Gaming GPUs Graphics Reviews
Radeon RX 7800XT and RX 7700XT Review – AMD, XFX and Sapphire against NVIDIA with reason or energetic crowbar
There was a gap as big and deep as the Pacific Ocean between the Radeon RX 7900XT and the Radeon RX 7600, so the RX 7900 GRE was nothing more than a rarely found alibi card. AMD took its time with the Navi32, probably also for resource reasons, and now wants to push itself ahead of NVIDIA’s GeForce RTX 4070 and the long-tested RTX 4060 Ti, which has to struggle with acceptance problems as a 16 GB variant because the price was simply not right. Even though NVIDIA has now adjusted the prices a bit, the cage is eagerly waiting for the fighters today and of course a result. Or several, depending on how you look at it.
Important preface
Today I’m testing two RX 7800XT and 7700XT each, whose orientation and layout are quite different from each other. And I think it’s a pity that AMD intentionally doesn’t have an MBA card of the RX 7700XT in the program, although it would have been an easy thing to do, because the boards are all the same except for one less voltage converter. Economic constraints? The MBA design is elaborate and good, I can certainly spoil that. That customers wouldn’t buy something like that is an urban legend. That you don’t want to bother with the OEM as much (Vapor Chamber Gate) and hardly earn anything from the cards is more plausible then.
Of course, as usual, there are many benchmarks, the comprehensive teardown, a very elaborate board and cooler analysis with some reverse engineering, a material analysis with my new lab equipment as well as the analysis of power consumption and load peaks including a suitable power supply recommendation. Since I know that many colleagues will also repeat all the technical details including theory, which have already been presented in various tidbits, I’ll spare myself that today and just briefly refer to the already known slides and the short presentation of the two cards with the most important details. After all, you want to see real figures today and not PR fireworks. We already had that recently.
Navi32 in a short overview
AMD’s Navi 32 GPU is manufactured at TSMC in a 5nm process (GCD, 5N FinFET) or in a 6nm process (MCD, N6 FinFET), which again points to a MCM design. A total of 4 chiplets (Navi31 with 6) lie on the now square packag and the 346 mm² total area of the interposer carries a GCD with around 200 mm² and four MCDs with 36.6 mm² die area. Thus, the complete Navi32 has been given to the midrange and even leaves a gap to the considerably slower RX 7600. A Radeon 7700 without XT or an RX 7600XT would easily find room here, because the jump is still much too big. But we’ll just wait and see, after all, the price structure still has to consolidate to some extent. The table actually shows the filled and the still open gap very clearly.
  Radeon RX
7900 XTX
Radeon RX
7900 XT
Radeon RX
7900 GRE
Radeon RX
7800 XT
Radeon RX
7700 XT
Radeon RX
7600
Architecture RDNA 3 RDNA 3 RDNA 3 RDNA 3 RDNA 3 RDNA 3
Chip Name Navi 31 XTX Navi 31 XT Navi 31 XL Navi 32 XT Navi 32 XL Navi 33 XL
GPU Design Multi-Chiplet Multi-Chiplet Multi-Chiplet Multi-Chiplet Multi-Chiplet Monolith
Process Node TSMC N5
TSMC N6
TSMC N5
TSMC N6
TSMC N5
TSMC N6
TSMC N5
TSMC N6
TSMC N5
TSMC N6
TSMC N6
Compute Units 96 84 80 60 54 32
Shader Units 6.144 5.376 5.120 3.840 3.456 2.048
RT Accelerators
96 84 80 60 54 32
AI Accelerators 192 158 160 120 108 64
Memory 24GB
GDDR6
20 GT/s
20GB
GDDR6
20 GT/s
16GB
GDDR6
18 GT/s
16GB
GDDR6
19.5 GT/s
12GB
GDDR6
18 GT/s
8GB
GDDR6
18 GT/s
Interface 384 bit 320 bit 256 bit 256 bit 192 bit 128 bit
TBP 355 W 315 W 260 W 263 W 245 W 165 W
MSRP 999 USD 899 USD 649 USD 499 USD 449 USD 269 USD
AMD sees the new cards in direct competition with NVIDIA’s GeForce RTX 4070 and RTX 4060 Ti 16 GB, which can of course also be found in the slides (see link below). Where this ends up in reality in the benchmarks, we will of course find out for ourselves today. As a reminder, we would like to show you the product presentation once again:
AMD fills the gap and also releases the unicorn: Radeon RX 7800XT and RX 7700XT flanked with FSR3
With that, the first page is done and we are slowly preparing for the test. But stop! There are four cards today, and I’ll quickly introduce you to them on the next page – it’s worth it!
167 Antworten
LEIV
1,558 Kommentare 645 Likes
Uff, schlimmer als befürchtet, hoffentlich wirds bei der nächsten Generation wieder besser
Die RX 7700XT ist eigentlich gut, denn sie füllt eine böse Lücke. Und NV hat da einfach nichts.
Antwort 7 Likes
RX480
1,887 Kommentare 879 Likes
Wenn der Preis sich normalisiert, net schlecht.
Roland83
708 Kommentare 549 Likes
@Igor da hast du in der Überschrift schnell mal die 7800XTX gespoilert xD
M
Moeppel
883 Kommentare 314 Likes
Also ein Lückenfüller und eine 6900XT zum Preis einer 6900XT?
Reiht sich nahtlos in den Rest der Generation ein, würd ich sagen ;)
Antwort 5 Likes
SchmoWu
95 Kommentare 25 Likes
Danke für den Test.
@Igor Wallossek bringst du noch was zum untervolten? Wieviel Verbrauch man einsparen kann und wie sich das auf die Leistung auswirkt.
C
ChaosKopp
573 Kommentare 608 Likes
Nicht, dass es an sich schlechte Karten sind, aber diese Generation hat nicht geliefert, was wir uns wohl erhofft hatten.
Mich wundert, wie inkonsistent die Leistung im Vergleich zu den Vorgängern ist. Mal spürbar mehr Performance, mal nicht so prall. Als läge wirklich noch treiberseitig etwas im Argen.
Gut, man war auch gewohnt, dass das Preis- Leistungsverhältnis sich jede Generation verbessert. Und die Leistungsaufnahme.
Da AMD uns leider nichts mehr machen lässt, wird das eher nichts :(
Ja, kommt vom Stress. Peinlich aber auch. Habs gefixt :D
Antwort 4 Likes
SchmoWu
schade aber trotzdem Danke Igor
exi78
166 Kommentare 90 Likes
Finde die Karten jetzt nicht schlimm, beides gute Karten.
Nach wie vor gibt es paar 6800 und 6800XT im Abverkauft, da kann man noch paar € sparen, grad wenn beide unter 400€/500€ zu bekommen sind.
echolot
1,118 Kommentare 875 Likes
Habe es befürchtet und bin direkt vom Benchmark zum Fazit übergangen. Im Grunde geht auch noch eine günstig zu ergatternde 6800XT, aber ganz ehrlich für 1080p und 1440p besser eine RTX 4070, alleine schon wegen dem Stromhunger. Was haben die sich nur dabei gedacht. Wenn jetzt FSR3 exklusiv nur für die neuen Karten verfügbar wäre könnte man das der Community ja noch vermitteln. Abser so lautet mein Fazit: 3 Jahre alte Technik annähernd auf Augenhöhe mit der neuen Generation. Nichts neues unter der Sonne. Schade.
Nachtrag: man muss natürlich abwarten was AMD mit FSR3 abliefert, aber zum jetzigen Zeitpunkt ist die 4070 schon alleine aufgrund von DLSS 3.5 und Frame Generation die bessere Wahl.
R
RX_Vega1975
165 Kommentare 46 Likes
NEUER v23.20 Branch für die gerade Releasten 7700XT und 7800XT Karten
Mit welchem Treiber wurde getestet und zudem was bringen die Neuen Optionen im Treiber Menü @Igor Wallossek
Kannst dies schon mal sagen bitte,- Danke!
S
Staarfury
257 Kommentare 206 Likes
Dass die 7800XT gegen aufgrund der 4070 mit ähnlicher Leistung und ähnlichem Preis nicht unbedingt brilliert kann ich verstehen.
Aber wieso die 7700 XT mit ~16% weniger Leistung für 11% tieferen Preis dann zu einem guten Angebot wird, nur weil Nvidia da kein schlaues Produkt hat, erschliesst sich mir nicht wirklich.
Für mich ist die 7700 XT den aufgerufenen Preis nicht wert, und die 4060 Ti als "Alternative" ist nochmals viel schlechter.
P.S. Die Überschrift von Seite 9 hat noch die falsche Auflösung.
W
Wheely
14 Kommentare 6 Likes
Noch eine kleine Sache zum ändern: die Überschrift der Seite 9 ist Details zu Full-HD, soll aber wahrscheinlich Details zu WQHD heißen.
Casi030
11,923 Kommentare 2,339 Likes
Schaun wir mal.;)
PL runter und mehr FPS ist doch auch was......
Y
Yumiko
546 Kommentare 248 Likes
Das ist ja genau die Nvidia-Taktik: Nur die neuere Generation bekommt die coolen Features, so dass die Leute nicht die sonst grob gleichwertige und inzwischen günstige Vorgängergeneration kaufen können.
Das ist doch super fair von AMD - hätten ja FSR3 auch nur für die 7xxx Generation machen können. Ok, wäre wegen Open Source wohl eh nicht gegangen - noch ein Vorteil von AMD: läuft auf allen Karten die wollen/können.
Y
Yumiko
Vielleicht machst du dann mal ein Artikel ;)
echolot
Noch mal von hier kopiert:
Das ist auch das was die anderen Tester in ihren benchmarks aufzeigen. Preislich würde ich trotzdem zur 7800 XT greifen. 50 € machen den Bock nicht fett und für 4GB mehr RAM und bessere Chipleistung ganz klar zu bevorzugen. Wenn man dann schon 50 € mehr hat, dann sind die nächsten auch nicht mehr weit und man gönnt sich eine RTX 4070. Die Staffelung von 400 bis 600 € ist aber auch sowas von eng. Mal gucken wer zuerst einbricht.
Follow Igor:
