Reviews System
Shuttle XPC cube SH570R6 Plus Barebone Review – Small powerhouse with a big name
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
With this review we start here at IgorsLab into a completely new article category and dive into the fascinating world of SFF and Mini-PCs. The fitting start is made by an XPC cube from Shuttle, one of the few large manufacturers of such systems. Roots and manufacturing in Taiwan as well as a company headquarters in Germany gives hope for quality, whether the SH570R6 Plus can prove itself in the tests, the following article will tell you.
The good piece is delivered in a medium-sized white cardboard box, which reveals more details about the content via a sticker on the side. There is a carrying handle on the top, so it makes sense to pick up the original packaging and use it as a “carrying bag” for the system.
This use is reinforced by the really good protection of the system inside, where blocks of robust foam enclose the computer from all sides.
The enclosed accessories consist of a driver CD, the power cable and two SATA cables.
Furthermore, various screws for the system and drives are included as well as an unlabeled tube of thermal paste. Of course, the cover for the CPU socket must not be missing either.
Specifications
As always, here are the technical details, more information can be found on theproduct page of the manufacturer
komatös
127 Kommentare 102 Likes
Boooooaaaaaaah, wenn ich Shuttle lese setzt sich bei mir immer von alleine die Hasskappe auf. Wie oft hab ich mir die Hände an den schei... Innenleben der Barebone Gehäuse geschnitten. Da war meistens nichts entgratet und man musste die halbe Inneinrichtung herausnehmen damit man Prozessor und RAM installieren konnte.
Alexander Brose
837 Kommentare 599 Likes
Schöner Artikel!
Ich hatte schon ewig nichts von Shuttle gehört, war aber echt verwundert zu sehen, dass die Dinger heute noch praktisch genau so aufgebaut sind, wie zu Sockel 462 Zeiten, wo ich meinen ersten XPC gebaut habe.
Grüße!
Tim Kutzner
888 Kommentare 726 Likes
Bisschen fummelig sind kleine Systeme immer, fand ich jetzt nicht übermäßig schwierig :D
Aber ja, im Vergleich zu einem ATX System ist es schon schwierig. Angst um meine Finger hatte ich aber wie gesagt nicht
Tim Kutzner
Danke!
Never change a running system und so. Wenn man sich ein eigens angepasstes Mainboard für das eigene Gehäuse anfertigen kann, muss man auch den Formfaktor nicht zwingend ändert :P
Tim Kutzner
Aber das ist doch mal etwas ganz Anderes, oder? :D
In der immer länger werdenden Durststrecke an Hardware, die mal wirklich innovativ und interessant (für mich) ist, war so ein komplett neues Gebiet erfrischend. Man hat es vielleicht schon im Review der letzten AiO gemerkt, so langsam wird Asetek Wasserkühlung mit Markenname XY drauf Nummer #12634 doch etwas trocken. Und so hat es mich sehr gefreut, dass die Resonanz bei den verschienen Mini-PC Herstellern so positiv war.
Und bevor Shuttle den (Retail) Prototypen wieder zurück haben wollte kam ich nicht umhin, ihn auch mal in mein kleines Homelab zu stellen. Der Ikea-Regal Formfaktor ist jedenfalls da :D Ich habe das System jetzt nicht integriert, aber mit ESXi oder Proxmox lässt sich da bestimmt was Feines basteln.
R
Rheinfels
52 Kommentare 28 Likes
Und für den ESXi/Proxmox-Fall im Homelab fände ich noch interessant, wie energiehungrig bzw. effizient das Mainboard ist. Mit 2 Ethernetkarten udn der Möglichkeit, eine 10Gbit im PCie Slot zu verbauen wäre ja ein wenig möglich.
komatös
Hallo Tim, mag sein, dass die neuen Gehäuse besser aufgebaut sind. Zu meinen Anfängen in den 1990ern hatte ich mit den meisten Shuttle Gehäusen 'einschneidende' Erfahrungen gemacht. Die Verarbeitungsqualität war damals, nicht dem Preis gerecht.
Wie dem auch sei, danke für den Artikel.
Fresh-D
74 Kommentare 13 Likes
@Tim Kutzner: Sind es nicht RS-232 Ports und nicht RS-323? 😉
Sonst hat sich gefühlt nichts geändert am Innenaufbau (Früher bis heute). Was ich schon immer gut fand war der Formfaktor des Mainboards (DTX). Das sieht zwar im ersten Moment komisch aus, im Vergleich zu den heutigen Mainstream Standards, aber ich finde immer noch das sich ein M-ITX+-Standard (wie Mini-DTX oder DTX) ruhig etablieren könnte.
