Aircooling Basics Cooling Reviews Wärmeleitpaste und Pads Watercooling
PCGH Gear Carbonite Ultra review – Generally not bad but with question marks
I actually didn’t want to test the PCGH Gear Carbonite Ultra at the beginning, because it is always difficult to objectively evaluate products from colleagues. Not because I lack objectivity, but because third parties are quick to assume the opposite. It doesn’t matter whether the result is good or bad, there is always a reason to complain. I do it anyway for two reasons: Firstly, it was the paste for which I received the most inquiries and for which there are the fewest reliable tests. Secondly, this paste is unlikely to be available in this form for much longer, so I have to hurry.
Why did they settle on exactly this name? I have no idea. Apart from the fact that Carbonite Ultra has been around for ages as an established brand product in the technology sector (video professionals know this), the risk of confusion with Carbonaut from Thermal Grizzly is certainly not to be dismissed out of hand. Action will certainly have to be taken. But at least it encourages curiosity. Because when a single gram costs almost 10 euros (now sold out) and two of them almost 16 euros, the hairs on the back of my neck stand up. That’s a profit margin to dream about, although I’m very sure (ok, I know) that PCGH profits the least here of all those involved. I have to defend those involved at PCGH, because they definitely relied on the wrong person or persons.
I can already spoil the fact that the paste is really good for short-term use, which is probably also due to its optimized composition. However, usability and reliability are not its greatest strengths. It will have to be measured against the Arctic MX-6, both in terms of consistency and long-term behavior. The only difference is that the MX-6 is significantly cheaper in terms of weight. The Carbonite Ultra in the 2-gram tube costs more than four times as much! However, the 14 W/(m-K) stated for the thermal conductivity is once again the usual marketing fairy tale.
An important foreword on “bulk thermal conductivity” and false marketing promises
I am now deliberately prefacing this with two quotes that not only speak to me from the heart, but also absolutely agree with my laboratory measurements. Conventional pastes cannot achieve much more than 4 to 5 W/(m-K) under the usual conditions on a GPU or CPU in terms of layer thickness, temperature and pressure. Because these quotes are honest and unfortunately correspond to reality, I will use this part from now on as a standard quote in all paste tests of all manufacturers and put it in front. You can’t bend physics.
For those who wonder how you can even arrive at figures above this limit, it should be noted that test conditions can certainly be adapted to achieve astronomically high figures. However, testing in a bucket has nothing to do with reality, even if a known measurement method is used. Without knowing the exact circumstances, such values are completely misleading and pointless. You could give many suppliers credit for simply not knowing any better and just copying the OEM data sheets, but it doesn’t make misleading consumers any better.
Thermal Grizzly
The mostly theoretically determined thermal conductivity values differ greatly depending on the application, as important factors such as contact pressure, temperature or surface cannot be taken into account uniformly. All our cooling products have therefore no longer given specific thermal conductivity values since the 4th quarter of 2020.We continue to rely on the test results of independent tests and reviews so that our customers can get a more realistic impression of the performance of our products in practice under comparable circumstances.
Arctic
ARCTIC has made a conscious decision not to provide thermal conductivity values for thermal pastes and thermal pads, as many manufacturers invent, artificially inflate or embellish these values. Thermally conductive paste has a thermal conductivity of 1 to 4 W/mK. Values outside this range, such as 12.5 W/mK, do not correspond to the truth. Many competitors state values above 4 W/mK to suggest better performance. This often leads to false expectations and dissatisfied users…
Unboxing
In addition to the paste, you receive two spatulas (one would have been enough) and two isopropanol pads with instructions. The initiated also like to use glasses cleaning cloths, which are much cheaper 🙂
Technical data
Let’s leave the marketing aside and look at the technical data of this paste, which is available in various containers and sizes. We can see that the information on thermal conductivity has nothing to do with reality. The green shaded columns contain measured values, the gray shaded columns contain the manufacturer’s data, which is usually missing
Technical data
Bulk thermal conductivity λ 14 W/(m-K) (marketing)
Effective thermal conductivity λeff, 3.383 W/(m-K) (Test method ASTM D5470-17)
Effective thermal resistance Rth 400 µm 1.28900 mm²K/W (Test method ASTM D5470-17)
Effective thermal resistance Rth 200 µm 0.68130 mm²K/W (Test method ASTM D5470-17)
Effective thermal resistance Rth 100 µm 0.40036 mm²K/W (Test method ASTM D5470-17)
Effective thermal resistance Rth min 0.18004 mm²K/W (Test method ASTM D5470-17)
Minimum layer thickness 9 µm (at 60 PSI and 60 °C after 30 minutes)
Thermally conductive particles Zinc oxide (ZnO), some aluminium oxide (AL2O3), silicone oil (Test method LIBS, Keyence EA-300)
Volatilization rate (volatilization) n/a
Density 3.74 g/cm³
Viscosity 110 to 170 Pa-s (1100 to 1700 poise), not plausible
Working temperature -250°C / 350°C, not plausible
Breakdown voltage n/a
Contact resistance n/a
Maximum pressure n/a
Color blue
Accessories
2 spatulas, Alko-Pads
Container
Tube 1 g, 2 g
Further links and basics
1,870 Kommentare 1,176 Likes
Das wird in der Tat bis jetzt produktpolitisch brisanteste Pastenanalyse sein. Allerdings finde ich es, gerade bei dem Preis, schon etwas unschön, daß die Paste dann nicht einmal richtig homogen ausfiel, denn Klumpen stören auch den Wärmetransfer. Ist das schlechte Mischung ab Werk, oder passiert das beim Lagern mit der Zeit?
Ebenso ist, wie von Dir (@Igor Wallossek ) geschrieben, der viel zu großzügige Einsatz von Silikonöl auch bedenklich. Aber, Silikonöl ist eben billig, v.a. wenn man's in großen Mengen kauft.
Weißt Du denn, welcher OEM die Paste produziert? Wenn ja, wäre ein Hintergrund Artikel, vielleicht nach den nächsten 6-8 Tests zu dem Thema (Wo die Pasten wirklich herkommen) interessant!
Antwort 5 Likes
10,920 Kommentare 20,700 Likes
Das OEM Business ist so eine Sache. Die ganz großen Hersteller sind ja mehr oder weniger bekannt, die kleineren Panscher sind im Flow. Da ist ein Kommen und Gehen und man fragt sich manchmal, ob nicht jede Batch eines eingeführten Produktes von wo anders herkommt :D
djrobinson
43 Kommentare 28 Likes
Ich kann mir gut vorstellen, was bei erscheinen dieser tests, in den marketingabteilungen abgeht.
Da wird sicher die eine oder andere videokonferenz kurzfristig anberaumt. 🙃
DMHas
72 Kommentare 35 Likes
Danke für den Test! PCGH kocht bzw. lässt auch nur mit Wasser kochen ...
Auf die Langzeittests freue ich mich schon jetzt!
S
SpotNic
1,151 Kommentare 505 Likes
Wollt ihr nicht mal Waschmaschinen, Spülmaschinen, Herde usw testen? Auch so totentwickelte Produkte wo einem dauernd X Mehrwerte versprochen werden und man Ende nur den Namen und Spielerreien in der Steuerung bezahlt :D
echolot
1,195 Kommentare 938 Likes
Igor deckt auf...für mich der Preisleistungsbrecher schlechthin bis dato ist ganz klar Arctic MX-6. Die machen nicht nur Superlüfter zum Schnäppchenpreis. Ich verwende bisweilen noch immer die Noctua NT-H1, da noch Restbestände da sind.
big-maec
985 Kommentare 595 Likes
Erinnert mich ein bisschen an mein Haferflocken-Blaubeerjoghurt Müsli, das zieht auch Fäden.
DigitalBlizzard
3,255 Kommentare 2,247 Likes
Danke @Igor Wallossek , ich bastele schon mal eine vereinfachte Käuferformel
Marketing Wmk :4-5=reale Wmk
Im Ergebnis zeigen die bisherigen Messwerte alle das, was die meisten Tests quasi auch aufgeben, mal 1-2 Grad Differenz in der Realität, egal ob Marketing Zweistellig etc. Real liegen sie bei 2 Komma - 3 Komma.
Das Zünglein an der Waage macht also am Ende eher nicht die "Bessere" Paste, sondern viel mehr die Schichtdicke in der realen Anwendung und die Langzeitstabilität und schon gar nicht der Preis.
Das ist ein erstes Fazit, welches sich vereinfacht ableiten lässt.
Oder noch krasser ausgedrückt, die Viskosität und chemische stabile Zusammensetzung einer Paste ist am Ende viel ausschlaggebender für den Anwender als irgendwelche Marketing Wmks.
Auch wenn's nervt, deckt sich mit meiner Erfahrung aus den X-Apply Tests aus den letzten Monaten, wir haben 23 verschiedene Pasten von 6-18 Wmk ( Nominal ) getestet, quasi alle haben das gleiche Temperaturergebnis geliefert, Differenz max 1K, die schlechteren Werte kamen von den sehr Viskosen Pasten, und nicht von denen die laut Marketing weniger oder mehr Wmk
Die Messwerte der Pasten jetzt, liefern uns dafür eine ziemlich schlüssige Erklärung.
Bitte berichtigt mich, wenn ich da einen Denkfehler habe.
Antwort 5 Likes
grimm
3,238 Kommentare 2,188 Likes
Das deckt sich auch mit meiner Erfahrung als Endanwender - von Alphacool Apex über Arctic Cooling (alt) / Arctic MX-4 (neu) oder Noctua - ich kann da keine großen Unterschiede feststellen. Lediglich auf der Langstrecke hab ich mit der aktuellen Tube MX-4 die Erfahrung gemacht, dass man die jährlich erneuern sollte.
Antwort 5 Likes
DigitalBlizzard
Ich denke chemische Stabilität und Langzeithaltbarkeit sind die entscheidenden Faktoren und natürlich die möglichst geringe Schichtdicke in der realen Anwendung.
Antwort 4 Likes
Nulight
277 Kommentare 185 Likes
Ich freue mich schon auf die Tests der Festen Produkte mit der besten Langzeitstabilität.
zB. KryoSheet / EC360 Graphite / Honeywell PTM 7950 u.s.w
Grund: Ich hätte gerne eine: ``Ein mal Einbauen und Vergessen bis zur nächsten CPU Lösung´´ 😀(y)
noir.
266 Kommentare 178 Likes
Einfach öfter ne neue CPU kaufen, dann ist die Haltbarkeit der WLP nicht so wichtig 😜
Aber ja, die Pads reizen mich auch sehr.
Nulight
7800X3d , da brauchst lang nix Neues Xd
DigitalBlizzard
Ich wäre da eher nicht zu euphorisch, horizontal leiten viele gut, vertikal siehts da ganz schnell anders aus, mal ganz abgesehen von ein paar anderen Nachteilen.
Ghyped wurde schon so oft so viel an Pasten, Pads und auch Kühlern etc, und alleine die Werte von Igors Messungen zeigen ganz klar, das noch lange nicht alles Gold ist was glänzt.
LurkingInShadows
1,401 Kommentare 601 Likes
Gold kann ich mir nicht leisten Silber reicht mir.
kA was die damals beim ditech 2014 draufgetan haben, aber mir ist der 4770k bis heurigen Februar afaik nie ins thermische Limit gelaufen. (Kann aber auch an den Anwendungen liegen. WoT, STO, diverse Städte u.Ä. Sims)
Feen-Schubser
57 Kommentare 22 Likes
Dankeschön für die Testreihe aktuell.
Darauf haben viele gewartet.
Ich habe noch 2 volle Tuben (also 2x 8G) MX5.
Ich traue mich nicht sie zu benutzen, weil ich nicht weiß ob sie fehlerhaft sind und wie Kleber am Ende wirken.
Reste von einer alten PK2.
Master Gel Maker fast voll
Master Gel Maker Nano fast voll
Über 8 Jahre alt, bin mir aber nicht sicher.
Ich würde es spenden wollen.
Wo kann ich die hinschicken oder wie läuft das ab, wohne in Thüringen
Für die Wissenschaft.
Mich interessiert sehr der Vergleich zu Wärmeleitpasten in der Zusammensetzung und vor allem Langlebigkeit im vergleich zu PTM7950 auf CPU oder GPU.
Gibt im Luxx was spanendes mit einer 4090 und PTM7950
und CPU:
Zitat:
Its fine.
Bit better than paste, slightly worse than Galium
A better idea might be lapping of both surfaces with 600 & 1200 grit ~ then polish with Flitz Paste
And buy a kryosheet from Roman (der8auer)
Above 100 microns , which is pretty much every CPU - PTM is better than kryosheet.
Besonders im Bezug auf den neuen NH D15 G2 LBC und AMD.
Wobei der LBC ist für mich fast wie Lapping vom Kühler früher.
Hab heute mal einen D14 als Test übers Schleifpapier gezogen mit 320 da blieb der stehen, bei 600 war nach 4x schieben oder so das blanke Kupfer da.
Entweder hat der Vorgänger schon mal biss was gemacht oder der ist so weich :)
Lapping 4650G hat was gebracht (der war auch extrem), Kühler weniger.
Als Anmerkung.
Ich schreibe es ja immer wieder: nur neue Pasten. OVP und im MHD. Sonst ist es angreifbar
Gregor Kacknoob
548 Kommentare 456 Likes
Dito, gerade für Grakas. Interessiert mich stark, ob die teils gottlosen Preise auch nur im Ansatz berechtigt sind.
noir.
Sicher, das wird auch immer so sein. Und bis es mal Tests wie diese (mE verdammt gute) Reihe hier gab, hat sich auch schon oft gezeigt, das es bei den gängigen, am Markt etablierten keine allzu grossen Unterschiede gab - unabhängig vom Versprechen der Hersteller. Wenn nun noch die Materialanalyse dazukommt und man somit gute Schlüsse auf Langzeithaltbarkeit machen kann, deckt das den bisher für mich fehlenden Punkt mehr als gut ab.
Daher schliesse ich mich @LurkingInShadows Aussage an: Gold muss gar nicht immer sein. Silber reicht - wenn das Gesamtpaket passt. Lieber 2°C höhere Temperaturen dafür aber konstant über einen langen Zeitraum. Mag aber auch daran liegen, das ich den PC im Laufe der Jahre immer weniger als Hobby-Bastelobjekt zum daddeln, dafür sehr viel mehr als Werkzeug sehe. Und das muss eben in allererster Linie zuverlässig funktionieren. Natürlich darf der dann auch kühl und leise sowie vernünftig zusammengebaut sein - das spielt dann aber erstmal zweite Geige.
Das der Punkt nach Langzeithaltbarkeit immer interessanter wird, ist wohl auch den ganzen Fällen über minderwertige Pads (siehe zB ausblutende Billigpads etlicher RTX 30x0) oder jüngst die sich (billiges Wortspiel) verdünnisierende WLP auf vielen RTX 40x0 GPUs.
Follow Igor:
