
Hab's für den Test von heute rausgenommen, falls wer nochmal in Ruhe und ohne genervt zu werden, die Bilder durchblättern möchte.
Und für kommende Artikel von mir wird es dann auch deaktiviert bleiben. Genau dafür ist das Forum ja auch da! ;)
Zum Board und den DIMM Slots: 8 bzw. 16 GB pro Riegel reichen i.d.R. für die meisten "ottonormal" Usecases locker aus, besonders wenn man nur benchmarkt oder die maximale Performance in Games erreichen will. Klar bringt man mit 4 Slots mehr RAM unter, aber wenn das die Anforderung ist, wäre man doch meistens mit einer Workstation Plattform mit Quad- oder Octa-Channel besser beraten, mMn jedenfalls.
Antwort 5 Likes
RedF
Finde solche Boards ja interessant, ich quetsche gerne das letzte bisschen leistung aus meinen komponenten ( hab da echt Spaß daran ).
Und zwei Dimms Slots reichen mir auch. Aber 600€, aua aua.
P
Phelan
200 Kommentare 178 Likes
Schöner Test und echt schickes MB.
Ach wenn ich nicht extrem OC mache und vermutlich auch nicht 600€ ausgeben würde , freud es mich mal so schöne aufgeräumte Layouts zu sehen wo nicht jedes Bauteil weggelassen wude was nicht unbedingt sein muss.
PS: auf einem 600€ MB würde ich Overkill an jeder Stelle erwarten und nicht kritisieren :)
Xabbel
6 Kommentare 0 Likes
...und bekommt dafür von EVGA mit dem Z590 Dark ein wirkliches Premium-Gesamtpaket für Overclocking auf der aktuelle Intel LGA1200-Plattform, vor allem optimal für den täglichen Gebrauch und mit Seltenheitsfaktor inklusive.
Huu bitte noch mal überarbeiten. Was ist damit gemeint? Auf Höhe der Intel Mainboard von EVGA?
RedF
Einen vergleich hat er doch garnicht gezogen.
skullbringer
Xaver Amberger (skullbringer)