Weil viele Leute brauchen in der Regel nur einen PCIe-Slot und haben für den Rest gerade in der heutigen Zeit, mit den ganzen M.2-Steckkarten, eigentlich keine Verwendung mehr und so könnte man irgendwann auch mal (m)ATX als Standard ablösen.
Schade ist das Shuttle, wie du das angesprochen hast, anscheinend unterschiedliche Seitenteile benutzt, obwohl dem System jeder Luftzug von aussen gut tun würde. Weil theoretisch auch der Core i9 irgendwie gekühlt werden möchte. 😄
Greetz,
Fresh-D
Edit: Jetzt erst den Autor gesehen und auch noch vergessen zu taggen. 😅
Abductee
274 Kommentare 49 Likes
Wie verhält sich denn das Netzteil akustisch?
Der kleine 40mm Lüfter ist ja bei den meisten FLEX-ATX Netzteilen gut hörbar.
B
Besterino
7,056 Kommentare 3,639 Likes
Wer soll denn davon wohl die Zielgruppe sein?
Meines Erachtens kommt ein Built auf Basis eines DanA4 wertiger, flexibler und - wenn geizhals mit ca. 450 Euro als Preis für das Shuttle nicht lügt - je nach Ausgestaltung sogar preiswerter daher. Ok, mehr Platz für eine Graka und potentiell 2 Steckplätze (x16 +x4) und 4 statt dem ITX-Standard 2 RAM-Plätze hätte es auf der Haben-Seite…
Meine einzige eigene Real-Life Erfahrung mit Shuttle ist auch schon Ewigkeiten her und hat mich so überzeugt, dass ich nur noch komplett selber baue (außer Mini-Office-Kisten mit mal nem MUC oder so)…
Tim Kutzner
Hups, korrigiert! :D Schreibt man nicht mehr ganz so häufig von :p
Ja, die paar Löcher mehr hätte man ruhig noch stanzen können. Sei es jetzt für CPU oder GPU
Tim Kutzner
Geht im Rest unter beim Betrieb. Mir zumindest nicht störend aufgefallen und ich habe hier ein 1U-Netzteil, wo es mich stört :D
Tim Kutzner
Update 01.01.2022:
Auch einige Tage nach Release funktioniert die sonst verlinkte Preisvergleich-Box von Geizhals bei allen Modellen vom Shuttle nicht, daher hänge ich hier nochmal die Direktlinks an:
Shuttle PC-SH570R611 (300W Modell)
Shuttle SH570R6 PLUS (500W Modell)
Besonders die Variante mit 300 Watt Netzteil ist nochmal ordentlich im Preis gefallen und landet mittlerweile bei etwa 350€ ! Das macht das Ganze natürlich nochmal interessanter, da der Preisunterschied zum Selbstbau immer kleiner wird
@Besterino Da hast du mit den 450€ aber einen teuren Händler erwischt, da gibts deutlich bessere Angebote :)
Fresh-D
Tim Kutzner
Ach das ist nur das Netzteil von der Coldstorage-NAS :D
So gut wie nie an und steht in einem anderen Raum, das passt schon
jo-82
54 Kommentare 21 Likes
Die XPCs haben sich von außen kaum verändert...meiner von 2006? sieht fast genauso aus. Der war Leistung auf Volumen gerechnet lange Zeit auf den damaligen LANs die Nr. 1 ;)
Hatte zum Schluss nen 2,6Ghz QuadCore drinn, die gute alte 280 GTX (P4 Stromkabel musste gemodded werden da der Stecker genau auf Linie des PCIe Slots war) und 2x 150 GB WD Raptor HDDs im Raid 0. Dazu gabs ein schickes Täschchen zum Transport.
Ich finde auch heute die Mainboardgröße mit ca. 10 x 20 cm immer noch deutlich sinnvoller als die 15 x 15 cm von ITX, da es schlankere Gehäuse ermöglicht... Leider schläft hier die Industrie und beharrt auf Quadratisch-Unpraktisch.
R
RazielNoir
472 Kommentare 230 Likes
Aufbau und Optik wie zu Zeiten meines Shuttle mit I7 4770. Und damals hab ich das Barebone schnellsmöglich wieder abgestossen.
Lautstärke und Kühlvermögen waren unterirdisch. In einem Fractal Design Core 500 oder einem Sharkoon QB One geht mehr und leiser. Nur das Mainboardformat ist hochinteressant.
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
