GPUs Graphics Latest news Picture stories
PowerColor RX 6900XT Liquid Devil in my test lab – picture gallery and first impressions
I was certainly a bit hasty with the announcement of the PowerColor RX 6900XT Liquid Devil at the time, because the card had already been here in the lab for some time and was also fully tested at that time. Since some coolers from EKWB (mine was not one of them) showed slight weaknesses in the finish, PowerColor has simply recalled all cards again and had them replaced (respect!). The result is really something to be proud of and now all sides have something to gain from it.
PowerColor can be sure to have created a very exceptional card, EKWB can sleep better again and we just start all over. The reader will be pleased in the end, even if these specimens will probably always remain unattainable. But it’s like the auto show: everyone runs to it and then makes long teeth. Instead, I present you a graphics card of a very special kind, because the card itself is a visual (and electrical) treat!
Since you have to use a custom loop cooling, the accessories also turn out accordingly. PowerColor adds a nice PCB ruler (not necessary, but stylish) and EKWB three mini bottles of dye for the coolant (completely unnecessary). The two plugs for closing the unused sides on the terminal (absolute necessary) are unfortunately left out for this. Strange and a bit illogical, but there it is like the RGB. The main thing is colorful, the rest is overrated anyway. But even here the skilled plumber will have enough parts in stock. Small stuff, but it’s holding something up.
Before we start the rest of the picture gallery, let’s quickly take a look at the key data from GPU-Z, because the reader is also interested in that:
D
Deridex
2,224 Kommentare 858 Likes
Auf den ersten Blick hätte ich gesagt, dass das Lineal eher nach einem PCB-Lineal aussieht. Die werden ja oft als Werbegeschenke verteilt. Bist du dir sicher, dass das aus Alu ist?
Saschman73
507 Kommentare 308 Likes
... kann man doch ganz leicht mit einen Alu-Magneten überprüfen, oder? :-)
10,476 Kommentare 19,608 Likes
Du hattest Recht, 2 seitisg kaschiert. :D
D
Deridex
Brauchst n Igors Lab Lineal? 😁
geist4711
274 Kommentare 127 Likes
schöne karte aber kaum bezahlbar, mindestens derzeit :cool:
leider wurde bei dem schönen kühler der teil der zu sehen interessant gewesen wäre,
von einer folie oderso abgedeckt.
so sieht man nicht ob zb die finnen zugesetzt sind, schade!
D
Deridex
So n PCB Lineal ist recht flott gemacht, sobald du weißt was du alles drauf haben willst.
D
Deridex
Scherzkeks. Im Ernst: Wenn du ein Layout für den chinesischen Leiterplattenfertiger deines Vertrauens haben willst, musst du dir schon überlegen, wie groß das werden soll und was explizit drauf soll.
g
gedi
33 Kommentare 5 Likes
Dass die 2 Fittings zum abdichten fehlen ist hoffentlich nicht dem "Originalzustand" geschuldet. Wäre ja megapeinlich, wenn man sich den Krempel noch dazukaufen müsste. Ich denke, wenn es derzeit lieferbare 3060 non Ti für sagenhaft billige 99000€ zu kaufen gibt, für wie viele Leben geht dann das Produkt über die Theke? Jetzt macht der Begriff "Godlike" wenigstens Sinn ....
Gurdi
1,370 Kommentare 900 Likes
Optisch wirklich ein absoluter Leckerbissen.
ro///M3o
361 Kommentare 249 Likes
Meiner Meinung nach machen im Augenblick XFX und PowerColor richtig "dezente" bzw. sehr hübsche Karten, die auch noch ordentlich funktionieren und nicht nur alles "Optik" ist :cool: ebenso sind die mit ihren Modellen auch recht "moderat" im gegensatz zu manchen Anderen die für jedes % mehr / weniger Leistung eine komplette Modellreihe mit absurdesten Namen in den Markt werfen... Gut aktuell kann von "werfen" keine Rede sein, sagen wir mal einfach "paperlaunchen". Ihr wisst was ich meine...
DommeP
122 Kommentare 37 Likes
Mhm, beim Wort Dreifachanschluss dachte ich erst an Wasser rein, raus und Strom - nicht an den reinen Stromanschluss Oo
Da möchte wohl jemand mit Nachdruck an die Leistungsspitze, oder lieg ich falsch wenn ich im Kopf hab das der 6900 sonst 2 Anschlüsse reichen?
CallistoJaro
174 Kommentare 59 Likes
big-maec
912 Kommentare 538 Likes
Alles ist aber übertrieben, hier mal 2 Anregungen.
EDIT:
Vielleicht würde ich meine Powercolor RX 6900XT Red Devil Limited Edition gegen eine RX 6900XT Liquid Devil eintauschen. :)
E
Eisbär2020
15 Kommentare 2 Likes
Ne fertige Wassergekühlte Graka mit netten Beigaben👍. Schönes Design und dolle Fatamorgana 😎😉 Hast du sie schon demontiert und mit Brösel fixen müssen🤔 Weil was nützt es ne fertige Karte, wenn diese an wichtigen Stellen mit "Airpads" gekühlt werden 😎 Bin mal auf die nächste Folge" Jäger des verlorenen GPU Schatz Teil 451 " gespannt 😁😎
Hinweis:
Dieser Beitrag enthält geringe Spuren von Ironie und ist in keinster Weise gegen den Autor gerichtet 😊😎
P.s Ich möchte auch eine vernünftige Graka habe, ohne das Mondpreise verlangt werden 😞😭
D
Deridex
@big-maec
Das Digikey Lineal kenne ich. Das andere ist mir neu. Eurocircuits hat auch gute gehabt. Aber ich denke ein an n Igor seine Themen angepasstes Lineal passt besser. Sofern Interesse besteht und es für den Igor ok ist, kann ich hier in den nächsten Tagen mal einen Entwurf zur Diskussion stellen.
Stadtreiter
210 Kommentare 170 Likes
Apropos "Mondpreise":
Donnerstags um 17:34 Uhr gab es die letzten Wochen regelmäßig neue Karten im AMD Shop zum UVP. Bei der 6800xt war nichts zu machen, die waren in Millisekunden ausverkauft, aber für die 6900xt hatte man immerhin mehrere Minuten Zeit. Wäre vielleicht einen Versuch wert.
Habe meine letzte Woche bekommen und seit gestern hat die auch einen Alphacoolen Kühler drauf. Zusammen 1120€ und damit momentan leider immer noch billiger als manch eine 3070. Mein persönliches Limit war irgendwann in normalen Zeiten mal "bis 800€ für die 3080, und die 6900xt ist unsinnig", aber ich denke mir "lieber eine 1000€ Karte für 1000€, als eine 700€ Karte für 1400€". Doof, oder?
Saschman73
Gilt das im AMD Shop auch für CPU's? Ich habe mir letzte Woche fast alle Teile für meinen neuen PC bestellt, ausser die CPU. Da wollte ich noch etwas abwarten und schauen ob die Preise sinken weil der Alpacool Kühler für meine 6900XT e nicht vor 5-6 Wochen kommt :-(
Follow Igor:
