GPUs Latest news
Samsung’s GDDR7 for next-gen GPUs: 54% faster than GDDR6X
Samsung plans to showcase its next-generation GDDR7 memory at the IEEE International Solid-State Circuit Conference 2024 in San Francisco next month. The company will hold a session titled “A 16Gb 37 Gb/s GDDR7 DRAM with PAM3 Optimized TRX Equalization and ZQ Calibration” to showcase its advanced memory solutions for the next generation of GPUs, as reported by TechRadar.
Samsung plans to increase DRAM speeds to 37Gbps, which would be an increase of over 50% over existing GDDR6X DRAM. Although they also have plans for GDDR6W with double the capacities and 64-bit DRAM, they are now focusing on the true next-gen standard. So far, Samsung is offering GDDR6 memory with speeds of up to 24Gbps, but NVIDIA’s RTX 4080 SUPER graphics card is expected to launch this week with at least 23.5Gbps.
Source: Samsung
A few months ago, Samsung announced that they had achieved speeds of up to 36Gbps internally with GDDR7 memory. It seems as though the company wants to continue to maximize the potential of next-generation memory modules. However, it remains questionable whether these faster speeds can be produced in sufficient quantities to meet the demands of upcoming gaming and AI GPU models. Nevertheless, one could expect the next generation of GPUs to reach speeds of 32-36 Gbps.
Below is the bandwidth that the 37 Gbps pin speeds would offer across multiple bus configurations:
  • 512-bit – 2368 GB/s (2.3 TB/s)
  • 384-bit – 1776 GB/s (1.7 TB/s)
  • 320-bit – 1480 GB/s (1.5 TB/s)
  • 256-bit – 1184 GB/s (1.2 TB/s)
  • 192-bit – 888 GB/s
  • 128-bit – 592 GB/s
The GDDR7 memory will offer 20% higher efficiency, which is particularly impressive considering that high-end GPUs consume a huge amount of power. The Samsung GDDR7 DRAM will include technologies specifically optimized for high-speed workloads. There will also be a low-voltage option designed for low-power applications such as laptops.
In order to optimize thermal performance, the new memory standard intends to use an epoxy molding material (EMC) with outstanding thermal conductivity. This should reduce thermal resistance by up to 70 %. In August, it was announced that Samsung had already handed over its GDDR7 DRAM to NVIDIA to conduct an early evaluation for their next-generation gaming graphics cards.
Source: TechRadar
arcDaniel
1,678 Kommentare 942 Likes
Ich finde das sehr spannend und freue mich schon. Ich hoffe, aber auch dass die Basis Speichermodule in ihrer Kapazität wachsen und so Karten von 20gb+ VRam normal werden. Hatte zwar bis jetzt kein Spiel welches die 16gb meiner 4080 ganz einnahmen (meist würden auch noch 12gb reichen), manche kommen aber nahe dran. Und ich möchte keine Monster GPU wie eine 4090 in meinem SFF System haben.
DrDre
267 Kommentare 106 Likes
Mal schauen wann das dann in Masse kommt und wie es dann wieder künstlich beschnitten wird. Effizienzsteigerungen sollten dann ja eigentlich kein Problem sein.
Onkel-Föhn
106 Kommentare 60 Likes
"54 % schneller als GDDR6X"
Dann kommt NV sicherlich auf die Idee das Interface zu halbieren, Kosten sparen, Marge erhöhen und abfeiern.
Zumindest von 384 auf 256bit (1225 GB/s) bei einer 5090 zu senken ...
Antwort 4 Likes
1,768 Kommentare 1,102 Likes
Wird auch interessant sein, ob und wie sich das Packaging ändert oder ändern muss. Bei so hohen Transferraten werden kürzere Wege fast zwingend wenn man sie nutzen will.
S
Staarfury
258 Kommentare 206 Likes
Die Frage ist sicher auch, wie gut DRAM überhaupt noch mit den neuen Fertigungsprozessen skaliert.
Bei SRAM geht da inzwischen kaum noch was, was ja z.B. auch ein Grund dafür ist, dass bei RDNA3 Cache und Speichercontroller in Chiplets mit billigerem Fertigungsprozess ausgelagert wurden.
midwed
41 Kommentare 12 Likes
Yve
113 Kommentare 55 Likes
Hat dann die RTX5060 dann nur noch 64bit breiten Bus? 🤣
Würde irgend wie zu Nvidia passen wenn man 2060 vs 3060 vs 4060 betrachtet.
Samir Bashir
