Basics CPU DDR-RAM Editor's Desk Motherboard Reviews System
The big Ryzen 7000 Memory and OC Tuning Guide – Infinity Fabric, EXPO, Dual-Rank, Samsung and Hynix DDR5 in Practice test with Benchmarks and Recommendations
AMD’s new Ryzen 7000 desktop CPUs, based on the Zen4 micro-architecture, still use the same chiplet design as their predecessors, with a few small but not negligible changes. Igor already gave details about this in yesterday’s big review. Today we want to look at how to configure the new CPUs as optimally as possible and for this we will test no less than 10 different configurations of RAM ICs, ranks, clock rates, timings and of course Infinity Fabric speeds. A big thank you goes to ASRock, AMD, with whose support we were able to prepare this guide in time for the launch.
What’s new with Zen 4, AM5 and Ryzen 7000?
But what is actually new in Zen 4 Raphael compared to Zen 3 Vermeer and how does this affect the adjusting screws, which are left up to each user? Since the design with 1-2 compute cluster dies (CCDs) and one IO die remains, the connecting infinitry fabric with its clock rate (FCLK) is also still highly significant. The IO-Die then again communicates with the rest of the system via interfaces like PCIe 5.0 and DDR5 as usual. The number of RAM channels also remains the same, with effectively 2x 64 bit.
The “sweet spot” on RAM has changed from DDR4-3600 on Zen 3 to DDR5-6000 on Zen 4, and it’s actually there. No, AMD, we’re not forgetting the originally advertised 2000 MHz FCLK with DDR4-4000 on Zen 3, which never really worked, but thankfully this time it’s different. The Infinity Fabric or FCLK also runs a bit faster than on Zen 3, but not at 3000 MHz by far. Consequently, there can no longer be a 1:1:1 config with DDR5-6000, as there was with Zen 3.
At RAM clock rates beyond 6000 Mbps, the UCLK automatically goes into 1/2:1 mode, better known as 1:2. For example, if you activate an EXPO profile with DDR4-6400, the corresponding values are 3200 MHz for MCLK and 1600 MHz for UCLK. The FCLK remains capped at 2000 MHz, at least as long as it is not changed manually. For RAM clock rates below DDR5-6000, an average value is automatically set for FLCK between the base clock of 1800 MHz and the maximum of 2000 MHz, e.g. 1900 MHz for DDR5-5600.
The already mentioned EXPO profiles are technically nothing else than XMP profiles with a different memory address, really now. The stored timings and voltages are also the same, except that they have a different label and are located further back in the SPD. Consequently, it is also possible for RAM kits to contain XMP and EXPO profiles at the same time, with corresponding optimizations for the respective platform.
Kits with both standards are probably already in the works at the known RAM manufacturers and those who don’t want to wait can also flash an EXPO profile onto their XMP kit themselves and vice versa. Not that this is necessary, because at least on Zen 4 motherboards, an XMP profile can also be loaded directly in the BIOS without further ado. Kind of reminding of the G-Sync vs. Adaptive Sync saga, whereas AMD also followed up with the open standard back then and thus slowly but surely put an end to the proprietary certification policy, but I’m digressing again.
AMD Ryzen 9 7950X and Ryzen 7 7700X Review with gaming and workstation benchmarks- A new era begins with Zen 4 an the new Socket AM5
221 Antworten
F
Falcon
117 Kommentare 119 Likes
Sehr geiler Vergleich und n Berg Arbeit! (y)
Bin gespannt wie gut sich das ganze auf preiswerteren Mainboards dann reproduzieren lässt.
Zer0Strat
162 Kommentare 138 Likes
Geiler Artikel vom Potential her und dann die Spielebenchmarks eine komplette Enttäuschung. Das ist vom Grundsatz her Zeitverschwendung. RAM Skalierung mit Built-in Gedöns und QHD?? Boah, ne. (n) Muss ich alles wieder selber machen am Ende.
Y
YoWoo
41 Kommentare 21 Likes
Auch von mir Daumen hoch, bei mir kommt langsam das Ergebnis hoch, dass den meisten Leuten 4800 bis 5200er RAM reichen sollte, die Mehrleistung für deutlich schnelleren und auch teureren RAM sehe ich beim normalen User nicht. Neben synthetischen Benchmarks wäre es mal interessant, in welchen professionellen Anwendungen der schnelle RAM dann seine Stärken ausspielt.
Pascal TM-Custom
1,122 Kommentare 1,361 Likes
Ich zieh mal wieder meinen Hut vor deiner Arbeit @skullbringer
Artikel ist wieder Oberklasse.
Glückwunsch zu denn Rekorden
Weniger reden, erst mal machen. Du willst immer alles besser machen, das sei Dir von ganzem Herzen gegönnt.
Doch auch beim letzten Mal kam dann genau: nichts. Gegenbeweis, Rekordeinträge und dann gern meckern. ;)
Ich kann bei der F1 im TV auch stets besser einschätzen, wer wie und wann dann wo falsch abgebogen ist. :D
Antwort 17 Likes
ApolloX
1,687 Kommentare 955 Likes
SOTTR hat immer gut mit RAM skaliert - hier nicht?
Dann heißt es für SOC, VDD Misc, VDDG CCD, VDDG IOD, VDDP wären 1,45 V sicher. Ok. Aber bootfähig? Stabil? Bei AM3 konntest die Dinger mit so höher Spannung nicht betreiben, hat sich das so deutlich geändert?
skullbringer
311 Kommentare 332 Likes
;) aber ja, bis zu 1,45 V SOC zu booten sind jetzt kein Problem mehr, wo bei Zen3 oft schon 1,25 negativ skalierten
Pascal TM-Custom
Wie schaut's eigentlich aus mit dem First Boot und dem ganzen war da nicht etwas das es länger geht usw?
RedF
4,888 Kommentare 2,717 Likes
Wow zu release schon einen Tunig Guide auf die Beine gestellt.
Hammer : )
Zer0Strat
Dafür brauche ich erstmal Hardware. Ihr habt das Privileg und macht kaum was draus. Die Frage ist jetzt, kommt die Schwache Skalierung von der Hardware oder von den Benchmarks? Test umsonst aus meiner Sicht.
Ghoster52
1,460 Kommentare 1,123 Likes
skullbringer
mit 2x 16 GB bootet's ca. 40 Sekunden, mit 4 x 16 GB ca. 70 Sekunden, Auto-Recovery bei falschen RAM-Settings funktioniert fast nicht. Da wird AMD bei der AGESA noch ein bisschen nachlegen müssen...
Pascal TM-Custom
Bin gespannt wann die ersten post kommen in Facebook oder Foren Hilfe mein Board ist defekt er bootet nicht. 🤣 Dabei braucht der eben länger zur initialisierung.
Jede Wette es werden solche Beiträge kommen.
Antwort 4 Likes
HerrRossi
6,821 Kommentare 2,256 Likes
Interessanter Test, danke @skullbringer! Das war sicherlich sehr zeitraubend.
Die Zugewinne sind zwar da, aber signifikant ist das bis auf SotTR nicht wirklich, weil man ja auch mit langsamerem RAM schon auf ziemlich hohem Niveau ist.Hier würde mich auch noch der Unterschied zu DDR4 interessieren, die Zen3 CPUs profitieren ja durchaus stark von schnellem RAM.
ArcusX
899 Kommentare 521 Likes
Echt jetzt? Wirklich?
Warum machst Du das so? Hier hat sich jemand Arbeit gemacht und sein Werk veröffentlicht. Kritik ist gut, aber warum formulierst Du diese nicht sachlicher und zielführender?
Was meinst Du damit, dass die Skalierung von Hardware oder Benchmarks kommen könnte. Wenn der Benchmark als Messwerkzeug dient, dann muss sich die Hardware gemessen mit diesem Messwerkzeug beweisen. Die Benchmarks die hier verwendet wurden, werden an tausenden anderen Stellen auch so verwendet. Klingt für mich danach, als ob Du bei einem 100m-Sprintfinale die Stoppuhr oder die Streckenlänge anzweifelst.
Aber vielleicht kannst Du ja erläutern, wo Du da Probleme siehst. Dann kann man sich damit auseinandersetzen.
So wie sie sind, klingen die Antworten, die Du postest, für mich nur abwertend provokativ und bringen niemandem etwas.
Antwort 15 Likes
g
gretzer
4 Kommentare 5 Likes
Sehr schön, dass ACC als Benchmark-Titel aufgenommen wurde!
Die Simulation bringt die CPUs voll ans Limit. Ich würde mir hierfür auch Grafikkarten Benchmarks wünschen. Im Simracing-Genre sind Triple-Screens des öfteren anzutreffen und daher auch für Grafikkarten ein enormer Kraftakt. Meine 3080 tut sich mit 3xWQHD schon schwer, weshalb z.B. FSR eingesetzt werden muss.
Grüße!
Guest
Hm.
Meine Hardwarefrickelzeit ist schon etwas her. Das war so 1996-2006. Danach wesentlich ruhiger.
Es sieht wieder so aus, als wenn man sich RAM-Zeugs wieder mal im Endeffekt sparen kann. Es sei denn man benutzt spezielle Anwendungen.
Klar. Passabel günstigen XMP-Speicher der vernünftigen Art lohnt ein bisschen, aber nungut. Überschaubar.
Ehrlich gesagt wundert mich das nicht so besonders viel. War vorher ja auch schon oft so. Nur dieses mal besonders wenig Effekt. Auch nicht schlecht, könnte man in andere Bereiche investieren. Oder es einfach sein lassen :D. Ist ja auch ein Ergebnis.
W
WeisserWalFisch
66 Kommentare 41 Likes
!!! Bombenklasseartikel vielen Dank !!! Da kribbeln doch gleich wieder die Finger auch mal meine historische Workstation zu übertakten. Wie in alten Zeiten wenn Tag und Nacht wie nichts vergehen und sich Pizzakartons und Energydrinks neben den Handbüchern stapeln und von harter Arbeit gezeichnete Sagengestalten in Foren legendäre Geschichten über verglühende Hardware und leuchtende Erfolge erzählen.
w
windclimber
72 Kommentare 21 Likes
Ich greife das hier mal auf mit der Frage an @skullbringer und/oder @Igor Wallossek ob es die ACC Benchmarks auch mit z.B. einem 5800x3d gibt? Habe hier auch einen reinen Rennsimulations PC mit 32er WQHD Triple Setup / 3080Ti / 5600x und überlege eventuell gleich auf AM4 AM5 zu setzen oder ob der 5800x3d vielleicht doch so nah rankommt dass AM4 AM5 zumindest aktuell keinen Sinn macht...
Follow Igor:
