Audio/Peripherals Keyboard Reviews
SHARKOON SKILLER SGK60 – Mechanical gaming keyboard with BOX Switches for connoisseurs vs. SHARKOON SKILLER SGK3 White for thrifty gamers
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
Tomorrow Sharkoon’s new gaming keyboard goes on sale and besides the usual features like RGB and multimedia keys, the new Sharkoon Skiller SGK60 has another special feature: it is equipped with so-called BOX switches – special switches that are especially popular in the DIY scene. I’m curious to see how these switches perform in everyday use and compare them to the regular red Kailh Switches on the SGK3, which is hard to beat as a price tip.
Admittedly: When I was confronted with the term BOX Switch, I first had to use the all-knowing search engine. Obviously, the development of these switches was inspired by the good old days, where a little more emphasis was placed on quality and functionality instead of producing everything as cost-efficiently as possible. My research revealed that these switches are very popular in certain circles and that there are actually real modding communities for keyboards. Little by little, customization options for keyboards are appearing on the German market as well, and it could prove to be a smart move to bring a keyboard with such switches into the mainstream.
Even away from the switches, Sharkoon has put together a nice overall package with the SGK60. The compact dimensions and the black aluminium plate with diamond cut together with the illuminated keys and the Edge-Light form a discreet but noble appearance. I will go into more detail about the separate multimedia, macro and function keys in the course of the review.
Unboxing
To be able to make a comprehensible judgement about the BOX Switches in the course of the test, I will compare them with the regular Kailh Switches. These come in the form of the SGK3 in the new White Edition, which I tested on this occasion.
So that nothing gets mixed up, I unpack the keyboards one after the other and you will be able to distinguish them well in the course of the test because of the color difference. If not, then you don’t need a keyboard anymore, but an optician first.
SKILLER SGK3 White
Let’s start with the white keyboard. Encased in foam and covered with a transparent hood, the white beauty smiles at you when you open the box.
If you’ve only had black keyboards for a long time, a pure white model seems almost alienating and maybe that’s exactly why it’s so attractive?
The switches sit open on the sturdy aluminium plate.
Hidden under the white keycaps: The linear Kailh red switches.
Already briefly teased above, there is also a package with 14 Double-Injected PBT Caps included.
For easy removal of the caps, there is even a tool for pulling them off.
Between the white keys, the blue PBT caps stand out and make you want to further customize the keyboard.
The rear feet are designed as a simple folding mechanism with a rubberised base.
There are also rubbers on the front to ensure a non-slip stand.
The nameplate indicates the current draw that was asked about in the last review.
Since I also respond to reader requests within the scope of my possibilities, I got myself a simple measuring device and measured the whole story. With rainbow illumination enabled at full brightness (default setting), the keyboard draws approximately 235 mA from the USB jack.
Despite specified 350 mA, I measured a little over 400 mA with all-white lighting. However, it is safe to assume that my meter is not the most accurate. So even in the worst case we are still far away from the USB 2.0 limit of 500 mA.
Besides the already shown keycaps there is only a short manual in the box. A short look into the booklet makes sense to have a look at the assignment of the functions, which is quite extensive.
Sharkoon Skiller SGK3 White, LEDs RGB, Kailh RED, USB, DE
Sebi19582
51 Kommentare 16 Likes
Cooler Artikel, vielen Dank!
Ich benötige dringend eine zweite Tastatur und Maus. Sonst laufe ich mit den Dinger immer zwischen zwei Rechnern hin und her. Ist ja auch irgendwie lächerlich. Die beiden kommen mit in meinen Überlegungskorb :cool:
geist4711
274 Kommentare 127 Likes
schöne tastaturen, beide, auch preislich.
sowas dann mit wahlweise funkanbindung und komplett abgeschaltetem 'blingbling',
sowie lion-akku, bestenfalls wechselbar, und das teil wäre gekauft.....
Guest
Schöner Test, mit etwas überraschendem Ausgang. Dachte eigentlich, die 60er würde besser abschneiden.
Ja, von den SKG3 (in Schwarz, natürlich) habe ich eine mit Khail Rot und eine mit Blau. Die blaue ist mir aber leider viel zu laut, daher liegt sie (schön verpackt) schon ein Weile rum. Vielleicht irgendwann mal andere Switches einbauen. Und das mit der Handballen-Auflage ist auch der Grund, weshalb ich die Rote nicht im Dauereinsatz habe, sondern nur für den Retro-PC. Aber von der Verarbeitung her sind beide wirklich top, für knapp 60 Euronen kann man da echt nicht meckern.
jgmischke
37 Kommentare 4 Likes
Wie sieht es NACH der Individualisierung der Tasten mittles Software aus. Bleiben die eingestellten Werte ( etwa komplette Befehlszeilen für die F-Tasten ) erhalten? Oder muss dazu im Hintergrund die Software laufen?. Da ja kaum für Linux getestet wird, könnte man ja über eine VM alles einstellen, wie man es unter Linux wünscht.
Alexander Brose
836 Kommentare 598 Likes
Normalerweise sind ja genau dazu eigentlich die auf dem Gerät speicherbaren Profile gedacht. Ich teste das die Tage mal aus und antworte hier im Thread darauf (y) .
Grüße!
m
maikrosoft
106 Kommentare 29 Likes
Seit heute steht die SGK 60 vor mir. Ein schönes Stück Technik.
Vorher war eine KLIM Dominaton im Einsatz, welche gegen die Sharkoon echt wie billiger Chinaschrott wirkt.
Hab die Version mit den braunen Switches und muss sagen, es ist echt ein sehr angenehmes Arbeiten damit, vor allem schön leise.
Die Beleuchtung ist sehr hell und die Tasten sind gut ausgeleuchtet.
Daher vielen Dank für den Artikel vom Herrn Brose.
Allerdings gibt es ein paar Sachen , welche ich persönlich, gemessen am Preis, unschön finde.
1. Läd man die Software herunter ist auch ein Firmwareupdater mit bei, welcher allerdings nur auf chinesisch, koreanisch, japanisch??? ist.
2. Bei den Beleuchtungseffekten habe ich keine Möglichkeit gefunden Haupttastenfeld und Edge Beleuchtung synchron laufen zu lassen. (kommt hoffentlich noch mit nem Update der FW)
und 3. - das iss jetzt Meckern auf ganz hohem Niveau :D , die Tasten sind nicht gleich hoch.
Wenn ich leicht schräg von vorne auf die Tastatur schaue dann ist bei meinem Exemplar unter anderem die ENDE Taste etwas höher als die ENTF- und BILD runterTaste jeweils rechts und links daneben.
Alexander Brose
Moin!
Freut mich, dass dir die Tastatur auch so gut gefällt (y).
Den Firmware-Updater (wo hast den denn gefunden?) hatte ich mir nicht angesehen, weil in der Sharkoon Software kein Update angezeigt wurde. Ich gebe das aber gerne weiter, wenn du mir vielleicht einen Screenshot schicken kannst.
Schau wegen der Tastenhöhe mal, ob die Kappe der entsprechenden Tasten komplett runtergedrückt ist. Die Switches sind eigentlich alle identisch hoch, weil die ja direkt in der Aluplatte einrasten. Einfach mal die Taste etwas fester runterdrücken, vielleicht drückt sich die Kappe dann bis zum Anschlag auf den Taster und ist dann eben mit den anderen Tasten.
Grüße!
m
maikrosoft
Der Firmwareupdater ist mit im ZIP Archiv enthalten welches man auf der Sharkoonseite unter Software herunterladen kann.
Alexander Brose
Ach, da isser. Okay, ich gebe das mal weiter. Danke für den Hinweis.
Grüße!
Guest
Hat die SGK3 hier in in Gebrauch?
Wenn ich die Skiller Software installiere, kommt bei jedem Boot die Rückfrage, nach meinem Einverständnis die Software zu starten.
Finde aber ohne tiefer im System rumzugraben nichts, wie ich das mal abstellen kann. Bei Sharkoon nicht vorgesehen und Win11 setzt mir einen Sicherheitsregler vor die Nase (den ich ungern herunter regel)
Bei der Skiller Maus (Light²100) gibt es kein Problem.
Alexander Brose
Unter Windows 10 hatte ich das nicht. Habe leider auch kein Windows 11 im Einsatz, um es zu testen. Hast du mal versucht, das Programm grundsätzlich mit Administratorrechten ausführen zu lassen? Also bei der Exe dieses Häkchen zu setzen?
Grüße!
Guest
Hat als Admin leider nicht funktioniert.
Danke trotzdem:)
Guest
Lösung: Von jedem aus dem Luxx (eratte (y))
Wenn einer hier drüber stoppert:
J
Joinker
27 Kommentare 8 Likes
Mache hier mal den Totengräber. Leider ist die SGK3 unter Linux (zumindest bei meinen beiden Ryzen 5000 Systemen) eher ungeeignet. So sorgt z.B. ein Druck von FN+ß dafür, dass die Tastatur einfach keinen weiteren Input mehr sendet bzw. Linux diesen nicht mehr wahrnimmt (nur manuell abziehen und wieder einstecken oder Neustart hilft dann). Besonders nervig ist das, wenn man sich "verdrückt" weil man z.B. "" tippen möchte (was man bei Linux ja gefühlt häufiger macht) und statt der AltGr Taste die FN Taste erwischt.
Manchmal braucht es zwar einen 2 oder 3 "Versuch" um die Tastatur so "stillzulegen" aber im Grunde passiert es dennoch immer wieder. Betroffen sind im Grunde alle FN-Tasten die RGB regeln. Nicht betroffen sind z.B. Multimediatasten wie "Play" und "Stop" usw. Aber ein paar mal FN+ß und FN+' (rechts neben ß) und man kann das Problem recht schnell reproduzieren.
Habe mich nun einige Tage damit auseinandergesetzt und alles mögliche versucht (z.B. auch die Tasten auf Linux einfach stillzulegen aber auch das blieb ohne Erfolg) Der einzige "Fix" scheint da zu sein die Tastatur (die selbst gar nicht USB3 ist) an einen USB3 Slot zu hängen. Dann passiert es nicht. Überwacht man jedoch dann den Input z.B. via Evtest, stellt man fest, dass nach dem Druck der Taste kein "release" Command gesendet wird und der Evtest-Log endlos gespamt wird. Das stört jedoch nicht weiter, weil dieser Input selbst ja eigentlich gar nicht mit dem Betriebssystem kommuniziert werden müsste, da es sich dabei ja nur um interne Hotkeys (nur für RGB) handelt.
Da scheint entweder irgendeine Inkompatibilität im Linuxtreiber, der Tastatur-Firmware oder im Uefi vorzuliegen. Seltsamerweise ist das Problem jedoch weder auf Windows noch im Uefi selbst reproduzierbar. Wer es selbst testen mag, kann auch einfach eine Linux Livedisk booten.
Vom Sharkoon-Support bekam ich dies bzgl. leider keine Antwort (meine Hoffnung lag darauf ob es ggf. ein Firmwareupdate gibt).
Alexander Brose
