GPUs Graphics Latest news
Palit RTX 4070 Dual 12GB Undboxing and Hands On – Short and sleek MSRP card with two fans in dual-slot design
The second card in today’s small MSRP roundup is the Palit RTX 4070 Dual 12 GB. For today’s launch day of the MSRP cards, we can of course only show the cards that also meet NVIDIA’s specifications and are offered at the MSRP of 659 Euros. Since the performance in games and applications is the same for all these 200 watt cards, you can of course skip this part for now. The real differences are in the technical details of the implementation, especially the circuit board and cooler. But you already know that.
Of course, this pushes up the time needed for such a review, so I will catch up on these things in detail in a later individual test. Today we first have the technical specifications, many pictures and a very first assessment. The rest is then worked through continuously and conscientiously over the following period. Of course, I also have a nice picture gallery for you, even though these were taken during the latetests at Fritz Hunter and not at my photo studio. Of course, I will do that as soon as the card arrives again.
First of all, there is no surprise in the technical specifications:
The power limit is also a done deal and can no longer be changed. 200 watts are set by default, more is not possible:
The first hands-on proves that Palit has also applied the dreaded red pencil. RGB? No one needs it and the treasurer doesn’t need it at all. So away with it. At just under 750 grams, the card is also nice and light, which certainly suits the motherboard. However, the ears will probably have to suffer a bit, because the card was not really inaudible in the first long-term use. Well, it’s not a real hurricane, but you can hear something.  At least in the open structure. But it’s not a quadcopter either, so much for reassurance. Otherwise, palit has kept very closely to the reference PCB. With all the advantages and disadvantages.
However, I can assure you that nothing will burn down or even explode at Palit. And as I have already written several times: As a technician, you have a feeling for certain weak points that could easily have been avoided. But more about that in the near future. Today, the pictures will have to do for now.
Kohlkopf
43 Kommentare 10 Likes
Okay, klingt erstmal ernüchternd. Finde es immer noch bisschen seltsam das diese Karten keine 16GB Speicher haben und die Bandbreite zu meiner sechs Jahre alten 1070 Ti sogar gesunken ist.
Davon ab würde es mich interessieren, warum es zu der 40xx Serie von Nvidia hier mehr bzw. weitere Tests gibt (CustomDesigns) und über die neuen AMD Karten nicht. Woran liegt`s?
Guest
Bandbreite GTX 1070 256 Gb/s, RTX 4070 504,2...
Wo siehst du denn da das die Bandbreite gesunken ist? Die Anbindung ist langsamer (256 bit Vs. 192 bit) - der Durchsatz ist aber höher geworden durch GDDR5 Vs. GDDR6X.
Welche Tests zu neuen AMD Karten soll es denn geben? Es gibt doch nach wie vor nur zwei Stück... nVidia hat nen ordentlichen Vorlauf was neue Karten dieses Jahr angeht... mal schauen wann sich das ändert.
Kohlkopf
Ja, meine die Anbindung. Ich vergleich hier Stumpf die Zahlen. Höher = Besser. Finde das mit der Anbindung ist eine künstliche Beschneidung, nur um mehr Produkte auf den Markt zu werfen. Und bei diversen Preisvergleichen sehe ich eine Menge CustomDesigns der AMD 7xxx Karten. Hier wäre es ja wie bei den anderen Test ja auch interessant ob es zu starken Spulenfiepen kommt, die Kühllösung okay ist etc.
10,477 Kommentare 19,621 Likes
Daran, dass die Hertsteller bewusst nichts schicken und nicht an Tests interessiert sind, weil sie an den Karten aktuell eh nichts verdienen und die sich im Prinzip auch so verkaufen. Die XTX Nitro mache ich noch, dann wars das.
Würde ich welche bekommen, würde ich sie auch testen (siehe 7900XT Pulse samt Verlosung)
Kohlkopf
Traurig, hatte aber schon so eine Vermutung. Bin aufjedenfall gespannt auf die Tests der 4070.
Edit.: Der Test der 4070 FE ist ja schon da. Oopsi ;-)
Ghoster52
1,456 Kommentare 1,121 Likes
Klingt im ersten Moment beschnitten, aber es hängt ja von der Anzahl der Speichercontroller ab.
Für 12 GB braucht es nur 3 Controller und 3x 64Bit = 192Bit, den Rest macht die Geschwindigkeit des RAMs.
Follow Igor:
