Matching the recently reviewed Roccat Vulcan Pro keyboard, there is also the Burst Pro mouse, which also relies on an optical trigger mechanism. You can find out how the lightweight did in the longer everyday test in the following article:
Packaging & scope of delivery
The cardboard box of the mouse is in the same design as the matching keyboard. Large black print with a few accents in yellow. The front and back show the Burst Pro, and there’s also a close-up of the Titan Switch Optical on the side. Short description of the features and technical specifications then round off the whole thing.
Even after opening, the little mouse still hides shyly in a transport protection made of folded cardboard and plastic foil. A short installation manual, unfortunately additionally shrink-wrapped, also flutters towards me.
Finally unpacked, a first look can be risked: Besides the mouse with PhantomFlex cable, two replacement equalizer pads made of PTFE are included, that’s all. The USB port, just like other Roccat peripherals, has a matching icon for easy identification on the back of the system. A ferrite core around the cable can also be seen, but this is not directly incorporated into the cable, but added later.
Specifications
Here is the overview of the technical details, everything else as usual on the manufacturer’s site.
Roccat Burst Pro schwarz, USB (ROC-11-745 / ROC-11-747)
![]() | Auf Lager, 1-2 Werktage | 43,99 €*Stand: 16.07.24 08:09 |
![]() | Lieferung in 1-2 Werktagen | 43,99 €*Stand: 16.07.24 08:25 |
![]() | Lieferung in 1-2 Werktagen | 43,99 €*Stand: 16.07.24 08:26 |
Roccat Burst Pro weiß, USB (ROC-11-746 / ROC-11-748)
![]() | 1-2 Wochen | 39,42 €*Stand: 16.07.24 08:09 |
![]() | lagernd | 39,99 €*Stand: 15.07.24 09:32 |
![]() | 1-2 Wochen | 47,54 €*Stand: 16.07.24 08:09 |
