Case Raffle Reviews System
Reader test: Jonsbo N2 NAS enclosure from our giveaway – Another good result!
Towards the end of last year, we raffled off a very early Christmas present together with Caseking, which found its lucky winner after some delivery problems. He was kind enough to share his own impressions with us, which we will of course not withhold from you. So here’s the corresponding reader test today, enjoy!
Jonsbo N2 NAS enclosure in review – Not a direct successor, but a chic variation instead
What began as a winter project and ended with glorious spring weather
The Jonsbo N2 is superbly packaged and well protected against external influences. Not only does it have foam protection against knocks, but the case is also wrapped in a plastic bag. Nice for the customer, not so good for the environment.
The case is very cleanly manufactured and has no sharp edges, paint noses or similar defects. The gap dimensions also indicate high-quality manufacturing/good QM.
The four side screws can be quickly loosened with the Allen key supplied and the top can be removed.
I would see a standardized screw concept as an option for further development. Currently, you still need a Phillips screwdriver to loosen the knurled nuts and for the “inner values”, but more on that later.
The user manual provides a quick overview and is well structured.
The individual accessory packs are sensibly packed according to their intended use. The packs also contain more screws, straps, etc. than required. A big compliment here for giving the buyer enough options with these penny items in case a screw gets lost or is simply poorly made.
Now we come to the inner values of the Jonsbo N2.
As there are Phillips screws in the system anyway (mainboard, HDD, power supply, etc.) and also others on the case itself, it would have made sense to install the four screws from the lid in the mold as well. There would definitely be space in the case for an appropriate tool.
I reused part of the foam packaging for the assembly, as the rubberized underside of the case was rather a hindrance for me during assembly.
I installed a Mini-ITX from Asus in combination with an I3-12100T. To be on the safe side, I opted for the option of active cooling and gave the CPU an Alpenföhn Panorama 2. The system was completed with used parts from my own box of bits and pieces. A Samsung 970 EVO 500GB for the operating system and a DDR4-3200 16 GB kit.
The installation was a little more fiddly than expected, as there is only space in the case behind the power supply (be quiet! SFX Power 3) to stow away unused cable lengths. A modular power supply could certainly help here, but you also have to bear in mind that the Jonsbo N2 is not a midi tower. So everything is fine. After the functional test, the cables were optimized a little and fixed with cable ties.
As the rear fan doesn’t leave much room for plugs and cables, I decided to use 90° angled SATA plugs. This works really well.
The Jonsbo N2 can hold a maximum of 5 HDDs. The supplied rubber bumpers are screwed to the sides of these, as well as a rubber band at the front for easy removal. In this way, the hard disks are well decoupled from the housing and do not transmit any vibrations. Three 8 TB hard disks are currently installed in Raid 5 mode. So there is still room for improvement if the storage fills up over time.
In final operation, the NAS runs with Open Media Vault as a data backup and access point for photos and videos in the local network. As I had no previous experience with NAS, learning the ropes and setting it up was a little more time-consuming than expected.
All in all, the project was a lot of fun and I was able to learn a lot.
Many thanks at this point to Igor and his team, as well as the great community!
echolot
1,114 Kommentare 871 Likes
Superinteressantes Thema, da ich dieses Case für eine Eigenbau NAS schon ins Auge gefasst habe. Von daher danke ersteinmal für den schönen Beitrag. Wäre es zu viel verlangt die Innereien mal inkl. Preis aufzulisten?
Warum wurde sich für diese Combo entschieden und nicht z.B. für ein N100 Board, die es ja schon mit 2,5 GBit Schnittstelle und DDR5 auf dem Markt gibt? Wie ist der Stromverbrauch Standby, Idle, Max.?
H
HabeLeiderKeinLabor
149 Kommentare 128 Likes
Wie sieht es mit den HHD Temps aus?
Passt da nur ein slim Fan rein?
komatös
116 Kommentare 93 Likes
Ja, es passt nur ein Slim Lüfter, da der Platz im hinteren Bereich begrenzt ist.
Die Werte für die HDD-Temperature liegen bei meinem 4 x 4 TB System bei 33°C im Idle bis 54°C unter Last.
Bei anderen Konfigurationen werden sich die Werte, von meinen, unterscheiden.
Ich habe mich für TrueNAS Scale als OS entschieden, da hier die Benutzer- und Rechteverwaltung umfangreicher und dedizierter konfiguriert werden kann.
Bandyto
51 Kommentare 57 Likes
Wenn HDD-Datengräber unter Last über 50 °c sind, sollten das hoffentlich nur kurzfristige Temperaturspitzen sein. Gemächliche Archive sollten nicht jenseits 50 °c arbeiten müssen; persönlich eher um die 40 °c maximal.
FfFCMAD
689 Kommentare 187 Likes
Ist egal, wenn die Platten für solche Temperaturen spezifiziert sind. Meine gehen auch bis 65°C. Festplatten fuer NAS sind mit 40 - 50°C absolut im gruenen Bereich.
Und man macht zudem eh noch einmal ein Backup auf eine extra HDD, am Besten gut geschuetzt.
R
Random Horst
20 Kommentare 9 Likes
Guten Abend zusammen,
gerne gibt es noch ein paar Infos, welche von Euch angefragt wurden.
Komponenten:
ASUS Prime H610I-Plus D4-CSM, Intel H610 Mainboard, Sockel 1700, DDR4
MBAS-714 -Aktueller Einzelpreis: 120,90 €
Intel Core i3-12100T 2,20 GHz (Alder Lake-S) Sockel 1700 - tray
HPIT-766 -Aktueller Einzelpreis: 133,02 €
Alpenföhn Panorama 2 CPU Kühler - 92mm
CPAF-059 -Aktueller Einzelpreis: 39,90 €
be quiet! SFX Power 3 Netzteil, 80 PLUS Bronze - 450 Watt
NEBE-216 -Aktueller Einzelpreis: 64,90 €
Das Teuere waren dann noch die Platten von Toshiba für je 179,90 €.
Ein 2.5er Netzwerkanschluss ist für mich keine Priorität, da ich zu Hause auf "nur" 1000 MBit unterwegs bin.
Da ich den RAM noch über hatte wollte ich diesen auch nutzen. Ein Kostenpunkt weniger und weniger Müll, da er so ein 2. Leben bekommt.
Von der CPU her wollte ich noch Reserven haben um eventuell mal einen dedicated Server o.ä. laufen zu lassen. Ich halte mir gerne Optionen offen und der I3-12100T hat da auf jeden Fall genug Reserven für allerlei Ideen. Wichtig war mir eine relativ geringt TPD, damit ich die Option zur Passivkühlung habe. Dies klappt beim hin und her schieben von Daten auch, ich habe den Lüfter jedoch soweit runtergedreht, dass man ihn nicht hört.
Zum Messen des Stromverbrauchs fehlt mir das notwendige Equipment. Steht bei mir aber auch nicht unbedingt oben in der Prioliste, da das System im Vergleich zur restlichen Haushaltselektronik in der Masse untergeht.
Die bereits genannten Temperaturen kann ich so ca. bestätigen, wobei durch die bisherige nicht volle Bestückung sich positiv auswirkt.
Hinten passt leider nur ein slim Fan rein. Mit 90° SATA Steckern geht vielleicht auch ein etwas dickerer rein, jedoch passt dies dann bei den Steckern für die Stromversorgung der Platten wieder nicht. Da fehlt ca. ein cm in der Tiefe, um einen "normalen" Fan einzubauen.
Viele Grüße.
FfFCMAD
N300 von Toshiba?
Ich habe die 4TB Modelle. Die sollten bis 65°C aushalten. Mit 50°C biste gut unterwegs. Bei mir sind die Dinger auch mit 40/ 45°C unterwegs.
R
Random Horst
Es sind 3x 8TB N300 von Toshiba verbaut.
FfFCMAD
Follow Igor:
