Aircooling Cooling Fans Reviews
Raijintek AGERAS 12 ARGB – Cheap 120 mm Case Fan Review | Exclusive Bargain Check
Disclaimer: The following article is mostly machine translated from the original German, and the translation has not been edited or checked for errors in-depth. Thank you for understanding!
Useful ARGB case fans for under 10 euros? The container is still on its way to Germany, but we already took the liberty of testing the Raijintek AGERAS 12 ARGB in detail today. The fans will be available soon in white and black for an MSRP of 9.79 Euros and without RGB for 7.99 Euros. And because the surcharge for the festive lighting is so low, we have already tested the colorful specimen in advance, because we (as well as the supplier) assume that the vast majority of buyers will choose the Christmas tree. For the unlit variant, there is already the Arctic P12 PWM as a counterpart on the market, but that will be very tight. Also and especially with the price.
The spec sheet reads unspectacular. With a self-determined 122 grams, the Raijintek fan is in the midfield and the manufacturer specifies the thickness (installation depth) with the usual 25 mm, which is even correct. You have to know that to be really sure. Often, the thickness is somewhat fiddled with and sometimes one or two millimeters are added without any indication. The bearing is a standard hydrodynamic plain bearing with all the known advantages and disadvantages, but with gratifyingly little play. Yes, and colorful is also possible, especially since Raijintek relies on common preci-dip connectors that can also be cascaded quite easily. Since there are also 2-packs and 3-packs, that makes sense, of course.
The maximum gap of 1.3 mm between the rotor and frame is very good and the surface finish is definitely not objectionable. The fairly neutral white is okay and it is neither too cold nor too yellowish.
And as just described, it also goes nice and colorful, at least within the fair price of just under 10 euros. The following pre-Christmas gallery shows a small foretaste of how the illuminated hub and the five translucent rotor blades look in terms of color.
The decoupling of the frame is done by glued rubber applications on the four corners. It works, but it’s not really that innovative. By the way, the usual 4 screws for the case are also included, there is nothing more. Well, you don’t need more either, only with the multiple packages you still get matching adapters for the purchased number of fans.
Technical data
As an example for the rest of the family, I’ll now show you the spec sheet for the white model, which also applies to the two black variants in the same form, although one of them does without ARGB, but is otherwise virtually identical in construction.
On the next page you will first see how and what we test and why. Understanding the details is incredibly important in order to be able to objectively classify the results later. The differences between many models are more in the details and the best fan for all situations can hardly exist. There is a certain optimum in every situation and, of course, good all-rounders. But they usually have their price. However, if you are planning very specifically with 60 mm radiators, for example, you might be able to save money by choosing the best model for your intended use, which might not perform so well as a case fan. And vice versa, of course.
C
Coquiner
4 Kommentare 4 Likes
Guten Morgen,
insgesamt macht ihr wirklich sehr umfangreiche Lüftertests. Eine bitte. Könntet ihr als Vergleich auch Reverse Lüfter ins Testrennen schicken? Beispielsweise den Sickle Flow Reverse ARGB oder den Thermalright TL-C12R-L RGB.
ipat66
1,422 Kommentare 1,436 Likes
Danke Euch beiden für den Test.
Preiswerte Ventilatoren interessieren mich eigentlich mehr,als diese ARGB-Designstücke.
Die Dinger sollen einfach gut performen und dabei keinen Lärm produzieren.
Deshalb habe ich auch keine Lust 200 Euro für eine Vollbestückung auszugeben.
Aus diesem Grund,bin ich dann letztendlich bei Arctic gelandet.
Mich haben diese Lüfter an die Arctic Lüfter Serien erinnert.
Anzahl und Blattdesign, bis auf die hintere gezackte Abrisskante vom Raijintek AGERAS 12, scheinen ähnlich.
Die Garantiezeit habe ich leider nicht gefunden.
Vielleicht habe ich aber auch Tomaten auf den Augen?
Auch da ist Arctic ja, in Anbetracht des aufgerufenen Preises, eine angenehme Ausnahme.
Pascal TM-Custom
1,122 Kommentare 1,361 Likes
kommt noch der Lüfter mit dieser Option wird der TT Swafan sein mit 2 wechselbaren Impellern. Der Test ist aber sehr umfangreich daher noch klein wenig Geduld.
Alkbert
959 Kommentare 747 Likes
Als jemand, der Stand jetzt seit 35 Jahren PC´s schraubt (angefangen mit einem Schneider PC 1512 aus 1986) stelle ich gerade bei Systemen, die mal 2-3 Jahre geöffnet werden, immer wieder fest, dass sich die Lüfter mit dem Kompressor und der Ausblaspistole unterschiedlich gut reinigen lassen.
Insbesondere diejenigen mit Luftführungsfinnen oder Applikationen oder "Haifisch"zahnform in den Rotorblättern.
Und mal Hand aufs Herz: Wenn man sich Igors lustige Bilder bisweilen anschaut und sich in hinreichendem Umfang die Fähigkeit ehrlicher Selbstkritik bewahrt hat, stellt man fest: Manchen PC hat man 5 Jahre lang nicht mehr aufgeschraubt.
Wieviel dann von der Kühlleistung der Lüfter-Design-Bomben noch übrig ist, hm.
Glatte oder beschichtete Kunststoffe, wie ich es in einem Server Lüfter von Compaq schon gesehen habe, findet man hier kaum - die sind allerdings nach 5 Jahren 24/7 Betrieb noch ohne ein "Staubkörnchen" an den Oberflächen. Sexy sehen die allerdings nicht aus.
Pascal TM-Custom
Ich hab eben direkt mit Raijintek gesprochen 3 Jahre Garantie was ich ausreichend finde. Dafür sind die auch 2-3€ Günstiger als die ARGB Version von Arctic das ist an sich ein sehr guter Spagat
ipat66
Die Auswahl haben ist immer besser...:)
Derfnam
7,517 Kommentare 2,032 Likes
Hattet ihr schon den Klassiker Enermax T.B.Silence im Test? Von wegen 'unter 10 €', newahr.
Ghoster52
1,460 Kommentare 1,123 Likes
Danke für den Test, wieder was günstiges für den Warenkorb (bei Bedarf). (y)
igor'lLAB Community
