Allgemein Monitors Practice Reviews
The ASUS ROG Strix XG349C Review – An ultrawide monitor with an essential problem!
In the meantime, I have become a convinced Ultrawide gamer myself. I’m even no longer so prejudiced against the topic of Curved. Therefore, the ASUS ROG Strix XG349C fits quite well into my test program. I can understand that Ultrawide and Curved are not for everyone. But as we all know, thinking outside the box is supposed to broaden your horizons. So, we take a detailed look at the good piece of monitor technology from ASUS and especially measure it.
The packaging is very much in the style of ASUS ROG – recognition value and all. Well protected, the monitor arrives at your home and is also set up quite quickly. This does not require any instruction pictures from me. You can do it. What is hidden behind the display? A 1900R Curved IPS panel with RGB subpixel layout. Probably from LG or AU-Optronics. (I’m just guessing at this point) ASUS wouldn’t tell me the manufacturer. Due to possible supply bottlenecks, the supplier is more or less left open. The main thing is that the specifications are met. This is common practice and not a big deal.
You can find the technical specifications in the attached PDF or you can take a look at the ASUS ROG page. (Click here!)
ASUS-Datenblatt_ROG-Strix-XG349C_11.22
That reads quite promisingly. Now, before I go into detail, we need to talk about the price. The RRP is 1,399 Euros. I hope it hasn’t knocked the batteries out of your pacemaker. About a year ago – no, more like two years ago – I would have said, okay: What does the market say? That would still have fit. But 2022? Where you can already get OLED monitors or LCD panels with full array local dimming including mini LEDs for the money. Quasi real HDR hardware, which the XG349C unfortunately does not have to offer at all. Difficult! But the topic of price comes up again at the very end.
The ASUS ROG Strix XG349C Da Vinci Code
ASUS = Manufacturer
ROG Strix = Gaming Brand
XG = Upscale Gaming Class
34 = Diagonal
9 = Sequential Number
C = USB C
At least this mystery could be solved. Now let’s take a look at what ASUS delivers with the Strix XG349C. Next page please…
R
Rene1797
1 Kommentare 0 Likes
Ich arbeite auch seit vielen Jahren auf Curved-Ultrawide-Monitoren, früher 34", jetzt 38". Es ist einfach herrlich, viel besser als früher 2 Monitore nebeneinander. Und natürlich ist auch das Spielerlebniss ein Wahnsinn, wenn es die Grafikkarte schafft möchte man (zumindest ich) nicht mehr tauschen.
ipat66
1,422 Kommentare 1,436 Likes
Wie Du richtig festgestellt hast,ist das ein einfacher Curved Monitor mit einem durchschnittlich gutem IPS Panel.
Das Ganze zu einem 40% überteuerten ROG Money-Train Preis.
Wie Du im Schlusswort richtig feststellst,gibt es für diesen Preis (Ca. 1060 Euro) schon OLED Modelle.
Ein Schnapper ist es nicht.
Danke @Fritz Hunter für die Morgenlektüre
Antwort 6 Likes
Megaone
1,833 Kommentare 1,724 Likes
Erstmal danke für den Test.
Ich glaube mittlerweile, es gibt eine spezielle Form des "Idiotenmarketings". Man nimmt irgendein Produkt von mittlerer Güte und stellt es preislich in eine Reihe von sogenannten "High-End" Produkte, in der Hoffnung, das sich genug finden, die das Teil kaufen.
Nach dem Motto, wenn es teuer ist, muss es ja auch gut sein.
Da es sowas wie einen seriösen Handel mit dem Schwerpunkt Beratung schon lange nicht mehr gibt, funktioniert das sicher in einem gewissen Umfang.
Schlimmstenfalls gibt es beim nächsten Black Friday 30% und das Ding wird den Händlern aus den Händen gerissen.
Antwort 6 Likes
Derfnam
7,517 Kommentare 2,032 Likes
Eher 50 Prozent, @ipat66, zumindest bis zu, wenn ich 700.- als niedrigsten Preis nehme.
Wenn das schon Regionalliga ist, also 4 Klassen unter der Pilzliga, dann gute N8.
Antwort 4 Likes
c
cunhell
562 Kommentare 529 Likes
Der Aussage verursacht mir ernsthafte Bauchschmerzen: "Aufgrund möglicher Lieferengpässe lässt man den Supplier quasi offen. Hauptsache die Spezifikationen werden eingehalten."
Man hat schon bei einem Panel-Hersteller eine gewisse Serienstreuung was die Qualität angeht. Das konnte ich in der Arbeit feststellen, da ich mal angeblich zwei gleiche Monitore auf dem Schreibtisch nebeneinander hatte.
Wenn jetzt ohne einen Hinweis der Panelhersteller gewechselt wird, wird es bestimmt nicht besser. Man kann sich nicht mehr sicher sein, was man bekommt und ob der gelieferte Monitor z.B. mit den Monitoren aus den Tests gleich ist.
Cunhell
Antwort 4 Likes
0
0xi6en
6 Kommentare 5 Likes
Der Monitor mag aktuell relativ teuer sein, das war im Jahresverlauf aber nicht immer so. Im September kostete er 819 Euro.
Zudem, der AW3423DWF ist ein reiner FreeSync Bildschirm, was einen Vergleich mit dem ASUS eher schwierig macht, der G-Sync bis ans Limit einwandfrei unterstützt. Der günstigste G-Sync QD-OLED Monitor kostet derweil dann auch min. 1300 Euro. Stichwort: Äpfel und Birnen.
Viele Grüße
Dennis
Sebi19582
51 Kommentare 16 Likes
Seit ich mit dem iiyama G-Master GB3461WQSU-B1 Red Eagle in Ultrawide angefangen habe (34" ohne Kurven), möchte ich auch nicht mehr ohne Ultrawide leben. Die RTX 2070 kotzt zwar manchmal ganz schön. Aber da muss sie eben durch :ROFLMAO:
Danke auf jeden Fall für den Test, aber insgesamt finde ich es schade, dass sich Ultrawidemonitore schon ganz schön fies in hohe Preisregionen bewegen. Okay, meiner hat nicht mal 400€ im Outlet gekostet (keine Ahnung, warum der retourniert wurde). Vielleicht habe ich bei den teilweise schlechten Bewertungen bei gh.de einfach Glück gehabt und seit fast zwei Jahren keine Probleme und ein für mich passendes Bild und prad.de war ja auch überzeugt.
Ich habe den Fehler gemacht, einmal auf einen OLED-Monitor zu schauen. Das hat natürlich versaut und da kann ich den Einwand von Fritz schon verstehen: Wenn man die UVP so hoch ansetzt, dann sollte es schon OLED sein.
Mein Traum wäre ein wirklich einfach designter OLED-Monitor ohne Curved (macht es ja nur teuerer), ohne RGB, ohne KVM mit einem stabilen Standfuß, nur mit Höhenverstellung und G-Sync-Kompatibilität. Da ist dann alles dabei, was viele Leute brauchen und man kann das Geld in das Panel stecken und bleibt vielleicht auch mal unter 1.000€...
Megaone
Zumal man im Zweifelsfall sich immer für den billigsten Anbieter entscheiden wird. Russich Roulette im Panellotto.
Ich sags ja. " Idiotenmarketing" at its best.
Derfnam
Panellotto? Dasn Kuchen, oder? Von dem jeder in der Kette bis zum Kunden ein Stück abschneiden will. Bis der sich dann verkrümelt :D
FritzHunter01
1,216 Kommentare 1,649 Likes
Hallo zusammen,
danke für euer Feedback. Zum Thema Panel-Lotto. Das sehe ich nicht so kritsch. Ich teste nicht den ersten ASUS Monitor, daher kann ich zumindest bis jetzt sagen, dass die Qualität immer gepasst hat. Mal von den Marketing-Witzen wie 1 ms Reaktionszeit abgesehen.
Die restlichen Specs passen schon. Ich habe gerade den BenQ Mobiuz EX3415R hier stehen. Was soll ich sagen, der hat eine UVP vopm 699 € und wer sich mal die Specs im Vergleich anschaut, der kann da schon auf dem Papier sehen, dass sich die Monitore aber am sowas von ähnlich sind. Da ich die Messwerte schon kenne, kann ich nur sagen:
Wer keinen KVM Switch braucht, ohne dedizierte OSD-Software klar kommt, mit Overshoot unter 100 Hz leben kann, dafür aber den besten sRGB-Modus - den ich je gemessen habe - braucht, der kann ich die Kiste holen. HDR kann der auch nur auf dem Papier... Wer das will, der sollte den DELL nehmen.
Grüße
FritzHunter01
LG bringt bald einen 27 Zoll 1440p 240 Hz OLED raus. Der wird einfach der Wahnsinn! UVP 999 €
Die Hersteller müssen ihre Preise für IPS ohne Mini-LED mit FALD aber sowas von senken....
Y
Yumiko
542 Kommentare 247 Likes
Mit Apple ist eine prominente Firma komplett mit diesem Konzept sehr erfolgreich - wenn der FUSS vom Monitor nur 1000€ kostet ist er gleich ausverkauft :p
T
TheSmart
432 Kommentare 216 Likes
Hmm dies bestätigt mal wieder meine Vorurteile gegenüber Produkten, wo Gaming draufsteht.
Da wird meistens dann noch ein ordentlicher Batzen an Geld auf den Preis aufgeschlagen.
Marketinggedönskram halt.
Und Asus ROG ist mir da in schlechter Erinnerung. Die Produkte sind gut, keine Frage. Aber die Preise teils unverschämt.
Seien es Monitore, Grakas, Mainboards und was die da noch so mit dem Gaming-Label haben.
Und naja Apple.. die waren schon sehr schlau unf verkaufen ihre Produkte als eine Art Luxus-Livestyleprodukt.
Ein Must-Have in gewissen Kreisen.
Aber Asus gehört nicht dazu. Die haben für mich persönlich kein echtes Alleinstellungsmerkmal.
c
cunhell
Bei Apple gab es angeblich mal ne App die absolut nichts konnte außer den Preis für eine App maximal ausreizen und auf dem Display erscheinen. Nur um zu zeigen, dass man es sich leisten konnte. Das wurde mir zumindest von einem Apple-User eines iPhones so erzählt.
Ob es stimmt weiß ich nicht, da ich kein Apple'aner bin.
Cunhell
1,698 Kommentare 1,031 Likes
Ja. ROG steht mittlerweile v.a. für "Ripoff of Gamers" oder irgendsowas ähnliches. Ich glaube Aston Martin hatte Mal einen Smart (den kleinsten) mit AM Schriftzug und entsprechendem Preis im Sortiment. Ähnliches Prinzip.
@Fritz Hunter: Danke dafür, daß Du auch das Preis/Leistungsverhältnis mit in Deine Bewertung einbezogen hast. Derartige Mondpreise müssen angeprangert werden, damit Hersteller verstehen, daß auch Enthusiasten ihre Grenzen haben!
Derfnam
Ruin oll Gamer, oder? Nee, warte: Republic of Gullibles, das war's.
Dabei ist das Prinzip doch schon seit Raffaelo bekannt (der süße Kram, nicht der Maler): von Ferrero? Muss ja gut sein, Adel verpflichtet.
BlackFireHawk
109 Kommentare 115 Likes
Typisch Asus.. gleiche Qualität bei doppelten Preis..
Oder in dem Fall.. Leg 10€ drauf und du hast etwas was welten vor dem Asus liegt von nem anderen Hersteller weil's ne Klasse höher ist
Hab den Alienware freesync OLED hier.. hab 1100€ dafür bezahlt und das Ding ist ein Traum von einem Monitor was das zocken und HDR angeht.
Auch wenn er noch das eine oder andere Firmware Update für ein besseres HDR Tracking vertragen könnte (aber laut hwunboxed wird da ja dran gearbeitet)
Die Reaktionszeit und klarheit... Nie wieder LCD
Y
Yumiko
grimm
3,193 Kommentare 2,125 Likes
Fritz Hunter
