Case Editor's Desk Reviews
Testing the Sharkoon Rebel C50 – how much hardware fits into a case for around 100 euros?
Every year again, or what was that? Yes, I also like to take a look at a case and assemble a PC. And because you don’t want to get the big catapult out financially, I deliberately look at inexpensive parts. That’s why today I have the Sharkoon Rebel C50, which I also requested as a sample. And then two boxes arrived at once. As Sharkoon sent me the Rebel C50 in both black and white, today’s article will be much longer than expected. Because if I already have two identical cases to test, then I’ll put the usual standard hardware in the black one. The white Rebel C50 will then be fitted with a custom water cooling system from Alphacool. Because I’ve never done a white build before. What’s more, I had to get additional components for the white build, which I will also introduce to you.
Sharkoon offers the Rebel C50 in black and white, so far. The customer can also choose whether they want four pre-installed RGB fans with a glass panel on the side, or just two pre-installed fans (without RGB) and without a glass panel (mech cover). After all, this also differs slightly in price. But I’ll say something about that later. Sharkoon sent me both cases with a glass panel and RGB fans. Let’s get started…
Technical data
ds_Rebel_C50_RGB_de_01
The features are really very good for the price of approx. 100 euros (in my opinion). Four RGB fans, RGB HUB incl. controller (pre-installed effects), 1x USB-C 3.2 Gen2 and 2x USB-A 3.0 as well as a combo jack connection (TRRS). Let’s take a closer look at the Rebel C50. Turn the page…
B
Besterino
6,933 Kommentare 3,507 Likes
Wo war denn genau Dein erstes Undichtigkeitsthema? Hab eigentlich brav alles gelesen…?
echolot
1,129 Kommentare 884 Likes
Merci Fritz für eine schöne Lektüre am Morgen. Für die Aussage "dass der Lüfter unter der GPU Geschmackssache wäre" hätte Dir Luigi Colani eine gescheuert. Das sieht echt bescheiden aus. Die Gehäusegröße ist nicht optimal für einen Custom-loop und zu limitiert für vernünftige Radiatorgrößen. Das Gefummel wäre mir auch zu stressig. Besser eine Nummer größer wenn es der Platz erlaubt.
10,563 Kommentare 19,821 Likes
Colani war ein dummes, rundgelutsches Ei :D
echolot
Extravagant ja, aber dumm sicher nicht. Im Gegensatz zu den heutigen "Kulturschaffenden" eine echte Bereicherung im Sinne von Mehrwert für die Gesellschaft und Wirtschaft.
Fritz Hunter
