Introduction and scope of delivery
For as long as I have known keyboards, I have always used keyboards that are 100% full-size. The advantage is obvious to me, because having all the keys in the same position is practically a customary right. It will be all the more exciting to use the SKG50 S20 PBT2, which does not use the 100% layout, but only a crooked 96%. But this test will also be a little different when it comes to the mouse, as a Sharkoon mouse, the SGKM50W, will also be tested to go with this keyboard. In other words, a kind of unity for the Day of German Unity. You can find out how the two perform in this review.
And what happens when you first look at it? You are greeted by attractive packaging that is kept simple and plain. You can choose between two color variations of the contents. There is a white and a black version. I opted for the black (linear) keyboard. For whatever reason.
The mouse also comes in plain packaging:
In addition to the main product, the two boxes naturally also contain a few other items. In other words, accessories. The keyboard comes with the spiral cable, two Sharkoon keycaps, a tool to remove the keycaps, “tweezers” to simply pull out the switches and a piece of paper that leads you to the instructions. I think it’s good that you don’t have to print out the instructions and instead refer to a link. It saves a lot of paper. It would have been even cleverer if this had been printed on the inside or outside of the packaging, which is necessary anyway.
The mouse, on the other hand, comes with printed instructions. You also get the charging station and additional feet for the bottom of the mouse.
Sharkoon Skiller SGK50 S2 PBT, schwarz, LEDs RGB, hot-swap, Gateron G Pro 3.0 YELLOW, USB, DE (4044951040872)
siehe Shop | 109,90 €*Stand: 04.10.24 23:15 | |
Auf Lager | 109,90 €*Stand: 04.10.24 23:05 | |
Lager Lieferant: Sofort lieferbar, 1-3 Werktage | 109,90 €*Stand: 04.10.24 23:12 |
Sharkoon Skiller SGM50W mit Ladestation, schwarz, USB (4044951040230)
Lagernd im Versandlager - Lieferzeit 2-5 Werktage | 39,98 €*Stand: 04.10.24 23:02 | |
siehe Shop | 39,99 €*Stand: 04.10.24 23:15 | |
Auf Lager | 39,99 €*Stand: 04.10.24 23:05 |
13 Antworten
