Cooling Fans Reviews
One size bigger: be quiet! Light Wings 140 mm PWM and PWM High Speed Review
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
We had already tested the smaller siblings of the Light Wings in 120 mm and found them to be good. So now comes the test of the be quiet! Light Wings 140 mm PWM and PWM High Speed and it will be interesting to see if they have managed to scale the successful concept in size. Often enough such projects are crowned with success, but now and then the whole thing turns out less optimal. That is exactly what we want to find out today. And the same applies as with the 120 mm fans: Individually or in a three-pack with a hub as a free accessory?
Even the larger 140mm variants are still fans that are focused on performance and noise development, and they also shine nicely as a bonus without overdoing it. The look hasn’t changed compared to the smaller models, it’s just kind of “upscaling”. This can go well, but it doesn’t necessarily have to. But that’s why we’re testing.
The manufacturer also uses the so-called rifle-bearing, which is very similar to the normal plain bearing, but is quieter and has a service life almost as long as ball bearings. This bearing has a spiral groove through which fluid is pumped from a reservoir (similar to the fluid bearing). This makes them rather insensitive to the direction of installation (unlike plain bearings), as the pumped fluid lubricates the top of the shaft. Pumping also provides sufficient lubricant on the shaft, reducing noise and increasing service life. So much for the theory and we will see later in the sound spectrum if and which advantages can be seen (and above all heard).
The frame is, except for the translucent light ring with its individually controllable 20 ARGB LEDs, rather plain and very torsion-resistant. The use of translucent plastics results in a very uniform luminous image without extreme hotspots for the LEDs. The shape of the impeller follows the well-known wave design of be quiet!and relies on rounded tear-off edges. While the classic standard case fan uses 7 fan blades, the High Speed has a total of 9 fan blades, which later explains the slightly different measurement results of the fans at identical speed.
The decoupling is achieved with inserted rubber applications, which do not twist even when the screw is tightened. The gap dimensions and surface finish are good to very good. The power consumption at full speed of 3.84 (140 mm PWM) and 4.68 (140 mm PWM High Speed) watts is lower than that of the 120 mm models. This, in turn, is astonishing and perhaps already allows conclusions to be drawn about what we are about to measure. First of all, however, the key data for better comparability with the later measurement results in the comparison:
140 mm PWM Standard 140 mm PWM High Speed
Form factor 140 mm
Starch 25 mm
PWM Yes, 4-pin connector
RGB 20 ARGB LEDs
Decoupled Yes
Color Frame Black
Accent color None
Color rotor Translucent
Weight in g 264 266
min. speed 150 250
max. speed 1500 2200
Volume flow m3/h 95.14 121.82
Flow rate CFM 56.00 71.7
static pressure mmH2O 1.49 2.3
Sound pressure dBA 23.3 31
Life Time hrs 60,000
On the next page you will first see how and what we test and why. Understanding the details is extremely important in order to be able to objectively classify the results later. The differences between many models are more in the details and THE best fan for all situations can hardly exist. There is a certain optimum in every situation and of course there are also good all-rounders. But they usually have their price. But if you plan to use 60mm radiators for example, you might save money by choosing the best model for your application, which might not perform so well as a case fan. And vise versa, of course.
For all curious people here again an excerpt of the data sheet:
Light_Wings_datasheet_de
ssj3rd
240 Kommentare 169 Likes
Hach ja, also immer noch kein perfekter ARGB Gehäuse Lüfter 😉
Pascal TM-Custom
1,122 Kommentare 1,362 Likes
ric84
63 Kommentare 30 Likes
Perfekt ist relativ, was wäre denn für dich perfekt?
Martin Gut
8,144 Kommentare 3,859 Likes
Zu "Full Motion" gehören doch nicht nur 3 RGB-Farben sondern 3D, UV-Licht-Effekte, Surround und Vibrationsfeedback. Ein Erlebnis-Lüfter, der einem richtig hinein zieht. 🥳
Antwort 5 Likes
ric84
Wenn mein gefühlt 20KG schweres Case samt Inhalt damit auch noch in den Hoverbetrieb übergehen kann, dann sag ich nur "TAKE MY MONEY"!!11!
Pascal TM-Custom
Martin alles gut bei dir heute? Drehst jetzt durch? :ROFLMAO: :ROFLMAO: :ROFLMAO:
10,919 Kommentare 20,698 Likes
Ich bestehe auf der Impfpflicht gegen Humorlosigkeit! Wenn jetzt schon Rotationsschleudern große Raketen ins All befördern sollen, ist doch so ein schwebendes Gehäuse technische Pillepalle. :D
Schwester Monika, bitte boostern :D
Antwort 4 Likes
a
aclogic
130 Kommentare 56 Likes
Aua, das ist doch sicher schmerzhaft, wenn der Lüfter einen hinein zieht? :unsure:
Martin Gut
Ja. Ich war schon im Spital, aber sie haben mich wieder laufen lassen. (war nur ein Allergietest)
v
vonXanten
834 Kommentare 370 Likes
@Martin Gut so schnell behalten die einen nicht da ;) Könnte ja jeder kommen :cool:
Und ein schwebendes Gehäuse, da hätte der Staub keine Chance mehr! Würde ich auch nehmen.
ssj3rd
„Für einen expeliziten Kauftipp reicht es allerdings nicht ganz, denn dazu fehlt dem normalen Gehäuselüfter etwas der Durchsatz und beim High Speed kann man das (wenn auch nur sehr schmalbandige) Humming nicht wegdiskutieren.“
Ähm, klingt irgendwie nicht so perfekt, oder?
M
Mr.Danger
77 Kommentare 43 Likes
😂😂😂 Ich hab mich so weggeschmissen, dass ich mich nun hier anmelden musste. Geil man🤩
Btw der Artikel von @Igor Wallossek war natürlich auch nicht so schlecht.🙂✌
Anmelden ist immer kostenlos, aber nie umsonst. :P
BTW:
CB hat jetzt auch einen Epyc-Server und freche 8 Kerne mehr. Ich glaube, ich muss mal aufrüsten. :D
Niccolo_Nirhall
4 Kommentare 2 Likes
Schöner Artikel. Diese Luftstromwaben kommen mir seeehr bekannt vor. Die habe ich viele Jahre verbaut :D
Pascal TM-Custom
ja die stecken z.b in Kühlregalen in Einkaufsläden damit lenken die die kalte Luft gerichtet nur ins Regal und nicht außerhalb.
So hat man es mir erklärt gibt es in verschiedenen stärken. Sind jedenfalls was feines
Niccolo_Nirhall
Richtig. Daher kenne ich sie auch. Egal wie und woher die Luft kommt, sie strömt damit immer in die gleiche Richtung. Kann man schöne Luftschleier mit machen. Mensch, habe ich doch was in meiner Ausbildung zum 'Mechatroniker für Klima- und Kältetechnik' gelernt (Die Jobbezeichnung klingt einfach kacke xD )
Pascal TM-Custom
hehe ja sind für die Lüfter Test einfach Genial die verhindern die Abrisskante da wir eine recht Dicke Platte verwenden und die Luft Verwirbelung ist besser. Es lässt sich viel besser damit messen.
Diese Info haben wir von einem Herrn aus deiner Zunft
Niccolo_Nirhall
Tronado
4,268 Kommentare 2,313 Likes
Nur gut, dass ich vier Scythe Kaze Flex ARGB 140 pwm hier liegen habe und am WE in einen Auftrags-PC einbaue.
Hier testet ja keiner mal, was ich gerne sehen würde. 😢
Follow Igor:
