Reviews SSD & HDD Storage drives
Patriot SUPERSONIC RAGE PRIME 1 TB Review – Small USB stick with SSD qualities in writing OR reading
Patriot has once again made it exciting and even issued an extra NDA for this SUPERSONIC RAGE PRIME 1TB USB 3.2 stick. I must also preface this by saying that I had to do this test without a communicated MSRP, which might put some things into perspective later on. But I was really fascinated by this stick in many parts of this test, because it offers more than just SATA performance for the pocket in the size of a rather small USB stick. Even with really large files and even after several full-fill actions, where I had completely filled the stick and then deleted it again.
But why does Patriot make it so mysterious this time? Unfortunately, nothing could be pulled out of the noses of the gentlemen, not even the data on the controller, which celebrated its mysterious appearance in the fully glued stick and is supposed to be “something from Phison” in the end. Be that as it may, it worked as advertised, otherwise today’s test would have had a different, rather catty introduction. Anyone who makes such big cheeks must also be able to deliver. That’s where there’s a lot of light, but also some shadow. But more on that later.
Actually, I wanted to compare the stick with an external NVMe-SSD (ADATA SE770G 1TB), but in the course of the tests I came to the conclusion that the purpose and characteristics of the two drives are not comparable. The new stick is almost perfect as a powerful data carrier for on the go, which can swallow larger data volumes in no time and also spit them out again quickly. The device can also handle long 4K streams without batting an eyelid and without stuttering. And you then not only reach the stated “up to 600 MB/s”, but can often exceed it very clearly, even with the stick already fully used and various write operations.
But – here comes the certain but – it’s not a real drive in the conventional sense, so no tricks and optimization of the firmware of the “Phison something” helps with the IOPS. While the two tested drives, the stick and the external SSD, were still very close to each other in the synthetic tests and even AJA as a streaming benchmark, the workstation test later separates them into two completely different categories. But I’ll get to that in detail and with lots of benchmarks later, because first we want to look at both the technical details and the usual benchmarks. At least here Patriot can score really well with the new stick.
Connectivity, power consumption and temperatures
In order to achieve the promised data rates, USB 3.2 is used as the interface, which is logical. This in turn only really works in all its glory if you use the USB-A port on the back of the motherboard, which is directly connected to the CPU. At least for most motherboards. Significantly lower values are measurable at normal USB 3.x or a split port. However, the low power consumption is astonishing. In idle it is just 50 to 100 mW, during reading and writing it is on average less than 500 mW. So with peaks below 1 watt, there won’t be any surprises thermally.
Apart from the fact that Patriot also writes about built-in temperature sensors in its documentation, the resulting typical power loss of far below one watt is never a reason for concern, especially since the stick only got hand-warm after one hour even in the workstation test. Plus point with distinction. The tested NVMe SSD from ADATA in the external case is a different caliber with almost 6 watts and in the stress test it is the perfect pants warmer for Siberian winter evenings.
The spec sheet also reads pretty tasty at first.
PEF1TBRPMW32U Sku Sheet_062121
P
Phelan
200 Kommentare 178 Likes
ne NDA für ein Stick ... okay ... Ich hab schon überlegt welche GRafikkarte jetzt wieder neu rauskommt ;-)
Beeindruckend finde ich die kleine Stromaufnahme.
Mich nerft es seit Jahren das schneller USB3.0 Stick gerne mal 1-3 Watt haben.
Dauerhaft am Notebook angesteckt kostet ds echt viel Akkulaufzeit, so das ich da noch eine sparsamen aber auch lahmen Stick nutzen.
Leute die große Daten bewegen möchte und/oder einen wirklich schnellen Stick mit massig Speicher haben wollen, die wird auch der Preis nicht stören.
10,476 Kommentare 19,612 Likes
Der ist im Idle mit 0.01 bis 0.02 Ampere wirklich kein Stromfreser. Beim Lesen wird fast mehr gelutscht als beim Schreiben.
Es gibt ja noch einen Test, aber da hat man offensichtlich am falschen Port getetstet ;)
ArthurUnaBrau
331 Kommentare 162 Likes
Gibt es einen technischen Grund für USB-A statt USB-C oder hat es nur mit Kompatibilität zu tun?
p
passivecool
56 Kommentare 32 Likes
Irgendwie war der Trailer doch spannender als der Hauptfilm. :LOL:
Wer als Patriot sein Sneakernet pflegt muss künftig nicht mehr wie ein gehetzter Gorilla laufen;
die vorab gesparten kostbaren Millisekunden sei Dank!
g
goch
488 Kommentare 181 Likes
Ja, wenn der Stick noch USB-A und USB-C hätte (hybrid), wäre das echt ne schöne Allzweckwaffe ;)
Derfnam
7,517 Kommentare 2,032 Likes
Ja, nett, aber die Marketingbande hat auf der Verpackung mal so richtig gnadenlos zugeschlagen:
EXTREME PERFORMANCE +++++++++
Könnte mal wer testen, ob die Katz' den 8x oder 9x vom Schreibtisch schubsen kann, bis er kaputt ist?
Tim Kutzner
855 Kommentare 700 Likes
Intel's 14nm wird neidisch
D
Don Omerta
52 Kommentare 37 Likes
Vor drei Jahren habe ich bis auf zwei USB-Sticks alle in die Tonne gekloppt. Die beiden USB-Sticks nutze ich nur noch für Bios-Update. Die anderen USB-Sticks habe ich durch zwei alte SSD (1 x Samsung 830 und 1 x Kingston HyperX aus 2012) via USB-3.0 Gehäuse ersetzt, der Speed ist halt besser und die Einbrüche bei kleinen Daten nicht so dramatisch wie bei den Sticks.
Trotzdem ein interessanter Test.....
Liquidator
9 Kommentare 3 Likes
Hab hier 512gb, is echt ne Wucht. 🙂
1,693 Kommentare 1,029 Likes
Danke für den Test, übrigens auch bei CB in einer Meldung verlinkt. Vielleicht hat Igor oder jemand hier die Antworten: Sind die kleineren (und billigeren) Sticks (zB 256 oder 512 GB) ähnlich oder genau so schnell?
Davon abgesehen, ist die Frage wie Patriot oder wer auch immer das Ding herstellt die hohen Datenraten schafft ohne die üblichen Nachteile von SSD on a Stick, v.a. Power Draw? Das finde ich schon faszinierend.
Deshalb haben die auch so ein NDA Drama drum gemacht
K
Kobichief
673 Kommentare 204 Likes
Erstklassige Überschall Wut mit extremer Leistung. Gratulation an Patriots Marketing, ihr habt es geschafft einem guten Produkt den Anschein eines billigen Schrottprodukts aus der Grabbelkiste für die Zielgruppe 13-Jähriger zu geben.
Follow Igor:
