Basics CPU DDR-RAM Practice Reviews System
RAM-OC Guide for Intel Rocket Lake and Z590 – Tips, Tricks and Benchmarks
Intel’s new 11th generation CPUs have been available for purchase for a few weeks now, albeit only recently officially. And so I also got hold of an i7 11700K and took a look at what innovations we can expect with the new generation, especially with regard to RAM tuning and overclocking. Unfortunately, I couldn’t present any reliable results so far, since new microcode and thus BIOS versions were released recently, even for Z590 mainboards, which have actually been on the market since the beginning of the year. But anyway, today is finally the day!
In today’s article I would like to take a look at what has changed with the 11th generation in terms of overclocking RAM, because although Rocket Lake still uses the same 14 nm manufacturing process as since Skylake, Intel has changed the internal architecture quite a bit. Primarily fewer and larger cores, with more power and support for AVX512, and a reworked memory controller should do the trick for this generation and bring the gaming crown back to Intel. Whether Intel has succeeded in this, Igor reveals in his big Rocket Lake review, with partly surprising findings!
Eyes open when selecting gears!
Of particular interest with the new CPUs is what has changed with the Integrated Memory Controller (IMC) and what new peculiarities need to be considered when overclocking memory with Rocket Lake. As it was already known in advance by numerous sources, Intel now also uses a gearing, i.e. a translation between memory controller (IMC) and RAM, in the form of Gear 1 (1:1) and Gear 2 (1:2), very similar to the 1:1 and 1:2 modes on AMD Ryzen CPUs between UCLK and MCLK.
The principle is similar to the gearbox in a car, except that you only have 2 gears and cannot change gear while driving, but have to decide beforehand. If we stay in this analogy, for low speeds and better response the first gear is better suited, but this can only be used until the memory controller or motor in our example reaches its “rev limit”.
This “rev limit” is made up of several factors and is reached with Rocket Lake in Gear 1 between DDR4-3733 and 3866. Officially, Intel specifies the supported maximum frequency in Gear 1 even a good bit lower, namely DDR4-3200 on the i9-11900 K(F) SKUs and DDR4-2933 on all other SKUs. If we look at what else the memory clock is composed of, namely the reference clock (depending on the base clock) and the QCLK ratio, then the limit also becomes more tangible.
The basic formula for the RAM clock is as follows:
MCLK = Reference Clock x Gear x QCLK Ratio / 2 (Dual Data Rate)
Of course, as always, we have to keep in mind that “DDR” stands for Dual Data Rate and the actual clock rate is only half. As with previous generations, the reference clock of the memory controller offers a choice between a multiplier of 1.00 and 1.33 and thus an effective clock of 100 or 133 MHz. Multiplied by this, on the one hand, is the new gearing – i.e. the factor 1 or 2 – and, on the other hand, the QCLK ratio just mentioned, a number between 6 and 31. And exactly this QCLK ratio depends on the silicon lottery and determines how high the IMC of a particular CPU can clock the RAM. Depending on the chip quality and the RAM used, this is a maximum of 28-29.
So faster RAM clock rates can only be achieved in the Gear 2 by roughly halving the clock rate of the memory controller and its load. Purely arithmetically you can then reach the double clock rates with this second gear, namely DDR4-7466 to DDR4-7533. Of course, these are only theoretical values, which cannot be achieved with DDR4 in daily operation, but the scale is already shifted upwards with this new IMC design, also in preparation for upcoming CPU generations and DDR5.
Let’s take a look at this with a few theoretical examples:
DDR4-3600 = 1800 MHz:
  • 100 MHz x 1 x 36 / 2 (practically does not work, because QCLK ratio cannot be greater than 31)
  • 100 MHz x 2 x 18 / 2 (works)
  • 133 MHz x 1 x 27 / 2 (works)
DDR4-4000 = 2000 MHz:
  • 100 MHz x 1 x 40 / 2 (practically does not work, because QCLK ration cannot be larger than 31)
  • 100 MHz x 2 x 20 / 2 (works)
  • 133 MHz x 2 x 15 / 2 (works)
So if you want to run your RAM at DDR4-4000 for example, you have to choose the Gear 2 mode with Intel Rocket Lake, there is no way around it and no binning either. We’ll take a look at how this affects performance and what other effects single and dual rank configurations can have in the following pages. But besides the gearing, there are a few other new and tweaks that we’ll get to in a bit.
FritzHunter01
1,216 Kommentare 1,649 Likes
Hallo Xaver,
mega geiles Review! Vielen Dank im Namen der Community für die investigative Arbeit!
Etwas überrascht war ich schon, dass der 3200 MHz CL14-14-14-36 hier so extrem gut abliefert. Klar, die Timings sind sehr wichtig, aber das es so einen Unterschied macht, das hatte ich nicht auf dem Schirm...
Aber gut zu wissen, denn 3200 CL14 bekommt man "noch" recht günstig. Warnung an alle, die Preise für Ram werden weiter steigen, somit solltet ihr jetzt zuschlagen!
MfG
Fritz
B
BloodReaver
56 Kommentare 20 Likes
Hallo,
Sehr interessantes Review! Auch von meiner Seite vielen Dank. Vor allem so rasch nach release :)
Eine Frage, mein 11900K sollte morgen bei mir Zuhause ankommen. Bereits im Februar habe ich mir das Ramkit F4-4000C16D-32GTZR bestellt.
Einfach aus dem Grund, dass ich nicht das Risiko eingehen wollte am Ende noch auf den Ram zu warten aufgrund der aktuellen Situation.
Was würdest du empfehlen - den Ram mal im XMP Profil (Gear 2) einzustellen oder ihn mit 3733MHZ (Gear 1) mit etwas schärferen Timings zu betreiben?
Welche Programme würden sich da am besten eignen - dies mal zu testen? Sorry was Ram-OC angeht weiss ich wo der XMP Button ist, mehr nicht :D
Mainboard ist das MSI MEG Z590 ACE.
Danke im Voraus :)
Gruss
FritzHunter01
Aus dem Artikel geht klar hervor, dass Timings wichtiger sind als MHz...
skullbringer
311 Kommentare 332 Likes
Ganz so einfach ist es leider nicht, da sich wirklich jede Applikation und jedes Spiel anders verhält bzgl. seiner Vorlieben an RAM und CPU. Für solche, die niedrigere Latenzen eher bevorzugen wäre natürlich ein Underclocking sinnvoll, etwa auf 3733 CL14, andernfalls würde 4000 CL16 im Gear 2 mit höherer Latenz aber auch höherem Durschsatz besser performen.
Da dein Kit F4-4000C16D-32GTZR aber Dual-Rank ist hast du damit schon einen Vorteil beim "Multitasking", wodurch sich ein Großteil des Latenznachteils von Gear 2 egalisieren würde.
Meine Empfehlung: Mit dem XMP Profil solltest du in jedem Fall 95% der Leistung aus dem Kit bekommen. Wenn dir die restlichen 5% an Leistung auch noch haben möchtest, hilft nur benchmarken und selber messen, für genau die Games oder Applikationen, die du eben nutzt.
B
BloodReaver
B
Bambina
65 Kommentare 34 Likes
So ganz erschließt sich mir der Sinn (oder Unsinn ?) des neuen Speichercontrollers der 11xxx CPUs noch nicht. Auf der Vorgängerplattform lief doch auch Speicher schneller als 3733 MHz noch im 1:1 (gear1 ) modus, auch wenn es da noch nicht so hieß. Oder liege ich da falsch?
skullbringer
Im Prinzip stimmt das schon, aber der IMC seit Skylake war relativ groß (physikalisch auf dem Package) und ineffizient. Um Platz und Powerbudget für die neuen größeren Cypress Cove Kerne zu schaffen, musste Intel ja eh schon 2 Kerne abschneiden und den IMC kam jetzt eben auch unters Messer.
Da passt die Analogie mit dem Automobil wieder, Stichwort "Downsizing" - Verbrauch und Platz sparen und mit technischen Innovationen dann die Leistung mindestens wieder auf das vorherige Niveau steigern.
B
Bambina
Okay. Ich sehe es trotzdem als Rückschritt, da läßt man einen Teil der Performance durch die neuen Kerne wieder liegen. Ein Schitt vor, ein halber zurück.
B
BloodReaver
Moin moin,
Hab mein System zusammengebaut. Als erstes hab ich mal einen Aida64 Benchmark gestartet. Was sagst du über die Werte?
Hab halt leider nur die Trial version.
Grüsse & schöne Ostern :)
skullbringer
Knapp 60 GB/s Read sind für DDR4-4000 XMP Plug-and-Play schon ziemlich gut. Lass dich von dem etwas höheren Latenz-Wert nicht beunruhigen, denn der Test reagiert ziemlich sensibel auf andere Hintergrund-Prozesse. Und den Vorteil von Dual-Rank könntest du bei AIDA64 eh nur im Copy-Test sehen.
Besseren DDR4 als diesen 4000 CL16 DR B-Die gibt's momentan nicht auf dem Markt, also alles richtig gemacht! 👍
M
Matt-M79
1 Kommentare 0 Likes
Hallo, vielen Dank für den tollen Beitrag.
Bezüglich Intel Rocket Lake S JEDEC 3200 Standard:
Laut JEDEC Website und Wikipedia gibt es 3 verschiedene standards für 3200, welcher davon ist für RKL-S bestimmt? Ich würde zu test- und vergleichszwecken gerne erst einmal alles nach strikten Intel spezifikationen laufen lassen. Welche timings sollte ich dafür verwenden?
DDR4-3200W
DDR4-3200AA
DDR4-3200AC
400 1600 3200 PC4-25600 25600 20-20-20
22-22-22
24-24-24
12.5
13.75
15
R
Ryan Stekken
1 Kommentare 1 Likes
Danke für das nützliche Review, der Gear2 Modus wird dann vermutlich erst ab DDR4 4400 wirklich interessant.
B
BloodReaver
Moin @skullbringer
Ich hab mich mal dran versucht den Ram zu übertakten. Aber mehr als die "Memory try" funktion trau ich mich noch nicht ran.
Bild oben zeigt die 3600Mhz Version und Bild unten die XMP 4000 Mhz variante.
Zu was würdest du jetzt eher tendieren wenn der Schwerpunkt beim gaming liegt?
Und vielleicht noch eine persönliche Einschätzung wie du zu den Werten allg. stehst wäre nett :) (3600Mhz Variante)
Mein Ram-Kit
Vielen Dank
skullbringer
DDR4-4000 Gear 2 und DDR4-3600 Gear 1 wird sich in deinem Fall leistungstechnisch nicht viel nehmen, da das Kit ohnehin schon Dual-Rank ist und dadurch der Impact des Gears geringer ausfällt. Zudem müsste man das wirklich für die jeweilige Applikation oder das jeweilige Game ausprobieren und messen, FPS und Frametimes, erst dann zeigt sich ob mehr Bandbreite oder geringe Latenz wichtiger ist. Und das ist eben bei so gut wie jeder Applikation oder jedem Game anders, teils sogar bei Games mit der selben Engine, je nachdem wie deren Features konkret genutzt werden.
Dein RAM Kit mit diesem Binning DDR4-4000 CL16-19-19-39 ist nebenbei so ziemlich das hochwertigste an Dual-Rank B-Die, was man im normalen Handel so bekommen kann, also sehr gute Wahl! Hier wäre je nachdem welches Mainboard du hast mit Gear 2 wohl noch einiges mehr an Luft nach oben, z.B. DDR4-4400 CL17 sollte machbar sein mit dem Kit. Hier wäre dann auch die Latenz in etwa gleich zu DDR4-3600 CL16, aber die Bandbreite dafür deutlich höher, und somit in jedem Usecase ein Leistungsplus drin.
Aber RAM OC ist natürlich eine recht delikate Angelegenheit und wenn du dir unsicher bist und kein Spielsystem dafür hast, wo im Zweifel mal das ganze Windows sterben darf, würde ich ehrlichgesagt empfehlen beim XMP Spec zu bleiben. Ich hab z.B. extra SSDs mit eigener Windows Installation für RAM OC, mit denen ich alle Settings teste, ausgiebig auf Stabilität teste und erst dann lasse ich das System auf mein normales OS mit wichtigen/sensiblen Daten los.
B
BmwM3
6 Kommentare 2 Likes
danke für den Artikel!
Durch die Infos habe ich nun auch meine 2x 16GB G.Skill RipJaws CL16 19 19 39 F4-3600C16D-32GVKC zum laufen gebracht,
hatte VCCSA und VCCIO zu hoch.
M
MopsHausen
1,054 Kommentare 293 Likes
Einige haben bestimmt schon ordentlich Erfahrungen mit RKL und diversen IC`s und dem IMC machen können, evtl. kann die ein oder andere Frage beantwortet werden.
Wie siehts den mit euren Erfahrungen bei RKL mit Vollbestückung aus gibts da Nennenstwerte Einschränkungen im Vergleich zui den Vorgängern( bei RKL und Cascade lake X ist mir zumindest bei 4XSR nix aufgefallen )?
Wie verhalten sich bei Idleverbrauch und Hitzeentwicklung bei ~3600Mhz G1 lese da viel wiedersprüchliches von o gott bis nicht signifikant.
Bei welcher Speicherverzögerung landet man Erfahrungsgemäß ca. mit durchschnitts E Dies @ 3600 C16 lockere sub timings ?
Bin am überlegen aus Bastellust den 10400 im 2. System gegen einen 11700k zu tauschen , Speicher hätte ich 3 Kits zum rumfummel wobei das E Die kit wohl weiter verwenden würde.
-4x8Gb Micron E Die laufen zur Zeit mit dem 10400 @ 4000 16-21-21-39 , 3200 14-17-14-37 gingen Testweise auch
-4x8Gb Sasmung B Die laufen zur Zeit mit dem 10900x im QC @ 4000 16-16-16-36 bleiben aber auch eher dort
-4x8GB Samsung D Die ( DR Riegel )laufen auf dem 5820k 2666Mhz 14-14-14-34 ( Memcontroller macht nicht mehr mit im QC )
Onkel.Tom
55 Kommentare 8 Likes
Grundsätzlich kann man sagen, 2 Module DR, sind das Optimum. Mit 4 Modulen DR, ist der Speicherbus überfordert und im schlimmsten Fall wird alles wieder langsamer oder die Timings muß man runterschrauben.
Oder man kauft 4xSR. Das ist ja das gleiche wie 2xDR.
Der Satz "je mehr Ranks, je besser" stimmt nur bis insgesamt 4R bei den mainstream CPUs. Bei Threadripper und HEDT natürlich nicht.
Beim Thema Stromverbrauch kann man zwischen 3200 und 4000 von 5W mehr ausgehen bei zwei Modulen. Im Grunde sehr wenig. Aber die erhöhte Spannung treibt halt auch den Stromverbrauch hoch.
E Dies hatte ich noch nie. Wie gut die sind kann man bestimmt raus finden...
Im Grunde ist der Test wirklich gut von Igor. Kleinere Timings bringen immer mehr als schnelleres Ram in der Bandbreite. Habe jetzt meine Samsung b-dies von 3200-CL14 auf 3800-CL16 laufen. Die Latenz ging von 65ns auf 56ns runter.
B
BloodReaver
Mit deinem Ergebnis wiedersprichst du aber ja deiner Aussage. Deine Timings sind gestiegen die Latenz aber gesunken? :)
Martin Gut
7,955 Kommentare 3,710 Likes
3800 MHz CL 16 ist ein etwas schnelleres Timing als 3200 CL 14. Man muss immer die Timings durch die Taktrate teilen um sie vergleichen zu können.
Xaver Amberger (skullbringer)
