Audio/Peripherals Editor's Desk Furniture Monitors Reviews
Heavy boys and their stands – Monitor arms from Rockstable for 1 and 2 monitors in practice test
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
A resilient gas pressure spring in a stable construction including sufficient mounting kit for a table or work surface, 360 ° swiveling and pivot function – if you are looking for such products for one or two monitors, where the load capacity must also sometimes be 8 kg (or more), then it gets tight. Well, my office furniture dealer has something like that on offer for a good three-figure sum, of course, but if you want something a bit cheaper, you’ll have to search hard – especially for models that can support two monitors independently of each other. By chance I got the tip through an old acquaintance to try it with Rockstable. However, they are not available at the online retailer with the capital A, so I went other ways. More about that later.
The noname monitor arm that we already tested has unfortunately disappeared from the scene and is no longer available. The following two pictures show the current situation in one of my lab rooms and the unfortunate situation of giving away a not insignificant part of the workspace as well as affecting the visibility of the screen contents. You can live with around 50 to 60 euros per monitor if the product is good. However, most cheap stuff only goes up to about 7 kilos per arm and that’s too tight in my case. Let’s start with the workstation for the 3D scanner and the thermal measurements. That’s how it looked until recently:
You can see it already, this is rubbish. Attached to the wall including holes would also be pointless, because I wanted it much more flexible. How versatile, you will see in a moment. The choice fell on the RS-MM010B from Rockstable, which currently costs just under 60 euros gross. I would have liked to have it a tenner cheaper, but the search sucks.
And on the other side of the room, the second monitor for the oscilloscope and the heavy 32″ Eizo monitor for the VGA measuring station were interfering. This monitor weighs in at a hefty 11 kilos, oops. Right here I had already tested another solution (28 Euros at Amazon) and suffered a terrific shipwreck, because the monitor stayed on the ground. Despite full-bodied promises, the construction was probably not designed for this purpose. Four kilos yes, but 11? Here we see the working environment before the conversion, where the work surfaces are once again senselessly blocked.
So how do you actually get this screen armada into the air? That’s exactly why I picked the RS-MM011B from Rockstable, which is designed as a double arm, so to speak, and gives each monitor its own individual life. Both monitor arms are specified for 8 kilos per monitor, but only the Eizo weighs over 11 kilos. Since the parts are interchangeable and the double arm consists of two identical single arms except for the table mount, I first tested the heavy Eizo on the single arm. Since that went, I still tried to fathom the maximum limit and hung various supports on the top. At just under 15 kilos, the arm then slowly but surely gave way and the monitor lowered down.
At 99.90 euros, we at least remain in the double-digit range, albeit only just. In relation, the double arm is therefore cheaper than the single solution. After all. I am sure that this test will be able to answer the many questions that I have been asked again and again in the meantime, also as feedback on the test at that time. Of course, neither of Rockstable’s products are absolutely perfect, so you’d have to go to a professional. But you only ever buy what you really need and nothing for the vanity gallery. From this point of view, the rebuilt lab and the gain in space and convenience were worth a review, even if such a thing is rather niche. But at the latest when you find yourself standing in front of a cluttered table, reality catches up with you all the harder.
Nice side-effect: Today you can see how it looks like with me when I’m not cleaning up for some big shots and what I’m doing where. All earthly problems like lack of space and overbuilt areas are included. Reality from the lab also has its charm and it also fits in with Friday, when you don’t expect scientific analyses, but rather light fare.
XXL
80 Kommentare 17 Likes
ach ich finde solche Nischen Reviews immer interessant und da ich vor noch nicht so langer Zeit vor dem selben Problem stand (Platzmangel) hätte ich mir gewünscht du hättest es eher gemacht. ;) Meine Lösung war diese Halterung , aber deine gefällt mir optisch besser.
MrMarler
3 Kommentare 1 Likes
Schönes Review! Ich hatte seinerzeit auch einen Arm für einen sehr schweren 49Zöller von Samsung gesucht und hatte mich schon über dein letztes Review gefreut. Leider war der Arm da schon nicht mehr verfügbar. Es gibt ihn inzwischen aber wieder:
HALTERUNGSPROFI OFFICE-GS512A https://www.amazon.de/dp/B086MTJ5DQ...t_i_ZF3HX5XA50YBY4VF0NGB?_encoding=UTF8&psc=1
Bei mir ist es ein Ergotron HX geworden. Leider unverschämt teuer.
Guest
Habe aufgrund des damaligen Tests eine Doppelhalterung geholt, da mich die 2 Ständer der Displays immer eingeschränkt haben.
Mittlerweile habe ich noch 2x 27-Zöller (LG Ultragear), ebenfalls mit einer solchen, ähnlichen befestigen wollen. Da musste ich dann aber sehr "kreativ" werden, incl. Flex und Bohrmaschine, um das am Tisch zu befestigen. Somit habe ich die Halterungsprofi von damals für die LG´s genommen.
Aber trotz allem Ungemach möchte ich solche Halterungen echt nicht mehr missen. Und mir reicht das so, obwohl die hier jetzt neu getesteten sicher auch noch praktischer gewesen wären.
Danke für diesen, aber vor allem für den ersten Test, hat mir echt das Leben am PC extrem erleichtert!
Atze Wellblech
110 Kommentare 21 Likes
Interessant. Ich denke das es kein Nischenprodukt mehr ist.
Ich selbst bevorzuge Wandhalterungen, das dann möglichst in 4D.
10,476 Kommentare 19,610 Likes
Ja, aber auch der Office ist mittlerweile sauteuer. Das ist der Rockstable ja noch günstger und lässt sich einfacher am Tisch verschrauben.
Eine Wand hier ist 500er Beton. Viel Spaß beim Bohren. Die andere ist Trockenbau, da braucht man Schwerlastdübel. Und dann hängen die Kabel dumm rum :D
Atze Wellblech
Für dich lieber Igor ist das dann gegessen ;)
Ich hatte in der letzten Butze Ziegelstein, in der jetzigen Gipsstein.
Von "daderweechen" bin ich glücklich :cool:
Stift von Edit sagt: Die Kabel stören mich nicht, ich finde freihängende Kabel, wenn sie ein wenig optisch gut verlegt sind nicht schlimm.
jo-82
54 Kommentare 21 Likes
Sehr schön. Für meinen Schreibtisch wären die Arme etwas zu kurz, hab mich vor über 10 Jahren für ein Modell von Lindy entschieden bei dem man die einzelnen Elemente verlängern kann. War dann zum Schluss bei knapp 200€ für die Stange, Doppelarm und einige Verlängerungen. Lediglich Höhenverstellung geht nicht on the fly, aber das kann ich verschmerzen.
Mein Möbeldealer war über 350 Euro für beide, bissl arg viel, aber am Ende sicher auch gerechtfertigt.
Nur waren die fürs Labor mit den ganzen Features einfach too much :D
O
Ozzy
225 Kommentare 137 Likes
Warum keine Unterlegsscheiben statt abknipsen?
War es so viel zu lang?
Kann man die Kabel nicht im Arm entlang führen?
Hab gerade gesehen, laut Anleitung kann man die Kabel unten am Arm einklicken.
Ansonsten mal ein anderes Thema, das aber auch interessant ist. Überlegung wert.
Die Kabel sind im Arm, das bezog sich auf die offene Wandmonatge.
Alexander Brose
836 Kommentare 598 Likes
Bei meiner nur 60cm tiefen Arbeitsplatte ist so ein Arm quasi unverzichtbar. Auch wenn der serienmäßige Fuß des Monitors noch so toll und flexibel ist, nimmt er doch immer viel Platz auf dem Tisch weg. Die Dinger von Rockstable machen einen guten Eindruck.
Grüße!
r
rossi94
12 Kommentare 3 Likes
Schau dir mal die SpaceCo Space Arms an (heißen in Deutschland Adapt Europe).
Da sind wir beim Single-Arm bei ca. 300 Euro, das ist schlicht zu teuer. Apple-Style :D
B
BirdofPrey
14 Kommentare 1 Likes
Interessanter Test und wohl relevant für mein Officesetup demnächst mit zwei Monitoren.
Den Ergotron habe ich mit dem Schwerlastgelenk für dann 300€ gesamt für einen Samsung C49 im Einsatz auf meinem LeetDesk.
Das Standardgelenk hat den Monitor nicht halten können in der gewünschten Position. Die 1000R erzeugen eine hohe Kopflastigkeit.
r
rossi94
Ich habe grade einen gebrauchten aus England für ca 50€ bestellt. Der Händler hat noch ein paar.
meiner (3x hat damals neu um die 900€ gekostet) …
Das System ist übrigens modular - das passt überhaupt nicht zu Apple 😂
Oryzen
315 Kommentare 184 Likes
Das ist interessant, ich habe mir den da gekauft "Invision MX400, Monitor Halterung 2 Monitore für 19 bis 32-Zoll-Bildschirm", geeignet für zwei 28 Zoll Monitore auf einem kleinen Hubtisch. Bisher finde ich es klasse.
exi78
166 Kommentare 90 Likes
Danke für den Test, finde unter anderem die RS-MM004 und RS-MM005 interessant.
A
Art
51 Kommentare 10 Likes
Ich habe mir in 2020 etwas entsprechendes für 2x 15kg für ~90 € besorgt: nennt sich "Dual Tischhalterung Office-GS524A" von der avertis GmbH (vermutl. nur Importeur)
43'' 4k + 34'' WQHD hängen seitdem erfolgreich dran + würde ich immer wieder kaufen
Follow Igor:
